tsturm
Joined: 01 Nov 2003 Posts: 1172 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Sun Apr 15, 2018 6:15 pm Post subject: Re: LED spot light on bow rail |
Rock-C wrote: | I would like to mount a LED spot light on the bow rail & run the wiring through the railing. Any tips on making the transition from the rail into the v-birth area ? I'm concerned about sealing the deck under the rail plate. |
Here is how I did this project. Polished a piece of 10ga 316L fit & welded it to the bow rail (tig), ran wire on the outside of the rail, made my own cable clam into the V-berth. 1 spot & 1flood can see approx 100' clearly in the Dark of Alaska winters. Can't go fast (5-6 knots) but can travel after dark. No glare
[url][/url] |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Mon Apr 16, 2018 9:50 am Post subject: |
ssobol wrote: | How durable is your gaffers tape?
I put some on my boat and it didn't last that long. It dries out and starts falling off. Maybe the environment you use it in is more benign. |
At least two years. I just pulled mine off yesterday and some of the sticky had gone hard, but it was still holding okay. Used "GooP Off" to clean it up and re-installed new tape.
Mark |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Mon Apr 16, 2018 12:50 pm Post subject: |
hardee wrote: | My favorite was the BBQ version...... |
Hahahahahahahahahahaha........good one! |
Rock-C
C-Dory Year: 1988
Vessel Name: Rock-C
Photos: Rock-C
Posted: Sat Apr 21, 2018 11:54 pm Post subject: |
Update on the project. Drilling the rail was not a problem, but drilling up from the v-berth through the deck plate was not so easy. I ended up removing the railing to drill the bottom plate. Ran the wiring & mounted the light. This gave me a chance to re-bed the deck for the railing. The wires are ran to the dash. All that's left is to mount the switch & connect the power. Thanks for the great advice. _________________ Terry, Ann & Chloe
Rock-C
C-Brat # 26 |
Joined: 02 Nov 2003 Posts: 21507 City/Region: Pensacola
Posted: Sun Apr 22, 2018 11:27 am Post subject: |
Good choice--SS is hard enough to drill, let alone drilling upward in a blind hole! _________________ Bob Austin
