Comparing VHF/GPS Radios (w/ current rebates)
Goto page 1, 2, 3  Next
JMacLeod
City/Region: Stuart
C-Dory Year: 2018
Vessel Name: C-Shalom
Photos: JMacLeod
PostPosted: Tue Aug 28, 2018 1:21 am    Post subject: Comparing VHF/GPS Radios (w/ current rebates) Reply with quote
Need some help deciding on fixed and handheld VHF radios.
I was originally keeping everything in the Garmin family, but on sage advice I'm going with a radio company for the radio.
Some of the Icom and Standard Horizon models have current rebates, so that might be a nice timing bonus.
FIXED AIS/GPS VHF:
Icom M506, AIS/GPS, NMEA 2000, 2 minute last call recording
$600 - West Marine
$454 - Ultimate Passage
Standard Horizon GX2200, AIS/GPS, NMEA 0183
$400 - $40 rebate = $350 - West Marine
$320 - $40 rebate = $280 - Ultimate Passage
The main difference seems to be the NMEA 2000 connectivity and the 2 minute last call recording feature.
Is this worth the $174-250 premium, and why?
FIXED GPS only VHF:
Icom M424G, GPS
$300 - $30 rebate = $270 - West Marine
$240 - $30 rebate = $214 - Ultimate Passage
Standard Horizon GX1700, GPS
$250 - $30 rebate = $220 - West Marine
$203 - $30 rebate = $173 - Ultimate Passage
Is AIS a useful enough function for FL/Bahamas cruising that I should consider it or not?
If so, is it worth the extra boat unit for a dedicated Tx/Rx?
We don't plan to cruise at night or in fog, but man makes plans and God laughs.
HANDHELD VHF:
Icom M93D, GPS/DSC
$240 - $30 rebate = $210 - Ultimate Passage
Standard Horizon HX870, GPS/DSC
$200 - $40 rebate = $160 - West Marine
$205 - $40 rebate = $165 - Ultimate Passage
The plan is to have one fixed in cabin and one handheld in ditch bag.
Does this sound about right for off-shore Florida cruising?
Is there anything else I should be considering in a VHF?
PostPosted: Tue Aug 28, 2018 3:04 am    Post subject: Reply with quote
I have the Standard Horizon GX1600 it is the same as the 1700 but without the GPS. If you another GPS source you can easily connect it to the GX1600.
I believe that these radios only speak NMEA 0183. So your GPS source has to be the same if you have the 1600.
I also have a Standard Horizon handheld that I got from somebody on CL (it was barely used). It was $60. I don't recall the model. It is in the ditch bag, but the only thing I've ever used it for it to see if it still works. BTW, with the handheld radio off, the battery will hold a charge for at least a year. I put it on the charger once a year, but it always seems to be fully charged.
PostPosted: Tue Aug 28, 2018 3:59 am    Post subject: Reply with quote
You are asking if AIS is worth the extra boat unit, or was it the M-506?
The ICOM M-506 with AIS (NOTE: Receive) also has the Last call 2 minute recording. It is the only VHF with that long record feature. For me it is worth it for that alone, but then, I use that radio for VHF Chn 16 (almost) exclusively. There are times when I will follow a USCG call on that radio for the recording feature alone.
The function menu on the M-506 is so easy to use, and quick both to use and to learn that it is my favorite VHF. (I should note here that I have 3 fixed mount vhf's on board, the M-506, the Standard Horizon 2150 - same as the 2200, and the Raymarine 218, all mounted side by side and each one has a favorite function, but if I replaced either of the later, it would be with the M-506. All have hailer/auto foghorn function. The SH and ICOM both have AIS Receive.)
Now to the usefulness of the AIS. In a 2 button push, I can pick an AIS equipped vessel, and find if it will be crossing ahead, dead on, or behind me, and see exactly how soon (TCPA) and where (CPA) = Time to closest point of approach and closest point of approach. Handy, not only at night or in fog, but where you have other vessel traffic, crossing situations or not. (In my situation - crossing the Strait of Juan de Fuca - I have large ocean going ships running between 4-5 knots up to 22 knots for the big ships or 35 knots for the walk-on passenger ferries. I can spot them, determine my crossing plan, have a 1 or 2 button direct call to their wheel house if there is any question as to continued travel direction, and know I have plenty of safety margin. It is called peace of mind.
