Alasgun Guest
Posted: Sun Nov 13, 2005 10:25 pm Post subject: Fuel for the Wallas |
It seems like the general population prefers Kleen Heat for the Wallas. Has any one tried pure liquid paraffin? (lamp oil) Thats all, just looking for input. The new guy (Alasgun) Mike on Huda Thunkit. |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2375 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Sun Nov 13, 2005 11:03 pm Post subject: |
I haven't used it. I have used kerosene in my 22 and now my 25 with no problems. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Joined: 23 Oct 2003 Posts: 5315 City/Region: Warrenton
Posted: Sun Nov 13, 2005 11:23 pm Post subject: Re: Fuel for the Wallas |
Alasgun wrote: | It seems like the general population prefers Kleen Heat for the Wallas. Has any one tried pure liquid paraffin? (lamp oil) |
I think the Kleen Heat guys are just more vocal than the majority. The stuff obviously works very well for them. Me, I tried it once and had a flame out and smoke filled boat. Now I am sure that it was not caused by the fuel, but being the superstitious sort, I went right back to K1 kerosene. It works great every time all the time.
Paraffin works well, I am told, unless the fuel itself gets cold. It will gel up something awful if it gets close to freezing. I do have a jug of it that a friend gave me, but when I got around to wanting to try it, the stuff was cold and just a blob in the jug.
Until the Kleen Heat gets cheaper than kerosene (which could happen because it is synthetic and not oil), I will be sticking with the kerosene.
I have nothing against the KH, but I have never been one to want to improve upon perfection. K1 gives off a slight odor when it first ignites, but it only lasts for about a minute. The KH has a startup smell too, and although it is not quite as noticeable as the K1, I find the K1 smell to be more pleasant. There, I said it. I like the smell of diesel exhaust, too. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
CatyMae n Steve
Joined: 18 Jun 2005 Posts: 838 City/Region: Jefferson, OR
Vessel Name: CatyMae
Photos: CatyMae
Posted: Mon Nov 14, 2005 12:10 am Post subject: |
Mike, I think you're right about the Kleen Heat folks being very verbal on the site. I was totally sold on using it before we got the boat....but when we picked up the boat, I asked the dealer about using it, and he said I needed to call the manufacturer to find out if we could use it instead of diesel. We were given half a fill of diesel with the boat, and have used it several times, for cooking and for heating. There is no smell, there is no black sooty material inside nor outside, and we'll continue to burn diesel as long as it doesn't go to $100/gallon |
flagold
Joined: 23 Mar 2004 Posts: 951 City/Region: Abbeville
State or Province: AL
Vessel Name: C-Dawg-E
Posted: Mon Nov 14, 2005 9:05 am Post subject: |
When I sent mine in I went through the fuel options with Karl (Scan Marine) and was told the fuel pump, etc., was designed to run and be lubricated with diesel. "Run just the diesel" he says. Also recomended to dump the diesel if not using it right away (keep it fresh or don't use it).
My stove always had a smell on startup and a bit of white smoke would come from under the counter and in taking it out I learned there was a pinhole leak in the foil exhaust tube right at the Wallas exhaust pipe where the clamp was. When it goes back in I'll use foil muffler tape (AKA heater tape) on the whole exhaust joint area and another where the exhaust exits the hull. |
Posted: Mon Nov 14, 2005 9:50 pm Post subject: |
Maybe this is a case where I was better off not knowing the general consensus. I've ALWAYS run just plain diesel. I use the boat at least once a month all year long (usually 2-4 times/month) and have never had a problem. My sense from seeing about 2 years of posts on the Wallace is that there seems to be a correlation between problems and the use of fuels other than diesel but I must admit this is simply anecdotal and is affected by the bias in fuel use (e.g. more brats seem to use kleen heat so if the problems are independent of fuel type, it might just be that the "correlation" of problems with Kleen Heat is not real). Just my 2 cent's worth but diesel has always been fine for me (going on 3 years now) and it readily available at gas stations and marine fuel docks.
