towing with the 3.5l v6
rbfconstruction
City/Region: huntington beach
Photos: Angler Management
PostPosted: Fri Jun 15, 2018 10:58 pm    Post subject: towing with the 3.5l v6 Reply with quote
Hi, Does anyone have the 3.5l v6 (ti-vct) ? I am looking to buy a 2017 f150 but everyone is telling me to get the 2.7 eco boost. I tow my 19 foot angler. local mostly, maybe 100 mile trip once a year.
Thanks, I don't want to make a wrong purchase.
Richard
shaferc
City/Region: Bermuda Dunes
PostPosted: Fri Jun 15, 2018 11:37 pm    Post subject: Reply with quote
Richard, I tow my Dory 22 with a 2017 F150 with the 3.5 Ecoboost. I have been very impressed even on a steep grade it has plenty of power.
Kestrel
jennykatz
City/Region: naples
Vessel Name: Jennykatz
Photos: Jennykatz
PostPosted: Sat Jun 16, 2018 6:53 am    Post subject: ford ecoboost Reply with quote
We belong to the Escape forum trailer group also and some of them have traded in their 3.5 for the 2.7 to get a little more mpg about 2-3 mpg all around .They tow 21 ft campers that weigh 4000-4500 lb more then a cd 19 angler for sure . I was looking at Expedition with a 3.5 plenty of power thats for sure .I don't think you can go wrong either way .maybe if you might get a cd 25 then maybe the 3.5 but otherwise save some money and get better mpg .
rbfconstruction
PostPosted: Sat Jun 16, 2018 10:06 am    Post subject: towing with the 3.5l v6 Reply with quote
Hi and Thx. I need to clarify, This is a used truck with the 3.5 but not the eco boost. They do have a 2.7 and a 3.5 eco boost, as well as a 5.0 ti-vct
I do probably need to pass and hold out for the 2,7 eco boost then.
thx Richard
Ordutch1975
City/Region: Portland
C-Dory Year: 2018
Vessel Name: PennyBridge
Photos: PennyBridge
PostPosted: Sat Jun 16, 2018 8:21 pm    Post subject: Reply with quote
What year ?
"And it is an interesting biological fact that all of us have, in our veins the exact same percentage of salt in our blood that exists in the ocean, and, therefore, we have salt in our blood, in our sweat, in our tears. We are tied to the ocean. And when we go back to the sea, whether it is to sail or to watch it, we are going back from whence we came. " -JFK
rbfconstruction
PostPosted: Sun Jun 17, 2018 4:59 pm    Post subject: towing with the 3.5l v6 Reply with quote
2017 crew cab xlt. Lots available with the 3.5 (not eco boost) for less then 30 with around 15 to 20k miles on them
Ordutch1975
C-Dory Year: 2018
Photos: PennyBridge
PostPosted: Sun Jun 17, 2018 9:25 pm    Post subject: Reply with quote
You should be fine 7600lbs with 1910 payload. I can't imagine the 19 angler weight over 5K and payload due to aluminum bed is awesome on the new fords.
https://www.ford.com/resources/ford/general/pdf/towingguides/17RV&TT_Ford_F150_Sep7.pdf
ShaunHicks
City/Region: West Allis WI 53214
PostPosted: Wed Jul 10, 2019 9:32 am    Post subject: Reply with quote
Turbocharging. One hallmark of Ford EcoBoost is its engines are turbocharged. Turbocharged engines use a device that forces in more air than a normal engine would receive. ... That's different from simply enlarging an engine, which requires more fuel and hurts mileage.
__________________
tow truck near me
TOGO
City/Region: Newport
C-Dory Model: 19 Angler
Vessel Name: TOGO
Photos: TOGO
PostPosted: Wed Jul 10, 2019 4:29 pm    Post subject: Reply with quote
I have had 3 different full size Ford trucks.
2000 F250 7.3 diesel With Banks the best hauling truck I have ever had about 16 mpg towing a 24 foot travel trailer. 21-23 unloaded.
2013 F150 with the 3.5 ecoboost towing a C-Dory 19 about 14 MPG a travel trailer about it dropped to between 10 and 12. Without load just under 20 mph. Speed usually about 60mph.
2018 F150 3.5 ecoboost Did not tow the dory but the same travel trailer it got about 12 to 14 mpg. Without load between 22 and 23 mpg. The mileage starts from my driveway which is a 9.5% grade for a mile to the state road.
Mileage Is effected effected by frontal area. I used to tow a utility trailer loaded to about 3500 pounds behind the F250 did not notice the change in the mileage. The trailer fit in to the airstream of the truck.
About the turbo charging on the 2013 F150 the turbo did not effect the performance much until about 2500 rpm then it kicked in.
The 2018 is a dual turbo this kicks in at a low rpm.
The advantage of turbo over a larger displacement engine is that the turbo adds little to the perceived displacement until you request more power. Then it forces more air into the cylinders.
Please understand that I spell truck "FORD"
Guy
Micahbigsur@msn.com
City/Region: Big Sur
Vessel Name: Sierra
Photos: Sierra
PostPosted: Thu Jul 11, 2019 10:31 am    Post subject: Reply with quote
There is no free lunch , turbos add stress and complexity compared to low stress larger displacement so long term maintenance costs may be higher.
Look at the tow rating of both trucks, sounds like both are more than adequate. Higher tow ratings usually means bigger, better brakes and more safety, a priority for me, my truck (3500 16' Ram diesel) is overkill for our CD25, but is very low stress on long downgrades.
Micah Curtis and Dana, RN
+ many more going back to my first boat a little trailerable Piver trimaran in 1969.
Micah, KJ6GUF, Dana, KJ6GXG
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Thu Jul 11, 2019 9:01 pm    Post subject: f150 Reply with quote
I towed a CD22 from Louisiana to Lake Powell with a V6 F150. I topped one hill in second gear. That was a C22. I can't imagine you would have a problem pulling your boat, but if you move up to a CD22 or CD25 do you really want to have to buy a new truck? JUST A THOUGHT.
Chester
City/Region: home
Vessel Name: Chester
PostPosted: Thu Jul 11, 2019 10:40 pm    Post subject: Reply with quote
The naturally aspirated 3.5 will be OK for your short hauls, assuming of course, the rig is rated for the trailer weight.
That motor will likely turn some higher RPMs but that's OK too.
Could you arrange a test drive towing your boat?
Post new topic   Reply to topic    The C-Brats Forum Index -> Trailers and Towing All times are GMT - 6 Hours
Page generation time: 0.0823s (PHP: 50% - SQL: 50%) - SQL queries: 29 - GZIP disabled - Debug on
