Storage attachment points and other fiberglass modifications
pcg
City/Region: Sherwood
Vessel Name: C-Quest
Photos: pcg
PostPosted: Mon Feb 04, 2019 7:08 pm    Post subject: Storage attachment points and other fiberglass modifications Reply with quote
I’m in the planning stage for starting fiberglass work on my 22 Cruiser project boat next fall. I’m trying to think of all the modifications I want to do to the hull and cabin fiberglass, particularly any areas where I can tab in reinforcement for attachment points for cleats, eye bolts, and anything else that can be used to secure or tie down cargo.
For example, should I incorporate SS eyebolts into the lower transom for trailer tie down? Are there locations where additional cleats might be handy? What about eye bolts for tie down points for securing extra fuel tanks or cargo in the cockpit during long cruises? Any other mods that would be useful?
I’ve never owned a C-Dory and never cruised in my own boat, so I have no experience to tell me what features I might wish I had, when I’m finally able to enjoy the boat. Thank you for any suggestions.
Paul
PostPosted: Mon Feb 04, 2019 7:14 pm    Post subject: Reply with quote
Paul, come up to the Friday Harbor CBGT and take a look at 50 C-Dorys. They will all be different, and all the same, so you can pick out what you like and what you think might work for you. Can't get a better selection than that anywhere.
Link to the Friday Harbor Thread:
http://www.c-brats.com/viewtopic.php?t=27120
DavidM
City/Region: Punta Gorda
PostPosted: Mon Feb 04, 2019 7:25 pm    Post subject: Reply with quote
Everyone has different ideas and needs for cleats, tie down eyes, etc. The factory probably installs what most people need and leaves it to the individual to add any additional points.
So the suggestion to look at a bunch of boats and talk to their owners is a good one. You can then find out what works and what doesn't.
But when you install a point, there are probably two levels of strength to consider. For moderate to light loads like cover tie downs then thru bolting it with fender washers on the inside will do. But if it is a high strength point like a boat to trailer tie down or a mooring cleat then put a backing plate inside to distribute the load. A 6" x 4" piece of Starboard or even 1/2" ply will make it a much stronger point.
David
pcg
Photos: pcg
PostPosted: Mon Feb 04, 2019 10:05 pm    Post subject: Reply with quote
hardee wrote:
...come up to the Friday Harbor CBGT and take a look at 50 C-Dorys. They will all be different, and all the same, so you can pick out what you like and what you think might work for you.
Not sure I can make it, but that's a really great suggestion.
DavidM wrote:
... But if it is a high strength point like a boat to trailer tie down or a mooring cleat then put a backing plate inside to distribute the load. A 6" x 4" piece of Starboard or even 1/2" ply will make it a much stronger point.
David
Thanks David. I'll do that.
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Mon Feb 04, 2019 10:57 pm    Post subject: Re: Storage attachment points and other fiberglass modificat Reply with quote
Not too "lower" keep them well above the water line.
Regards,
Rob
PostPosted: Mon Feb 04, 2019 11:07 pm    Post subject: Reply with quote
My personal feeling is that a strap over the gunnels just forward of the aft deck cleats is a good stern tie down. You want to keep the boat from sliding sideways and going forward. Many of the boats already have stern tow eyes.
I like backing plates to be aluminum or stainless steel/. If I use wood or other materials, I like to use "fender washers"--way oversized washers to help distribute the load.
I do feel that almost all of the boats benefit from additional hand railings at the edge of the cabin top, aft and forward:
I have also found cleats right by the aft cabin are good--such as:
Our current 25 has 3 jam cleats on each side of the cabin side, and also hangers for the light docking lines across the aft cabin bulkhead. Sorry don't have photos of these.
Extra cleats by the bow for light lines to adsorb shock on anchor rode.
Upgraded aft lazarett hatches which do not leak:
If you want extra tie downs or even spring Line cleats the fold down pad eyes work great:
We have put extra grab rails in front of the galley, and in front of forward facing navigator's seat (if so equipped.
We use the fittings of the Bimini top to keep chairs and other items on the side of the cockpit in place when traveling.
pcg
Photos: pcg
PostPosted: Tue Feb 05, 2019 1:09 am    Post subject: Reply with quote
Thank you Bob. Those are exactly the kinds of suggestions I'm looking for!
PostPosted: Tue Feb 05, 2019 2:04 am    Post subject: Reply with quote
I have been looking at backing cleats and tie-downs recently and when the marine electronics tech was here I was talking with him about that and his recommendations. He was good with Sail or star board, Fiberglass board, or stainless, but no aluminum due to the galvanic corrosion possibility (too hard to keep it isolated from the fasteners).
