Brattytoo
Avidmagnum12
Joined: 23 Mar 2013 Posts: 668 City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
Posted: Wed May 23, 2018 8:39 pm Post subject: |
Drain for anchor rode locker. _________________ Tom and Joyce Schulke
2004 CD 22 Commuter "Out2C" 03/10 to 06/15 |
Brattytoo
Posted: Wed May 23, 2018 10:36 pm Post subject: |
oh thank you, is that a common way to fix the anchor locker leak? |
Posted: Wed May 23, 2018 10:42 pm Post subject: |
If any water gets in thru the deck pipe or a windlass, it should drain out thru the bottom of the anchor locker. Most are on the port side, but it makes no difference.
There is no "leak" unless some one forgot to seal off the area between the anchor locker and under bunk--and water can then be trapped there, if it does not drain out the bottom of the locker. Some boats have to have the floor of the anchor locker faired and sealed so the water can drain properly _________________ Bob Austin
Brattytoo
Posted: Wed May 23, 2018 10:54 pm Post subject: |
Great explanation! I wish I could have been the new owner of Thisaway, but sounds like she found a good home. Congrats on your new boat. |
