Drain plug - internal or externala?
skiptowns98033
City/Region: Cornet Bay
Vessel Name: Plan C
PostPosted: Sat Apr 28, 2018 2:13 pm    Post subject: Drain plug - internal or externala? Reply with quote
I have [i]always[/i] put the transom drain plug on the inside of the boat. Until last year, a neighbor and very experienced boater, suggested it go on the outside. That way if anything happens to it, the water pressure will keep in in place.
"Something could hit it and knock it off" was my initial reaction
but I went ahead and put it on the outside of the transom anyway.
I'm glad I did!
Plan C sits in salt water 7 months a year. The metal fittings in the drain plug - one that had been used for 'a while' - had corroded enough the plug just dropped right out when i pulled the boat for the winter.
Saved me this time!
My solution now is to pay close attention to the plug when it's on the trailer and probably get a new one every year or two.
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sat Apr 28, 2018 6:07 pm    Post subject: Reply with quote
I would suggest that if you put the plug in from outside, that you keep a spare plug handy near the transom.
If a stray stick or pot warp pulls the plug from the outside, your spare is handy inside the boat.
Larry H
A C-Brat since Nov 1, 2003
PostPosted: Sat Apr 28, 2018 7:37 pm    Post subject: Reply with quote
As Larry, we keep a couple spare plugs in the boat--one close to the transom. You should be using the ones which are made for salt water, if leaving the boat in the water.
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Sat Apr 28, 2018 8:14 pm    Post subject: Reply with quote
My 16 and 19 had the rubber plugs. My 25 had a screw on bronze type. They were all installed on the outside. I didn't even know putting it on the inside was a possibility.
<><><> Jason <><><>
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sat Apr 28, 2018 9:06 pm    Post subject: Reply with quote
I don't think it really makes a difference what side you put the plug in, as long as you remember to put it in.
All the fishing skiffs I've worked on had the plug inside, so you could pull it and run the water out.
It boils down to what works for you.
Boatless for now but looking
Saxe Point
City/Region: Sooke
PostPosted: Sat Apr 28, 2018 11:31 pm    Post subject: Reply with quote
I don't have a C-Dory yet and my current boat leaves me no internal option as the drain hole is deep in a recessed bilge under the motor well. So outside is the only option.
Because of this I use the stainless steel version of this plug. You can twist it in very tightly. So tightly that I cannot imagine anything pulling it out. The worst that could happen would be that the twist part of the plug would break off, but I don't think that would cause the plug to release.
https://seasense.com/collections/marine-plumbling/products/twist-drain-plug
PostPosted: Sun Apr 29, 2018 12:36 am    Post subject: Reply with quote
I have a brass screw in type plug, from the outside. I also carry a spare expanding type plug that will fit on the inside. Just in case... Colby
jer2
City/Region: Burke
Vessel Name: R&R
Photos: R&R
PostPosted: Sun Apr 29, 2018 11:16 am    Post subject: Transom Plugs Reply with quote
C-Brats-
Just curious, from a 'belt & suspenders' perspective, why not use both an 'inside' & 'outside' plug sort of a 'fail' safe measure (if they will both fit)? Anyway, you'll always know where the 'spare' plug is in the transom!
Just saying...
John Roark
R&R
2008 CD-16C
Upper Potomac River (VA)
Ordutch1975
City/Region: Portland
Vessel Name: Boatless :-(
Photos: PennyBridge
PostPosted: Sun Apr 29, 2018 12:31 pm    Post subject: Reply with quote
30 years ago I had a very small open 13’ fiber glass boat with an outboard I’d take out fishing on a lake - at the time I kept the plug on the inside the beauty of this was that when I got water in the boat I could get on plane remove the plug and it would suck out all the accumulated water. I don’t suggest this on a c-dory lol. My 23 has a screw-in type plug from the outside. I would suggest the exterior inserted plug is the safer option.
"And it is an interesting biological fact that all of us have, in our veins the exact same percentage of salt in our blood that exists in the ocean, and, therefore, we have salt in our blood, in our sweat, in our tears. We are tied to the ocean. And when we go back to the sea, whether it is to sail or to watch it, we are going back from whence we came. " -JFK
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Sun Apr 29, 2018 3:11 pm    Post subject: Reply with quote
I did have a drain assembly years ago that had a cage with a small ball in it. When the boat was in the water the pressure of the water from outside would push the ball in and seal the opening. If you left the boat at the dock and it started to fill up with water from rain, when the water inside the boat was higher than the water line outside the pressure would push the ball out and allow the water pressure to equalize inside and outside the boat. You could also screw a regular bronze plug into it. I guess it was for small cottage boats left in the water without a bilge pump.
Regards, Rob
Page generation time: 0.0446s (PHP: 63% - SQL: 37%) - SQL queries: 27 - GZIP disabled - Debug on
