Depth Sounder - Cored Hull
DW
City/Region: Mount Vernon
Vessel Name: Wicked Pissah
PostPosted: Fri Jun 29, 2018 11:38 pm    Post subject: Depth Sounder - Cored Hull Reply with quote
Can anyone verify that on a C22 the hull is or is not cored? I'm installing a depth sounder soon and need to know if there is solid fiberglass at the keel area or cored?
Thank you
CaptainJeff
City/Region: Olympia
Vessel Name: HAWSEPIPER
Photos: HAWSEPIPER
PostPosted: Sat Jun 30, 2018 10:57 am    Post subject: Reply with quote
I have a 2004 and the entire rear deck is cored. I installed a shoot through the hull transducer just forward of the depression by the drain (where the bilge pump usually sits). Pictures of the installation can be seen in my album.
http://www.c-brats.com/modules.php?set_albumName=Shoot-Through-the-Hull-Transducer-Installation&op=modload&name=gallery&file=index&include=view_album.php
Respectfully,
Jeff
HAWSEPIPER
san juanderer
City/Region: Stanwood
C-Dory Year: 1990
PostPosted: Sat Jun 30, 2018 12:17 pm    Post subject: Reply with quote
Don't you hate it that the boat builder would penetrate the core, but not seal it properly ! Such a shame.
Cdory 22 Angler
SeaSport 24XL, Etec 250 hp (sold)
Rosborough RF246 (sold)
Commander 30 Sportfish (sold)
Olympic 26 XL (sold)
Glassply 19 (sold)
Olympic 23 (sold)
Bayliner 38 Motoryacht (sold)
Olympic 20 (sold)
Fiberform 16 (sold)
Olympic 18 (sold)
PostPosted: Sat Jun 30, 2018 12:26 pm    Post subject: Reply with quote
Capt Jeff,
Nice job and well documented.
The hull is cored up to the bulkhead between the V berths and the main cabin. There is a depression, in some of the boats just inside the cabin, aft bulkhead, where a bilge pump is installed. Some of the boats have partial core still under this area You can cut the inner layer of the bottom, and remove the core--and then re-inforce that part, with extra layers of glass and resin. I personally prefer epoxy, because it has better secondary bonding strength than Polyester. Some use vinyl ester which has strength between the epoxy and polyester.
If you want to test areas, put the transducer (a transom mount can be used) in a plastic baggie of water or mineral oil, and lay it on the bottom of the boat. If it is cored there will be no or very minimal transmission of the impulses, and you will not get a usable sonar image.
For non cored hulls, I have made a plywood and epoxy/fiberglass cloth box inside the hull, put the thru hull transducer into the lid, with a port to fill the box which is glassed to the hull. Then I fill the "bottomless box" with mineral oil. Had good echos thru 3/4" solid glass to over 600 feet.
Page generation time: 0.0436s (PHP: 44% - SQL: 56%) - SQL queries: 17 - GZIP disabled - Debug on
