Sdcotten
Vessel Name: C-Sprite
Posted: Tue May 15, 2018 8:55 pm Post subject: New c-dory 16 owner |
We are just joining the C-Dory family with the purchase of a 2006 16 Cruiser. I'm excited about adding a depth finder and other tech things but my wife wants to know what others have done for v-berth sheets? Are these just a make your own scenario, or are there actually v-berth sheets available? |
Posted: Tue May 15, 2018 11:23 pm Post subject: |
There are V berth sheets available, but they are expensive. I would suggest cutting down standard or maybe queen--not sure which for the 16. You can take fitted bottom sheets, and place them around the "V" berth cushions. Then pin the excess material in a perimeter, cut away the eccess, and then use the sewing machine to make a new seam--and a much cheaper "fitted" sheet. We generally use sleeping bag on the bottom. It if gets real cold, them we go with that on top. On the 22, we were using queen sheets; on the 25, we will use king. We each have a good size fleece, and that with a top sheet is great for most of our boating except in the PNW. _________________ Bob Austin
jack keifer
State or Province: ID
Vessel Name: C-Squirt
Photos: C-Squirt
Posted: Thu May 17, 2018 11:26 pm Post subject: New c-dory 16owner |
We had a 22 and now a 16 for about 5 years. Our solution has always been a couple of lightweight sleeping bags along with a couple of pillows and pillow cases from Walmart. The Captain likes the idea a lot as it keeps the deckhand (I know my place on this vessel) from stealing the sheets. Works well for us because as you know there is not a lot of space on a 16. So in the daytime we just roll up the bags, stuff pillows in a garbage bag, and pile our gear in the cuddy and not worry about dirtying up the bedding. _________________ Jack
Previously 22 cruiser "Loafer's Paradise"
Now 16 cruiser "C-Squirt" |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Sun May 20, 2018 7:12 pm Post subject: |
My present setup is a self-inflating back packing (aka Thermarest) air mattress and a "custom" sleeping bag. When travelling with my wife, we take two air mattresses. I found that the original foam mattress wasn't all that comfortable and took up precious space (being 3 inches thick instead of 3/4 inch thick). My "custom" sleeping bag is an inexpensive Walmart double bed comforter that I put a few snaps on so that it is folded in half. Plenty wide (too much material at the foot) but I don't care. Wide enough for two people. I take a polar fleece blanket if it might get really cold. No sheets required as the comforter fits in the washing machine.
There is an added benefit to using the back packer air mattress. Many people have noted that if the bedding gets up against the hull there can be condensation that gets the bedding wet. That is definitely going to happen in the peak of the 16 V berth. The air mattresses, being "two wide," run up the side of the hull and stop condensation there. Stopping condensation in other areas requires air circulation.
Mark |
jack keifer
Photos: C-Squirt
Posted: Tue May 22, 2018 11:24 pm Post subject: New c-dory 16 owner and Thermarest |
Marco,
If I read your post correctly, you took out C-Dory supplied pad and replaced it with 2 Themarest air mattresses. And the T-rests don’t stop the condensation but just keep it off the sleeping bags, right? We have a couple of T-rests from camping days and could give them a try. |
