Gps with built in antenna
bladesmith
City/Region: Galisteo
State or Province: NM
PostPosted: Mon Jan 14, 2019 10:35 pm    Post subject: Gps with built in antenna Reply with quote
Hi Folks..I recently bought my first CD, a 2007 16' cruiser. My first boat with a pilot house...Can I mount a GPS with a builtin antenna inside my cabin or do I need a separate antenna mounted out side?... Thanks
PostPosted: Mon Jan 14, 2019 10:49 pm    Post subject: Reply with quote
I've had mine mounted inside the cabin with no external antenna for years. No problems. Signal passes through fiberglass quite well.
Saxe Point
City/Region: Sooke
PostPosted: Mon Jan 14, 2019 10:53 pm    Post subject: Reply with quote
I’ve got a Garmin Echomap 50DV chart plotter on my dash inside my fibreglass pilot house. My boat is not a C Dory, but the pilot house is fibreglass and very similar to many, including the C Dory. Works perfectly and picks up satellites very quickly. I can’t imagine an external antenna would make any difference to the GPS performance. I’ve read that my experience is common.
PostPosted: Tue Jan 15, 2019 12:06 am    Post subject: Reply with quote
I've got two Garmin Chartplotters, an AIS transceiver, and now a VHF radio with GPS. I haven't hooked the new radio up yet, however I've had no problems with the chartplotters and AIS transceiver receiving GPS signals without an external antenna, and I don't expect to have a problem with the VHF radio. Colby
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Tue Jan 15, 2019 7:57 am    Post subject: Reply with quote
I removed the GPS antenna on the roof of our boat when I realized it wasn't hooked up to anything. The Garmin picks up satellites right away with no issues.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
PostPosted: Tue Jan 15, 2019 1:16 pm    Post subject: Reply with quote
Modern GPS receivers will pick up the GPS signals in cars, boats, planes, etc, unless there is extensive shielding--for example if you had a steel boat, and GPS on lower deck. Even with trawlers with hard tops flying bridge (including aluminum in the hard top), I have had the GPS work in the cabin below.
bladesmith
PostPosted: Tue Jan 15, 2019 1:49 pm    Post subject: Reply with quote
Thank you all for the quick response
janjackparadise
City/Region: Port Charlotte
PostPosted: Thu Feb 06, 2020 10:16 am    Post subject: Reply with quote
I would like to see the C-Dory you have for sale in Florida.
What marina is the boat located at ?
Thank you
I am a Buyer
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Thu Feb 06, 2020 12:09 pm    Post subject: Reply with quote
Bladesmith,
I still find electronics to be one of the most confusing boat purchases. Internet research to find out if there is an all-in-one product that can answer your issues, or whether a new unit will interface with existing electronics takes some research. To further complicate things, asking what electronics will work for you is a bit like asking others what size shoe you should buy. Ultimately, individual needs should override internet market preferences. So I don't have much to offer in the way of product choices, other than to say good luck.
Mark
PostPosted: Thu Feb 06, 2020 8:27 pm    Post subject: Reply with quote
I have one GPS antenna on the outside cabin top, and 2 inside on the shelf. I cannot tell any functional difference between them.
SleepyCMoon
PostPosted: Fri Feb 07, 2020 1:06 am    Post subject: Reply with quote
I have two GPS antennas on the roof. One for the chartplotter (NMEA 0183). The boat came with that one. I added a NMEA 2000 GPS receiver antenna (all in one) for my NMEA 2000 network. Never thought of putting the one I added anywhere else.
Page generation time: 0.1376s (PHP: 28% - SQL: 72%) - SQL queries: 24 - GZIP disabled - Debug on
