2005 CD 25 Bennett Trim Tab lights not working
joc1212
City/Region: OAK HARBOR
Vessel Name: Last Time ll
PostPosted: Fri Sep 14, 2018 10:12 pm    Post subject: 2005 CD 25 Bennett Trim Tab lights not working Reply with quote
The position indicator lights on the Bennett Trim tabs are not working...(not lighting up)
Does anyone have any ideas where to start looking to fix this. I'm very new to the C Dory and can use all the advise I can get.
Thanks in advance...
Be safe wear a PFD have fun
25 ' CDMA Cruiser 200 Yamaha 15 Honda
All New Garmin Electronics package
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Sep 14, 2018 10:24 pm    Post subject: Reply with quote
I would ask TabMan at
http://www.thehulltruth.com/tabmans-trim-tab-discussion-15/
Brent Barrett
PostPosted: Sat Sep 15, 2018 1:52 am    Post subject: Reply with quote
Sure the brightness is turned up? My tab indicator lights default to very dim when first powered up. I have to increase the brightness quite a lot to see them in daylight. Wish I could set the default to a higher value.
PostPosted: Sat Sep 15, 2018 9:37 am    Post subject: Reply with quote
Check to see if the trim tabs go down. The pump may not be working. Also check to see if you're getting power to the lights.
Those are the first places I'd look.
Page generation time: 0.0507s (PHP: 37% - SQL: 63%) - SQL queries: 17 - GZIP disabled - Debug on