Yes, not every boat on the water will have AIS, but the large commercial ones, and the big, fast yachts will have it. I don't know if you have radar or not, but yes you can do some of that with radar using MARPA, but it will take you multiple buttons and up to 2 minutes. AND, radar can not see around islands or to the other side of a big ship or other visual obstruction. AIS can, is fast and easy. The AIS receive VHF does not need a separate antenna.
To have that function you MUST have 2 things, GPS input to the VHF, and DSC activated on your VHF, which will require a MMSI number. Easy and an important step for safety.
As to the handheld VHF, You are on the right track. Look for floating capability, recharege and replaceable battery, multiple transmit power levels - usually 1, 3 and 5 or 6 watt, and DSC capability, (that one will probably have an internal GPS too.) I use 2, on in the ditch bag, and one on my PFD. If I have someone with me, they get the ditch bag radio for their PFD. I have had the Standard Horizon HX 851 since they first came out. Good service and good radios. I would go with those.
gstraub
City/Region: Callao
C-Dory Year: 1998
Vessel Name: EnDoryFun
Photos: EnDoryFun
PostPosted: Tue Aug 28, 2018 10:41 am    Post subject: Reply with quote
I have the GX2200 and bought it because of the built in GPS and AIS receive functions. I have been happy with it so far, but really have not used all the functions much. The GPS Store has it for $314.95, with the $40 mail in rebate, and free shipping.
Gerhard
Gerhard
Peter & Judy
City/Region: Olds
State or Province: AB
Vessel Name: Mistaya
Photos: Mistaya
PostPosted: Tue Aug 28, 2018 10:43 am    Post subject: Reply with quote
I have recently upgraded the original Raymarine VHF radio on my boat to a Standard Horizon GX2200. The Raymarine was still in very good condition, but was programmed with a US MMSI number. I wanted to change to may new Canadian MMSI number, which would require me to ship the radio to Raymarine in the US. I contacted Raymarine and they no longer supported repairs on this radio, but said they might be able to upgrade the MMSI number, but they needed me to send the radio to them in the US to know for sure. I debated this option and considered the cost. I then decided to invest the money in a new VHF. I chose the GX2200 because of many features, I like the built in GPS, the AIS might come in handy someday, I installed a loud hailer and fog horn. Mostly I did so because of the DSC features and the safety aspects incorporated in this radio. I also own a pair of Standard Horizon HX870 VHF radios which we bought for use when we sea kayak. These too have DSC, built in GPS and have their own MMSI numbers programmed into them. I have not used the GX2200 much beyond testing yet.
I did leave the old Raymarine VHF installed in the boat, I have yet to attach an antenna to it. I plan to use the GX2200 as my main emergency radio on Channel 16. The Raymarine will be my backup radio and allow me to monitor other channels as needed.
Peter & Judy Haase
Buffalo Horn Ranch
HMCB Mistaya
Pedromo
City/Region: Oxnard
Vessel Name: C-Casa
Photos: C-Casa
PostPosted: Tue Aug 28, 2018 11:52 am    Post subject: Reply with quote
I have the Icom. Very happy with it, functionally as well as ergonomically.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Tue Aug 28, 2018 12:29 pm    Post subject: Reply with quote
I have the GX2200 and the HX870 handheld, both of which seem to have more features than I need. Because they have many more features than buttons, it takes a while for "simple" choices to become routine. Often by the next time I want to use a feature I've forgotten how to do it. Probably more a commentary on me than on the radios.
One thing I learned on our recent trip about the HX870 that I didn't like was the volume control. We could drop a person on shore with the HH and then communicate (i.e., "come get me"). I know, there's a protocol for VHF transmissions while ashore, but the ship-to-ship channel is generally open in Kyuquot because the only ship that visits comes in on Thursdays once a week. Anyway, I learned that the volume on the handheld can be turned so low as to be turned off. Maybe there is a good reason for this, but an audio safety device that can be turned on for transmission but the reception not heard could be a problem.
We comparison tested the reception of the two radios. Because of the taller antenna on the GX2200, it got better reception (and presumably, transmission). Sometimes we could hear both sides of the conversation on the GX2200 and only one side on the handheld. But if I stood on the gunnel so that the HH antenna was closer in height to the deck-mounted antenna, the difference disappeared. Strange to think that there could be a one or two mile difference between using the HH while sitting at the helm and standing next to the helm. Same would be true of using the HH ashore. Climb a tree or something if you need the signal to carry.