Roger on the SeaDNA _________________ Roger on Meant to be |
Byrdman
Joined: 06 Nov 2003 Posts: 3320 City/Region: Cumberland River, Clarksville,
Photos: FreeByrd and C-Byrd
Posted: Mon Nov 14, 2005 10:27 pm Post subject: |
Thanks guys for getting Karl's name back up on here. I'll be going to LAX on Dec28 and will pack my wallas for a trip back to the west coast. Had the little "slip nut" .....slip down...and back up and back down causing air/exhaust flow issues... so Karl asked me to prior to taking her out and shipping back cross country....to try supper glueing the little "slipping-nut" in the up position....but not to far up....as that is a problem too. Well, I got a 70% solution...and have been "limping" aloung... Things I found. It is real hard to super glue up and against gravity...and that simple open new tube with pin-hole and sqeeze real hard caused a "blob" to form on one side....sort of like a drive shaft being a bit out of balance.....a bit noisey...and I either have her too high or too low....cause she will not run real long, real smooth on the lowest setting.....which is a great spot for overnight sleeping in the cooler southern nights... and of course great for slow cooking stews/soups n stuff.... So
Would someone please email me Karl's phone number... I left it on the boat....under the cabinet, next to the wallas. I want to let him and his folks know I will be bringing her back for a visit.
Byrdman on FreeByrd |
flagold
Posted: Mon Nov 14, 2005 11:00 pm Post subject: |
(206) 285-3675 |
Otter-BelleHavenMarina
Joined: 03 Nov 2003 Posts: 390 City/Region: Alexandria
Vessel Name: Otter
Photos: Otter
Posted: Tue Nov 15, 2005 8:45 am Post subject: |
Five years using diesel, no problems. Never tried anything else. _________________ Tom on Otter |
Posted: Tue Nov 15, 2005 10:00 am Post subject: |
This would be a good one to have a poll on. Three questions:
1) Have you ever had problems with your Wallace heater?
2) What fuel do you use?
3) Did the problem occurr immediately after more than a month of non-use?
That might provide enough data to get a better sense if fuel choice is related to problems.
Roger on the SeaDNA |
Da Nag
Joined: 24 Oct 2003 Posts: 2828 City/Region: Port Angeles
Vessel Name: Wilbur
Photos: Da Boats
Posted: Tue Nov 15, 2005 10:33 am Post subject: |
As one of the KH fanatics, I stick with it for a pretty simple reason - in liquid form, it's odorless.
Last thing I want to smell in my cabin is diesel fuel, and being the klutz I am, I'd eventually spill some while filling/installing the tank. Getting rid of diesel smell is not easy... _________________ Will, C-Brat Nerd |
dogon dory
Vessel Name: DogOnDory
Posted: Sat Mar 18, 2006 3:44 pm Post subject: Re: Fuel for the Wallas |
stevej
Vessel Name: Shearwater
Photos: Shearwater
Posted: Sat Mar 18, 2006 7:41 pm Post subject: |
My wallas is almost 11 years old and gets lots of hours per year.
Had it overhauled two years ago (bad fan) other than that no problems.
Twist the knob hit the switch and it always starts
It's a kerosene only model so I use kerosene
99% of the time it's on high with the lid down in heater mode
stevej _________________ 1995 25' Cruise Ship #3 |
Posted: Sat Mar 18, 2006 8:28 pm Post subject: |
DoD -
I can't believe it!! An oil industry guy using phony stuff?? That's like me using plastic toilet paper. I just hope your fuel choice doesn't chap you in the same place the plastic TP would me. |
Dora~Jean
Joined: 09 Mar 2004 Posts: 1507 City/Region: Simi Valley
Vessel Name: Dora~Jean
Photos: Dora~Jean
Posted: Sat Mar 18, 2006 9:23 pm Post subject: |
I've checked every Home Depot around here in So Cal (about 4), none have Klean Heat and never heard of it, some have Kerosene (not 1-K). Is this product stocked on "northern" shelves only?
Steve |