PostPosted: Tue Feb 05, 2019 3:19 pm    Post subject: Reply with quote
As long as you use marine grade aluminum--and in some cases just use a isolating washer--or Tef Gel anti corrosion compound it is not a problem. I have used aluminum, in multiple boats which saw a lot more rough blue water than any C Dory, including backing a SS Bow roller assembly about 36" long, x 10" wide which was removable to get the LOA of boat down to 45'. SS is not immure to problems itself. Again--the proper materials and knowledge are essential.
I have also made a number of electronics brackets out of aluminum which is easy to work, and can be made much thinner and lower than the brackets which come with the electronics.
What can be an issue is going to Home Depot and getting a non satisfactory aluminum (depending on use).
PostPosted: Tue Feb 05, 2019 11:41 pm    Post subject: Reply with quote
Bob, You are right but generally, mixing metals is kin to asking for trouble. Why tempt fate. I found this photo in an album labeled "Electrolysis".
"While working on the bilge pump through-hull (on the right), I noticed some serious electrolysis on the U-bolt for the transom tie-down. "Electrolysis." What a great name for a boat. Sounds like a Greek God."
The link to the album is here:
http://www.c-brats.com/modules.php?set_albumName=album2361&op=modload&name=gallery&file=index&include=view_album.php
Not sure why something as dangerous as this is provided by the C-Dory manufacture, but if anyone should know better, they should have.
I think I will skip using aluminum, just in case.
PostPosted: Wed Feb 06, 2019 1:02 pm    Post subject: Reply with quote
Electrolysis is the process of passing an electric current through a substance in order to produce chemical changes in the substance.
Galvanic corrosion is caused by self-induced current created by electrical potential of two dissimilar metals in contact with an electrolyte. It can occur when two dissimilar metals (such as copper tube and steel pipe) are connected in the presence of an electrolyte. Fresh potable water is a weak electrolyte.
Or perhaps more eloquent:
Electrolysis occurs when an electrical current strays from its path due to improper wiring or a defect coming between two metals in the presence of an electrolyte, usually seawater in this case. Metal hull boats are particularly at risk because the hull is conductive and stray wire or connections use the hull as a ground. The two metals can be the same or different.
Galvanic corrosion is when two different metals are in contact in the presence of an electrolyte. One metal will be more chemically active than the other, and a reaction occurs. Very pure water will not conduct electricity, so the electrolyte isn’t present. Saltwater however conducts an electrical current and allows for corrosion to occur.
Those who write books electrical circuits find it is very useful to differentiate, because of different causes and different "cures".
The photo of the trailer is clearly rust= corrosion.
I suspect that the same is true for your backing plate. Unfortunately during the Reynold's ownership of C Dory some short cuts were taken--and this is an example of one of them where some in-expensive aluminum plate was used which had minimal exposure to sea water. I suspect that that same plate would have corroded to that extent, just sitting on the deck or in the bilge.
The reason for "rust" in the SS bow eye is that they used inferior Chinese Imported SS. I found many examples thru the years of this inferior SS. You may remember that I found rust on the deck fittings of my Tom Cat 255 within months of delivery--and will minimal salt water exposure.
There is also crevice crack corrosion in SS.
Crevice corrosion is not unique to stainless steels. It can occur in other alloys including those of aluminium, titanium and copper.
It is a localized form of attack, where there is a breakdown of the surface passive layer, in crevices or on 'shielded' areas beneath surface deposits. Engineered or 'designed in' crevices can be set up at bolted and other joints, beneath flanges or between flanges and gaskets or other contact areas such as valve seats.
The mechanism of crevice corrosion. I have seen this result in loss of rudders, chain plates and keel boats--where the outcome is the loss of the boat.
To be an effective corrosion site, the crevice must be wide enough to allow the corroding electrolyte in and then provide 'stagnant' conditions. Crevice corrosion can therefore be a concern where gaps are a few micrometers wide, but there are no absolute or critical dimensions for crevices, below which corrosion is certain.
Your example of corrosion is an excellent reminder to check all of these fittings., Unfortunately in the 22, these are often behind the fuel tanks. You can sometimes see these areas with a small camera, a properly placed mirror, or an inexpensive Borescope. I have a Milwaukee Borescope which was less than $100 at the time, which I have used for years to exam these poorly accessible areas. Every marine surveyor should be dong this--but they don't....
Page generation time: 0.0531s (PHP: 69% - SQL: 31%) - SQL queries: 24 - GZIP disabled - Debug on