Mark
PostPosted: Tue Aug 28, 2018 1:05 pm    Post subject: Reply with quote
Mark, Part of the reason for the Tx and Rx difference is in the antenna length, not just the height. So when comparing, even if both the 2200 and the HH are set at 1 watt, the fixed mount with the longer, stronger antenna will win out.
As to the volume control. One of the features on the HH is the "button lock. That keeps everything set the way I want it, and is especially useful when I have the HH clipped to my PFD. I set the channel I want to use, the volume to loud enough to cover ambient sound, and the squelch to just at the break point and then lock the buttons. Hope that helps.
On my Standard Horizon, my 2150 is the same radio as the 2200 but does not have an internal GPS. The LCD screen smaller than the ICOM, and the menu is more complicated to work your way around in, except for the DSC call to a listed MMSI from the AIS screen. It is a 2 button push from the AIS screen. I rarely use that feature but when I do need to call another vessel that way, I do use the SH2150. (I have AIS out put from both the ICOM and SH vhf's to my chartplotter, so most of my AIS monitoring is cone on the plotter.
Peter and Judy, Good choice to leave the first radio in the boat. I would add the second antenna, but that is my choice, you may or may not. It not, you can use a VHF splitter, and put both radios onto one antenna. That will work as you are only going to be transmitting off one radio at a time BUT adding a separate mount and antenna will increase longevity and functionality of both radios. Until you have more than one radio on at a time you will never know how much you are missing even with using a scan feature. (That is one of the main reasons I have the ICOM M-506 for monitoring 16 exclusively.)
PostPosted: Tue Aug 28, 2018 1:52 pm    Post subject: Reply with quote
JMacLeod, something else to keep in mind in your shopping. West Marine now has a price matching policy. Find what you can and then take it to them. They (at least here in my local story 40 miles away) are pretty good to work with.)
There is something else, you may want to consider. Of the VHF's that you mentioned, they are capable of an Auto Fog/Hailer function. It is relatively simple to add a good speaker to give you those functions. In my area, the auto fog horn is invaluable. BUT, I use the hailer function more.... Whoa there don't get ahead of me... doesn't mean I am talking on it at all. It also has a "listen back" feature when in hailer mode, working as a big microphone, so when entering a marina, or crowded anchorage, I turn that on, and can listen to the ambient noise, like if someone is yelling at me that I am screwing up, and "don't go there" etc. I have even, on occasion, heard the "Cute little boat" comments that way. Cool That was worth the $40 for the speaker:lol:
PostPosted: Tue Aug 28, 2018 2:10 pm    Post subject: Reply with quote
There are a few places where you may miss some important transmission, with one radio, even on scan or triplex function. For that reason I have two fixed mount VHF radios--one always on Ch. 16, the other on working channel--tug and tow along the ICW, but it might be a scan with tug and tow, vessel separation scheme, traffic control in a harbor or other C Brats.
I have the Standard Horizon 2200, and a slightly older Standard Horizon. I also have several hand held--the primary being the Standard Horizon HX 870. I have a west Marine simple VHF with both rechargeable as well as a AA battery tray in the ditch bag. I carry a dozen AA, ( strobe, flashlight, and hand held GPS all use AA batteries) The HX 870 uses AAA. I have two hand held, with base charger at the helm. One for each of us to go on our life jacket along with PLB. if we are offshore in rough weather.
I do hook up the hailer--the fog functions alone are worth it.
If you are contemplating the transceiver (Garmin 600) then get the MMSI from the FCC--since you cannot use the Sea Tow/Boat US number in a transmitter, or out of the territorial US waters (although many do use them in Canada)...
I added one other feature--mostly because I had a RAM mike I had bought several years ago--and put the remote mike where it can be easily accessed from my bunk, (the entire port bulkhead is cut out, like in the Tom Cat), or by the person riding in the passenger's seat. I figured that was an additional safety function--or i can get the weather report./ safety function at any time of the night, without leaving the bunk.....(Lazy in my old age)
Finally antennas--buy the best you can. I went with the Morad VHF on the 25. It out performs the Shakesphere Galaxy. It is a relatively shot antenna with a 6 Db gain, and a whip.(which I prefer over the fiberglass tube, with a wire antenna inside. As I noted, in a PM, I like VHF antennas which have a sold body (metal extension or like the Morad, and the whip on top--these cannot be broken by someone grabbing them! You will find Morad on Law enforcement, commercial and military vessels; they are rugged and dependable. Our 4' antenna is mounted on the top of the Radar arch, so it is up higher than an 8' antenna mounted on the deck would be. (you would get a mile or two more range with an 8 foot on the Radar arch.) Antennas can make a significant difference in distance of both reception, and transmissions. Also the "clamp on" PL 259 fittings (antenna feed to the radio) often are a source of decreased function. Better is soldered (only if you do it properly--I did a tutorial about 10 years ago on that). also the MINI vhf connector which will pass thru the tubes and any fittings the co-ax will. (Digital Antennas also have the mini connectors).
