What length shaft on 83 Angler 22
alleuro
City/Region: Eagle River
C-Dory Year: 1983
Vessel Name: High Tide
PostPosted: Sat Nov 17, 2018 12:26 pm    Post subject: What length shaft on 83 Angler 22 Reply with quote
bought an 83 Angler without a motor do I need a 21" shaft or 25" I understand that. there is some movement available via how it is mounted. What gives the best performance?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sat Nov 17, 2018 1:42 pm    Post subject: Reply with quote
Prior posting stated the length was 20"
Brent Barrett
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Nov 18, 2018 1:53 pm    Post subject: Re: What length shaft on 83 Angler 22 Reply with quote
Take a tape measure, go to back of boat, measure from top of transom to bottom of hull. Your tape says 20" Buy motor to fit transom height. When you install the motor bottom of hull should be in line with bottom of cavitation plate on motor. There will be holes / slots on engine bracket for adjustment. A 25" shaft will be 5" too deep for your boat, unless you built a transom adaptor/spacer to raise it up
Beer Mr. Green
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Tue Nov 20, 2018 1:31 am    Post subject: High Tide Reply with quote
Glad to see the old High Tide has a new owner after being stolen in August.
Good luck to the new owner.
Jack on High Tide II
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
Jack in Alaska
PostPosted: Thu Nov 22, 2018 1:57 pm    Post subject: motor mounting Reply with quote
The holes in the transom fit a 1977 115 Johnson as well as a 1997 Honda 90.
My recollection is a 25" motor shaft but measure it up to be sure.
Jack
Jazzmanic
Photos: C-Dancer
PostPosted: Thu Nov 22, 2018 3:18 pm    Post subject: Re: High Tide Reply with quote
Huh? That doesn't sound right. Sad
Peter & Caryn
Email: pjamero@gmail.com
Jack in Alaska
PostPosted: Sun Nov 25, 2018 3:19 pm    Post subject: bolt holes Reply with quote
HUH.........what doesn't sound right????
Page generation time: 0.1112s (PHP: 80% - SQL: 20%) - SQL queries: 24 - GZIP disabled - Debug on
