eu1000 honda generator problem
anchorout
City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
PostPosted: Wed Jun 13, 2018 1:10 am    Post subject: eu1000 honda generator problem Reply with quote
Just spent 3 days on the boat, running my relatively new Honda EU1000 generator. Today I try to start it to heat the oil for an oil change and it won't start. New spark plug fires when grounded to engine. New gas, and the carb is clean inside. Finger over the spark plug hole shows good compression. Starter fluid squirted down the carb does nothing. I have fuel, compression, and spark but not a hint of it trying to start. Anyone out there have any ideas?
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Wed Jun 13, 2018 6:43 am    Post subject: Reply with quote
Reset the breakers, open the fuel tank vent, and check the oil level.
2003 CD22 Cruiser with Honda 90
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Wed Jun 13, 2018 7:25 am    Post subject: Reply with quote
I had a similar problem with my new EU2000i last year. Like Almas said, make sure the vent on the fuel cap is open!
I went crazy last year thinking I had a clogged carb or something because my generator would only run for a minute or two then shut off. Come to find out I had the fuel vent closed!!!!!!!!!
<><><> Jason <><><>
jack keifer
City/Region: Boise
State or Province: ID
Vessel Name: C-Squirt
Photos: C-Squirt
PostPosted: Thu Jun 14, 2018 12:30 pm    Post subject: Eu 1000 problem Reply with quote
If the problem is not the fuel vent, double check the oil level. It does not have to be down very much to not start or also shut down.
Jack
Previously 22 cruiser "Loafer's Paradise"
Now 16 cruiser "C-Squirt"
PostPosted: Thu Jun 14, 2018 12:51 pm    Post subject: Reply with quote
The most common problem is dirt or debris in the carburetor jets. Even though it ran last week, it is possible that you got a small piece of debris into one of the jets. After the diagnostic tour, and being sure that everything is set properly (the newest 2200 have a fuel shut off valve also, so another thing to check.), I pull the carb, put some cleaner into it and the jets, then blow out with compressed air after sitting for a few minutes.
One would think it would fire with the squirt of ether--but the fuel air mixture has to be close to optimal; too much or too little may not fire.
Foggy
C-Dory Year: 2014
Photos: W B Nod
PostPosted: Thu Jun 14, 2018 3:43 pm    Post subject: Reply with quote
Trouble shooting a combustion engine involves inspection/evaluation of the
four phases common to all:
"SUCK" (air intake) clean air filter? debris?
"SQUEEZE" (compression) clean spark plug?
"BANG" (ignition) Gas/ignition valve turned on? fresh uncontaminated fuel?
"BLOW" (exhaust) blockage?
Add generous curse words and a stiff kick or two and your problem will most
likely abate.
Aye.
Grandpa used to say, "Everything made by man will fail, sooner or later."
"I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life.
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Thu Jun 14, 2018 6:35 pm    Post subject: Reply with quote
That "debris" may not be recognized as such at first glance. A Honda I had used for years would not start one day. After much hair pulling I discovered that the air filter had become saturated with oil(forget how that happened). It looked clean but the oil that had saturated the paper would not allow air to pass through it. Got a new filter and it ran for many more years.
Regards,
Rob
anchorout
Photos: EZ DUZIT
PostPosted: Thu Jun 14, 2018 11:55 pm    Post subject: eu1000 honda generator problem Reply with quote
Thanks guys. I'll give them all a try and let you know the results.
Page generation time: 0.1142s (PHP: 88% - SQL: 12%) - SQL queries: 25 - GZIP disabled - Debug on
