Need Help!! Never ending issue Suzuki DF150
Easyvictor.14
City/Region: Dallas
State or Province: TX
Vessel Name: Easy Victor
Photos: Easy Victor
PostPosted: Wed Sep 19, 2018 4:53 pm    Post subject: Need Help!! Never ending issue Suzuki DF150 Reply with quote
OK brats,I have A recurring problem with my Suzuki DF 150 fuel injected 4 stroke. 2008 model on a 23 Venture.
I’ve been in 3 shops a total of 5 times and spent over $2800 so far.
The engine will start just fine, and run for about five or 10 minutes at 3800 to 5500 RPM then it will start to stutter stumble down to about 3000 RPM and never go back.
This is what has been done: water separator replaced, fuel vents re-oriented, loop in fuel vent lines, injectors rebuilt, vapor separator tank cleaned twice and replaced once, new fuel pump $$$, and “vacuum leak” repaired (don’t know what was supposedly leaking) both tanks pulled, cleaned, tested. The engine had 85 hrs on it when I bought it 3 yrs ago from Wefings, Now has 235 hrs. Been a huge pain in my butt, I’ve even thought of selling, but I won’t do that to someone. HELLLLPPPP!!!
All but one shop are in other states, and local shop won’t honor any work, they just want to keep throwing parts at it with my credit card.
There was some water in fuel originally, came in thru tank vents facing forward. That problem is fixed.
"New" 2008 23 Venture.
1992 Boston Whaler Montauk 17
1977 Sea Ray SRV 200 sold 2008
1981 T Craft 26 center console
1981 Silverton 34
1979 Chapparal 187
Many, many other small aluminum, wood and fiberglass toys!!!
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Wed Sep 19, 2018 6:54 pm    Post subject: Reply with quote
Any water and debris in filter. I use a Racor water and gas filter with clear bowl to check.
Have all fuel hoses been replaced esp the ones inside the rigging tube? Hose can look good on outside but the inner hose can fail
What is the fuel pressure on the injector rail?
Do you have the factory shop manual? Any codes using diagnostic software.?
Take it back to Marc at Wefings?
Brent Barrett
Easyvictor.14
City/Region: Dallas
Photos: Easy Victor
PostPosted: Wed Sep 19, 2018 9:42 pm    Post subject: Reply with quote
Yes, every fuel hose and filter has also been replaced, and it does it when run from a portable tank, so it’s engine side. Don’t know rail pressure, I have to assume Suzuki dealers checked that!
The most maddening part is, it’s intermittent. Might start and run all day for several days, then start acting up. Sometimes it will clear after a shutdown for a few minutes, other times it won’t recover until it hits the shop.
Da Nag
Vessel Name: Wilbur
Photos: Da Boats
PostPosted: Wed Sep 19, 2018 10:18 pm    Post subject: Reply with quote
Sounds like venting/fuel flow could be a potential culprit, but even though you've looked into that - have you tried running it on a portable tank just to make sure?
Tux Will, C-Brat Nerd Tux
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Wed Sep 19, 2018 11:20 pm    Post subject: Reply with quote
Is the White E.C.M. power wire HOOKED DIRECTLY TO THE + POST OF A BATTERY, not through a switch, combiner or relay etc.?? Beer
MikeR
City/Region: Mill Creek
C-Dory Year: 2016
Photos: MikeR
PostPosted: Thu Sep 20, 2018 12:50 am    Post subject: Reply with quote
It sounds like something is tripping the over-rev caution system, which on the DF150 limits the throttle to 3000 rpm. Next time it happens, try to re-set it by reducing throttle all the way to idle for at least 1 second (I'd even go into neutral, just to be sure), then see if you can get above 3000 again. That's what the Suzuki manual says, and it's the exact same procedure as my Merc (which limits to 2500 rpm). The owners manuals provide virtually no information on what sensors play into this "feature", but in doing some research, it's more than just over-revs, at least on the Merc. It seems to be a combination of different sensors and from what I've gathered, protects the engine from some kind of perceived over-load condition and can happen at any RPMs above the protection limit (3000 in your case) not just RPMs above the max RPM rating. It could be a bad sensor...Mechanics may insist bad sensors will always throw a code, but I've heard from others who have replaced sensors like TPS or CPS which never threw codes, and their intermittent problems disappeared. Just a thought since it sounds like you've already checked all the fuel systems, and since it is so randomly intermittent.
-Mike
22' C-Dory Cruiser (2016)
16' C-Dory Angler (1989)
10' C-Dory Row Boat (1995)
Easyvictor.14
City/Region: Dallas
Photos: Easy Victor
PostPosted: Thu Sep 20, 2018 10:07 am    Post subject: Reply with quote
OK! I’ll check the dreaded “white wire”, thanks Dave.
Also, it’s not throwing any codes, but I’ll check into rev limiter and sensors.
All the shops have focused on fuel, but I’m leaning electrical also.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Thu Sep 20, 2018 5:32 pm    Post subject: Reply with quote
Change the spark plugs if you haven't already . Really ...........
They fail .
Marc
Wefings Marine Website
Since 1909
Easyvictor.14
City/Region: Dallas
Photos: Easy Victor
PostPosted: Thu Sep 20, 2018 6:14 pm    Post subject: Reply with quote
Changed plugs already also. I’ll be back at the boat Sunday and I’ll start checking these items. It’s just frustrating to have spent almost $3000 on “repairs” that didn’t fix anything. I can’t go back to the shops because they’re behind me on the Loop, and the boat is now back in Texas for the winter.
DavidM
City/Region: Punta Gorda
PostPosted: Thu Sep 20, 2018 7:44 pm    Post subject: Reply with quote
Are you sure that the fuel tank, the fuel pickup, the valve if it has one, any fuel filter and all of the plumbing to the carb or EFI is clean with no blockages.
Years ago I had a motorcycle that acted just like your engine. Turned out it was a blocked fuel pickup tube.
David
Easyvictor.14
City/Region: Dallas
Photos: Easy Victor
PostPosted: Thu Sep 20, 2018 9:02 pm    Post subject: Reply with quote
Yep. Ran it off a portable tank. Same results.
DrewbirdII
City/Region: fanny bay
Vessel Name: Drewbird II
PostPosted: Thu Sep 20, 2018 10:06 pm    Post subject: Reply with quote
Maybe a faulty 02 censor, or the tiny HP fuel filter in the fuel rail is partially plugged? Jim
BrentB
Photos: BrentB
PostPosted: Sat Sep 22, 2018 9:44 am    Post subject: Reply with quote
Do you have the factory shop manual? Diagnostic software kit is available, too.
Pura Vida
City/Region: St. Augustine
Vessel Name: C-Pearl
Photos: C-Pearl
PostPosted: Tue Jun 02, 2020 11:30 pm    Post subject: DF150 Reply with quote
I just bought C-Pearl a 2006 25 Crusier with the same motor as yours. I am going to be servicing myself and came across this post. Just wondering if you ever solved the problems you were having and if so what was the cause.
Thanks!
PostPosted: Wed Jun 03, 2020 11:39 am    Post subject: Reply with quote
My Honda misbehaved due to a bad ECM. There was a service bulletin about it, but I had to point the dealer to it.
Might want to check the service bulletins for Suzuki.
Page generation time: 0.0558s (PHP: 67% - SQL: 33%) - SQL queries: 32 - GZIP disabled - Debug on
