Duplicate duplicate posts?
Post new topic   Reply to topic    The C-Brats Forum Index -> C-Brat Site Feedback
Esmi2
City/Region: San Luis Obispo, CA
PostPosted: Tue Nov 06, 2018 3:59 pm    Post subject: Duplicate duplicate posts? Reply with quote
Either I am slightly losing my mind, or posts are occassionally showing up as new several days after their initial appearance.
For instance, right now there is a New Today post for a 2006 C-dory named “Miss Maria.” I am almost positive this exact same post was new last week. But I see no evidence of the previous post, just this new one.
Is it me? Or is something going on?
Crook
PostPosted: Tue Nov 06, 2018 4:03 pm    Post subject: Reply with quote
I noted the same item. Mostly new posters--maybe someone using two names. Most duplicates are a result of not checking to see if the post went thru--or accidentally hitting post a second time as one goes back.
Thataway (Ex Seaweed) 2007 25 C Dory May 2018
City/Region: Leesburg
PostPosted: Tue Nov 06, 2018 5:05 pm    Post subject: Reply with quote
For me there seems to be a timer that prevents accidental duplicate posts. If I have finger trouble and a second duplicate post is sent I get a message that says something to the effect of a second post cannot be sent so soon.
However, it seems that it doesn't work for all people. There are a few users that end up with duplicate posts almost every time they respond to a forum.
PostPosted: Tue Nov 06, 2018 5:06 pm    Post subject: Reply with quote
For me there seems to be a timer that prevents accidental duplicate posts. If I have finger trouble and a second duplicate post is sent I get a message that says "You cannot make another post so soon after your last; please try again in a short while."
It seems that if you hit submit, then preview, and then submit again, you can get duplicate posts.
Also, if you hover on the edit button on your latest post, the popup says "Edit/delete this post". However, once you go into edit mode, I don't see any way to delete it. AFAIK, you can only delete the text the posting contains, but not the actual posting.
nordicstallion
City/Region: Crescent City
C-Dory Model: 19 Angler
Vessel Name: Rylee Rose
Photos: Rylee Rose
PostPosted: Wed Nov 07, 2018 6:35 pm    Post subject: Reply with quote
I had the same problem, I just needed to give it another few seconds after hitting submit.
Vern
PostPosted: Sun Nov 11, 2018 11:39 pm    Post subject: Reply with quote
I am guilty of the same thing. Need to watch the little spinning circle,,,,
Until it stops spinning Shocked
Before we try to move on to the next activity:oops:
Post new topic   Reply to topic    The C-Brats Forum Index -> C-Brat Site Feedback All times are GMT - 6 Hours
Page generation time: 0.0546s (PHP: 73% - SQL: 27%) - SQL queries: 23 - GZIP disabled - Debug on
