Fuel lines
Kingmann
City/Region: Kettle Falls
Vessel Name: Eva
Photos: Eva
PostPosted: Thu Aug 16, 2018 4:45 pm    Post subject: Fuel lines Reply with quote
I am still getting to know this 22’ Cdory, got it used last fall. Year 2000. I have two built-in gas tanks that have not been used for years. I replaced the fuel filter and line to motor with a primer bulb. I am unable to draw fuel to the motor using the bulb. Maybe not enough suction power? Also not sure about the lever that directs flow from either tank. It seems like a priming issue, not sure. Any input welcome.
Love the northwest
alainP
City/Region: TUCSON
C-Dory Year: 2011
Vessel Name: deja la
PostPosted: Thu Aug 16, 2018 5:14 pm    Post subject: Reply with quote
Did you fill the new filter with gas before installing? Are you holding the bulb vertical while squeezing?
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Thu Aug 16, 2018 5:58 pm    Post subject: Reply with quote
Kingman,
This may be a non issue, but check to ensure that the fuel valve, mounter on the transom is not in the off position.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Thu Aug 16, 2018 7:10 pm    Post subject: Reply with quote
I have found that on some boats the fuel valve plate (Port Starboard and off) is mislabeled, or the lines are not hooked up properly.
It is also possible that the 2000 fuel lines were not alcohol (Ethanol) resistant, and the inner lining has deteriorated blocking the fuel line.
Certainly AlainP's advice about filling the fuel filter is a big help. Also be sure that there is no teflon tape wrapped so it blocks the fuel flow.
I probably would start the motor by using an external fuel tank.--you should be able to prime the engine from a 2 gallon fuel can to start with.
Be sure that the arrow on the bulb is pointed the correct direction. Try priming with the small fuel can. See if the bulb is developing suction--it is possible that you have a defective bulb. The bulb will pull fuel up from far greater depths and distances than the 22's tanks.
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Fri Aug 17, 2018 2:59 am    Post subject: fuel lones Reply with quote
Make sure that the fuel line and bulb are going in the correct direction.
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Aug 17, 2018 10:03 am    Post subject: Reply with quote
I would clean the tank and replace the fuel pickup tubes, fuel and vent hoses, and if ASV are present, clean them out.
Brent Barrett
Pedromo
City/Region: Oxnard
Vessel Name: C-Casa
Photos: C-Casa
PostPosted: Fri Aug 17, 2018 1:46 pm    Post subject: Reply with quote
Sometimes you’ll find a check valve in the elbow at the top of the pickup tube on top of the tanks. . These valves have a tendency to freeze, because they c9mbine aluminum with a stainless steel ball. I suggest replacing the elbow.
Page generation time: 0.1412s (PHP: 81% - SQL: 19%) - SQL queries: 24 - GZIP disabled - Debug on
