Anyone know the length of CD25 from Boweye to transom?
Major Tom
City/Region: Saratoga Springs
State or Province: NY
Photos: Major Tom
PostPosted: Mon Apr 30, 2018 1:49 pm    Post subject: Anyone know the length of CD25 from Boweye to transom? Reply with quote
I'm getting a new trailer for my CD 22, and for just a few dollars more I can get a slightly larger trailer. In case I step up to a 25 down the road, I'm considering it.
But the max length is 23' 7" from boweye to transom. So will a CD25 fit?
One weight, the max net capacity is 6700 lbs., (that's net capacity, not GVWR) and I've found posts here detailing weight so I think I'd be OK there... looks like I could be around 5000 lbs. without gas or water, and for 80% of the 6700 capacity I could be at 5360 so that leaves around 360 for gas/water. I can live with topping off right before launch or moving some gear into the truck if the weight goes much over 5300 lbs.
Tom Whitten
2005 C-Dory 22 Cruiser/90HP Honda
1993 Sea Ray 230 Sundancer (sold)
1987 Checkmate Enticer (sold)
1986 Sea Nymph (sold)
PostPosted: Mon Apr 30, 2018 2:09 pm    Post subject: Reply with quote
One of the best things about the CD22 is it's portability (IMO). So having a trailer is a good thing. When you sell your 22 the new owners might want it on a trailer, so keeping the trailer for your next boat might not be possible. I wouldn't have one without a trailer.
As you note, the payload limitations of your new trailer may not be practical when applied to a CD-25.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Apr 30, 2018 4:45 pm    Post subject: Re: Anyone know the length of CD25 from Boweye to transom? Reply with quote
You would be far closer to reality with a 10,000# "gross rating" on a trailer for a loaded 25 Wink
tsturm
Photos: JMR-TOO
PostPosted: Mon Apr 30, 2018 5:13 pm    Post subject: Re: Anyone know the length of CD25 from Boweye to transom? Reply with quote
& to answer the question 23' + or- bow eye to transom Mr. Green
jkswor
City/Region: tok
Vessel Name: Missy marie
PostPosted: Mon Apr 30, 2018 7:25 pm    Post subject: Reply with quote
That is BS. I have one. It is 25ft 5 in front to back not counting motors and anchor
Avidmagnum12
City/Region: Ocklawaha
C-Dory Year: 2011
Vessel Name: C-Otter
Photos: C-Otter
PostPosted: Mon Apr 30, 2018 7:52 pm    Post subject: Reply with quote
Bow eye to Transom on my CD-25 is 23 feet more or less......no BS.
Just went out to measure it.
Let’s be nice. 😇
Tom and Joyce Schulke
tsturm
Photos: JMR-TOO
PostPosted: Mon Apr 30, 2018 8:29 pm    Post subject: Reply with quote
Learn to read & comprehend in Tok? Mr. Green
PostPosted: Mon Apr 30, 2018 8:46 pm    Post subject: Reply with quote
I think that 6700 lbs is too light for the C Dory 25. I would be shooting closer to the 8000 to 8500 range. Gas is close to 7# gallon, and the tank is 100 lbs—-that is 700# more. Then water at 8#/ gallon is another 120#. Food, anchors, chain, gear clothes. Most boats are going to be very close or beyond the capacity of the trailer—might be OK, if you just need to go a few miles. But if you want to fully utilize the C Dory capability—you want a more robust trailer.
Major Tom
Photos: Major Tom
PostPosted: Tue May 01, 2018 1:08 pm    Post subject: Reply with quote
Thanks for the replies. And thanks, Bob, I trust your judgement. I'd seen other posts showing it was around 5000 without gas, water, or extraneous gear, but maybe that's not accurate.
I also just discovered that on that 6700 # trailer my CD22 is short of the minimum length by a few inches. So I'm going with the next step down, 6300# Loadrite aluminum tandem, that fits my boat and puts me at about 70% capacity w/out gas or water, and about 75% fully loaded. I'd like to be around 80% but the next step down from there is 5200 #, but 14" wheels, and I'd be at 90% capacity fully loaded.
So the 6300# is the only one with 15" wheels that's closest to my weight capacity target.
FWIW I talked with Owens & Sons, they were great but I just couldn't justify going all the way to FL and back, and trying sell my existing trailer down in FL, etc. And I want to be able to "supervise" the fit... I do a lot of launching, and I'll be putting some serious miles on this so I want the 22 to be perfectly fitted. So I'm going with Loadrite, and there's a great dealer in my area that I trust.
Looking forward to some road/water trips! Very Happy
Major Tom
Photos: Major Tom
PostPosted: Tue May 01, 2018 1:11 pm    Post subject: Re: Anyone know the length of CD25 from Boweye to transom? Reply with quote
Thanks tsturm![/quote]
PostPosted: Tue May 01, 2018 10:38 pm    Post subject: Reply with quote
Uh, why would a C-Dory 25 measure only 23' 7" from boweye to transom? I would make a wild guess that there is 25 feet of boat there. And there have been several threads pointing out that a 25 weighs ~7500# in the water.
Given those thoughts, there's a lot of difference between the 7500 carrying capacity of a trailer that can carry a 25 and the 5000 lb capacity (assumed) of a trailer that can carry a 22. If nothing else the heavier trailers spring rate would hammer that poor 22 a lot. And you're buying more expensive tyres, the brakes are different, etc..
Buy the trailer for what you have, not what you want.
PostPosted: Tue May 01, 2018 10:48 pm    Post subject: Reply with quote
The point of the foredeck is what sounds like 1' 10" farther forward than the bow eye.
PostPosted: Wed May 02, 2018 3:04 am    Post subject: Reply with quote
This is on a 22, but you can see the bow eye is aft of the fore deck point (bow), and though I don't have the measurements it would be proportional on a 25.
tsturm
Photos: JMR-TOO
PostPosted: Wed May 02, 2018 4:04 pm    Post subject: Reply with quote
journey on wrote:
Uh, why would a C-Dory 25 measure only 23' 7" from boweye to transom? I would make a wild guess that there is 25 feet of boat there. Boris
I have never seen a boat that had a "BOW EYE" at the tip of the bow! If the Question had been what is the overall length of a CD 25 There would have been a different answer.
The original question was " LENGTH FROM BOW EYE TO TRANSOM & according to my little yellow rolly up thingy with all the numbers & lines on it the 25' C-Dory in my driveway measures 23' + or - a inch or two.
BOW EYE TO TRANSOM Moon Beer
PostPosted: Thu May 03, 2018 12:10 am    Post subject: Reply with quote
tsturm, you do know that the overall length of a 25 is listed at over 25', maybe 25 1/2?. I'll measure the difference tomorrow and then we'll all be happy
What I'm also saying is that the 25 is longer than the guy is wishing and therre's a lot of difference between the trailers. At one time I changed the 14" tyres on a boat trailer for 15" tyres. With the stiffer sidewalls the boat nearly shook apart.
Page generation time: 0.2038s (PHP: 91% - SQL: 9%) - SQL queries: 33 - GZIP disabled - Debug on