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Tue Aug 28, 2018 3:04 pm    Post subject: Reply with quote
I went with a little smaller and less expensive hailer/listener than the official Standard Horizon accessory speaker. It appears to be the same manufacturer, just sold under the maker's name (Pyle) instead of SH. Works fine and tucks up under my cabin overhang better. I offset it to port behind the windshield pillar, so I can't really see it from the helm.
https://www.amazon.com/gp/product/B002UL0WEQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
So far I have used it to listen to gulls feeding on a distant bait ball and otters cracking open clams. Probably not its intended purpose, but fun. Now when I'm in the fog I can yell "help, I'm lost!" at two minute intervals.
Mark
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Aug 28, 2018 5:41 pm    Post subject: Reply with quote
I recently bought an Uniden radio with DSC, It is very compact and mounted overhead. It was $100 and not high end but I like the display better and
to replace a 15+ years SH unit. The unit has tri scan and DSC, and suits our needs for fishing. Our handheld is SH unit but the generation before the new one with better display. I keep it by the helm and as a second radio and agree with Bob. I keep the AA battery pack in the ditch bag. Antenna is Shakespeare XT Galaxy 8 feet and roof mounted. Digital antennas are easy to install.
The gold factory-attached mini-UHF female connector with PL-259 (UHF) adapter makes connecting to the radio easy, eliminating the need to solder connectors
Shakespeare requires soldering the connector or their no solder connector. see https://www.amazon.com/Shakespeare-PL-259-CP-G-Marine-Center-Connector/dp/B000K2IGPE
From Amazon
Uniden UM415 Advanced Fixed Mount VHF Marine Radio DSC (Digital Selective Calling). All USA/International/Canadian Marine Channels. 1 Watt/25 Watt Transmit Power. Ultra Compact Rugged Construction and JIS7
Brent Barrett
PostPosted: Tue Aug 28, 2018 6:00 pm    Post subject: Reply with quote
... I like VHF antennas which have a sold body (metal extension or like the Morad, and the whip on top--these cannot be broken by someone grabbing them! ...
I have a Shakespeare antenna that has the 6' fiberglass extension and a whip. Last time we were retrieving the boat, while I was getting the trailer, the boat started to get away from my wife. Without thinking she grabbed the antenna body and pulled. The antenna was already folded down for transport. Anyway, she pulled the boat back to the dock. After she told what happened I figured it was time for a new antenna. However, when I looked at it, the fiberglass antenna body was not affected by the pulling, but the stainless steel antenna mount was bent. There was also no damage to the cabin roof where the mount attaches either. I was pretty surprised that the weak point of the antenna assembly was the part that I expected to actually be the strongest.
PostPosted: Tue Aug 28, 2018 6:17 pm    Post subject: Reply with quote
If she got it by the extension, that is pretty strong. I am also surprised that the mount bent--but they are not all equal...
JMacLeod
City/Region: Stuart
C-Dory Year: 2018
Photos: JMacLeod
PostPosted: Tue Aug 28, 2018 7:29 pm    Post subject: Reply with quote
I was actually asking about a dedicated AIS transceiver like the Garmin AIS-600 ($1000) or the Em-Trak B100 ($500), but thanks for all the extra info.
Icom owes you a commission. I think you've sold me.
hook up the hailer
Cheers. Will do.
I imagine a couple of handhelds could be used the same way in a charging cradle at the helm and could be connected to an external antenna for better reception?
If I went the two radio route like Bob that would probably be a good choice for an inexpensive backup.
Thanks. I saw that a Restricted Radiotelephone Operator Permit is also required if using the VHF in a foreign port.
I'm on the FCC site looking over the forms.
If necessity is the mother of invention, laziness must be it's father.
I plan to mount the antennas on the arch.
Digital gets hyped a lot in threads on the other forum, but I'll look into the Morad now as well.
Page 1 of 3
Page generation time: 0.0759s (PHP: 75% - SQL: 25%) - SQL queries: 28 - GZIP disabled - Debug on
