Navman repair
jkswor
City/Region: tok
Vessel Name: Missy marie
PostPosted: Sun Sep 02, 2018 11:10 am    Post subject: Navman repair Reply with quote
So I bought a 25 ft last year. Had the Navman fuel flow meter
I did not know what it was or how it worked my fuel guage quit working and a friend said I should get fuel meters. Well I found out I had some
However it quit showing letters and numbers. There is a repair person in Virginia That can fix it. For less than $100 he will fix it and send a video of it. If he can’t no charge. There is a kit if you want to fix it yourself.
So that saved me hundreds. If you have an old Navman and the screen has quit showing info, you might give him a shout. thomas.stevens@cox.net
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun Sep 02, 2018 1:50 pm    Post subject: Reply with quote
JKSWOR,
The Tom Stevens in Williamsburg, VA does a wonderful job of repairing Navman instruments. He has repaired numerous ones for me. My Navman instruments are on my sailboat and several of them are exposed 24/7 to WX/UV, because they are mounted on the cockpit bulkhead. Though they have a sun cover, they still see heat/cold/rain.
Most of the instruments fail because the continuity film between the screen and the circuit panel come unglued. Tom removes this and installs a zebra strip (silicon strip with many carbon strips laminated in the silicon). The zebra strip is installed under compression, between the cover and the circuit card, so it will not come unglued over time.
I recommend that you do not spend your money on the kit. I purchased one once and was not careful enough when removing the old glue, so the solvent caused damage to the screen. The unit worked, but after Tom fixed several of mine, I found that he is an expert and worth the extra few buck.
Best regards,
Steve Baum
Steve Baum
Homeport of Portsmouth, VA
joc1212
City/Region: OAK HARBOR
Vessel Name: Last Time ll
PostPosted: Sun Sep 30, 2018 7:01 pm    Post subject: Calibrate Navman Fuel flow meter Reply with quote
How do you tell the Navman Fuel 3100 that you just filled the fuel tank. We just bought this boat and the Navman is showing 3/4 full when I just topped off the fuel tank.
How do I calibrate it??
Be safe wear a PFD have fun
25 ' CDMA Cruiser 200 Yamaha 15 Honda
All New Garmin Electronics package
joc1212
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun Sep 30, 2018 7:51 pm    Post subject: Reply with quote
Joconnor,
You can still read the instruction for Navman fuel instrument here: http://www.navmanmarine.net/upload/Marine/Internet_Manuals/2000/2100_fuel_MN000207A_eng_web.pdf
and here for all of the instruments:
http://www.navmanmarine.net/multi-3100.html
Best regards,
Steve Baum
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Mon Oct 01, 2018 10:53 am    Post subject: Reply with quote
Jim,
When you read the manual, you will see that you only need to punch a couple of buttons simultaneously to reset the Navman after filling; but also you'll need to check at least once that the unit is properly calibrated (also in manual). Calibration entails burning a known amount of fuel and then setting a one-time calibration factor in the unit.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Mon Oct 01, 2018 2:24 pm    Post subject: navman2100 Reply with quote
Thanks for posting .I will look into why mine just stopped working the other day .It lights up and I get prior readings but no fuel flow ? Jim
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Thu Nov 01, 2018 7:08 am    Post subject: Navman Reply with quote
Does anyone know where to buy a navman 2100 spinning transducer the gauge works its the part where the fuel goes through
PostPosted: Thu Nov 01, 2018 12:55 pm    Post subject: Reply with quote
jennykatz,
Just try cleaning that sensor and spinning it with a breath. The sending unit gets "dirty" and needs to be cleaned every year or so.
It's just a turbine wheel and a magnetic pickup, so there's not much to go wrong. I have to do that on Journey On every year or so.
PostPosted: Thu Nov 01, 2018 1:08 pm    Post subject: Reply with quote
The Lowrandce and Navman used the same transducer. Not sure if the current transducer is the same--but it should be.
PostPosted: Thu Nov 01, 2018 5:06 pm    Post subject: Reply with quote
The current Lowrance fuel flow meter is a NMEA 2000 bus device. I looked at the Navman manual and it is not clear to me if the Navman works the same way.
When I installed the Lowrance system FF system, I also had to install a NMEA 2000 backbone and a compatible GPS receiver.
https://www.lowrance.com/lowrance/type/accessories/sensor-networking-accessories/fuel-flow-sensor-pk/
Page generation time: 0.0347s (PHP: 65% - SQL: 35%) - SQL queries: 24 - GZIP disabled - Debug on
