Snider
Joined: 21 Jun 2013 Posts: 204 City/Region: Charleston
State or Province: SC
Vessel Name: Kestrel Dawn
Photos: Kestrel Dawn
Posted: Fri Aug 31, 2018 11:29 am Post subject: Fuel Tank Selector Decal/Sticker |
Anyone have a source for a new fuel tank selector decal? Mine is faded and I'm unable to find a new one.
_________________ Brandon
22ft Cruiser
Charleston SC |
Posted: Fri Aug 31, 2018 3:22 pm Post subject: |
I solved the problem by drilling 1 hole at the port and 1 hole at the starboard feed position of the pointer and putting a home-made green and red plastic washer under a machine screw to indicate the appropriate position.
Survives better than a decal, probably for the life of the boat.
Snider
Posted: Fri Aug 31, 2018 3:24 pm Post subject: Good idea |
Good idea, thanks. I've also considered just painting on my own decal. My registration numbers and name is painted on too so wouldn't be a stretch. I like the color coding with the washer. |
srbaum
Joined: 30 Aug 2010 Posts: 877 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Fri Aug 31, 2018 4:19 pm Post subject: |
Brandon,
I had a local trophy shop make a new label. The new label is plastic made for engraving. I selected gray for my top surface color to match my boat's trim color, but you can get any color you want. When engraved below the color surface, the letters are white. The new plastic label came with two sided tape to make placement easy, then I fastened it using the fuel valve screws.
Lastly I ended up replacing the fuel valve (they happen to be inexpensive at West Marine), as the valve, valve stem, handle and screw are all different materials, so I had to cut it off at the valve stem, because the fastener and handle could not be removed any other way.
http://www.c-brats.com/modules.php?set_albumName=album2209&op=modload&name=gallery&file=index&include=view_album.php _________________ Steve Baum
Homeport of Portsmouth, VA
Snider
Posted: Fri Aug 31, 2018 5:25 pm Post subject: Thanks |
Thanks Steve, that looks great. There's a trophy shop down the road I'll check out. I tried to remove mine but the screw for the handle was stripped also. Like you said, different metals. I was thinking of trying to drill it out but just cutting off the stem works too. I just put new hoses on it so it shouldn't be to bad to get loose.
Now after this I need to install those lazarette hatches you have.
Thanks |
srbaum
Vessel Name: Osprey
Photos: Osprey
Posted: Fri Aug 31, 2018 6:11 pm Post subject: |
Brandon,
I did not remove the old fuel selection decal, as it is completely covered by the new plastic placard. I forgot to mention that the new fuel placard cost about $18...
The new hatches do not leak (like the old ones did) and just remember that butyl rubber tape (off white color and very inexpensive) is your friend. |
Snider
Posted: Thu Dec 06, 2018 9:26 pm Post subject: Update |
I meant to update this back in August. Thanks for the help. I got this printed at a local trophy shop for $8
Joined: 27 Oct 2012 Posts: 3372 City/Region: SW Michigan
Posted: Fri Dec 07, 2018 12:17 am Post subject: |
I would get a vinyl label place to make a suitable substitute (e.g. diylettering.com) and stick it on myself. |
rbfconstruction
Joined: 19 Sep 2017 Posts: 126 City/Region: huntington beach
Photos: Angler Management
Posted: Fri Dec 07, 2018 9:56 am Post subject: fuel tank selector |
I would use a sharpie
kidding
Richard |
Jazzmanic
Photos: C-Dancer
Posted: Fri Dec 07, 2018 12:01 pm Post subject: |
Nice job, looks great! _________________ Peter & Caryn
Email: pjamero@gmail.com |
Posted: Fri Dec 07, 2018 2:13 pm Post subject: |
Something I have done for labeling, because I always want to make sure It is what I want to say and where I will be OK with it for a long time is use "post it note" and Sharpie. And now, Post-it" has come out with the new "EXTREME Notes". Water resistant and stick to anything. After a season with that then I get out the label machine.
SleepyC
