Where to find a rear cooler rack?
rock knocker
City/Region: Georgetown
PostPosted: Sun Dec 16, 2018 9:44 pm    Post subject: Where to find a rear cooler rack? Reply with quote
Ive got a 22ft cruiser and want to be able to put a ice chest in front of motors. Where do i find them at? Thank you in advance
A Fishin C
Guest
PostPosted: Mon Dec 17, 2018 12:04 am    Post subject: Reply with quote
Get the rack from a c-dory dealer or from the factory, however,
the cooler that the rack was designed for is no longer in production I believe.
but there are other coolers with a length and width dimension that will fit.
Not cheap. My pics have a factory rack.
PostPosted: Mon Dec 17, 2018 12:12 am    Post subject: Reply with quote
There are many different racks and cooler assemblies. Probably because most of them are owner built to some extent. The stainless parts are put together (like Lego's, Erector or Tinker Toys) to suit and fit each owners needs and abilities.
Mine came on my previously owned boat. A single bar that goes across the forward edge of the splash well and then t Igloo coolers that attach to that bar with home made fittings and a rubber space to keep it from rubbing on the fiberglass. One cooler goes over the bar and fits from the splash well side. The other hangs on the bar and over the aft section of the cockpit. 2 coolers, one bar, and nothing on the cockpit sole. Ingenuous I think.
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Mon Dec 17, 2018 9:02 am    Post subject: Reply with quote
This is another option that was not very expensive and required no holes in the boat. I have been using mine for 5 years now and really like it.
Rob
http://www.c-brats.com/modules.php?set_albumName=Cooler-Rack&id=IMG_2199&sid=57e8698ad8dbedcf3618a1e54aafdabd&op=modload&name=gallery&file=index&include=view_photo.php
PostPosted: Mon Dec 17, 2018 10:24 pm    Post subject: Reply with quote
I don't believe there is /was a cooler rack which fit all coolers. I have used SS tubing with end fittings for Bimini tops--and the eyes a number of ways in the cockpit well. This is simple and not particularly expensive.
The tubing is 7/8" diameter. The end caps are SS and are held on the tubing with set screw. These are held in the well with the deck fittings for a Bimini top, set horizontally across the well. Can be any elevation--one on the bottom and one on the back often is enough. [/img]
rock knocker
PostPosted: Mon Dec 17, 2018 11:27 pm    Post subject: Reply with quote
Thank you for the options.
Page generation time: 0.0388s (PHP: 59% - SQL: 41%) - SQL queries: 19 - GZIP disabled - Debug on
