interlocking Teak tiles
PostPosted: Thu Nov 29, 2018 11:45 am    Post subject: interlocking Teak tiles Reply with quote
I came across these in my Facebook feed the other day. They are similar to the rubber deck tiles in installation but have teak topping. They might be of interest to a brat. @$8.40/sq ft. they are not that much more expensive than the dry deck tiles ($6.29/sq ft at West Marine).
PostPosted: Thu Nov 29, 2018 12:18 pm    Post subject: Reply with quote
I used these on my boat. Not teak, but the look is pretty close. Lots cheaper too.
https://www.ikea.com/us/en/catalog/products/90234226/?gclid=EAIaIQobChMInY7UuY363gIVEVqGCh3cigz7EAQYASABEgJ3wvD_BwE
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Sat Dec 01, 2018 10:20 am    Post subject: Reply with quote
They are beautiful Roger. But, it looks like it would be hard to clean the fish guts and crab trap leavings.
Gene
tight lines
PostPosted: Sat Dec 01, 2018 4:31 pm    Post subject: Reply with quote
I have owned boats and houses with the short teak decking--glued together not on a rubber backing. (These had a scrim on the back, and were glued to the floor or deck). Both in boats and house decks, eventually these broke loose from the glue.
I have no idea how the teak planks are glued to the rubber or plastic backing--but teak is an extremely oily wood, and few glues work really well with it. When we were building boats I did destructive testing because because I was laminating some teak rub rails. I found that the old fashioned Rescorcinal Glue (by Weld Wood) was the best, followed by epoxy.
The Dri Deck and similar rubber based tiles are certainly well utilized (and I have them lining the bilge of my current 25). I also came across some harder ones, which do not flex (and may be better for wood overlay)--but they worked well only on flat parts of the boat.), Reading the reviews--it suggest that the under surface may be a plastic rather an rubber based (?). There is also suggestion that the planks are screwed to the substrate--is that correct? If so--these should be SS fastenings.
I would be interested on how the teak is fitted to the substrate and how they last. Look great! (and cheaper than Deckadence spaghetti mats!)
cmetzenberg
City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
PostPosted: Mon Dec 03, 2018 4:15 am    Post subject: Reply with quote
This looks so good I just bought 27sqft for the interior of mine
Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
Page generation time: 0.119s (PHP: 91% - SQL: 9%) - SQL queries: 22 - GZIP disabled - Debug on
