2006 Cape Cruiser Venture 23 in Newport, OR
rudi23
City/Region: Newport
Vessel Name: Wi Knot?
Photos: Wi Knot?
PostPosted: Thu Mar 08, 2018 2:55 pm    Post subject: 2006 Cape Cruiser Venture 23 in Newport, OR Reply with quote
2006 Cape Cruiser Venture 23 in Newport, OR for sale. Price: $45,900. Click “Wi Knot?” link at left to see photos.
We have owned this beautiful boat for 3 years now and have only put 24 hours on it. So we have reluctantly decided to put her up for sale because we just don’t have the time to enjoy her. She’s in excellent condition and has been professionally maintained. Call for more info and/or specific pictures or details: Jon at 541-270-2192 or email me at carmjon1@gmail.com
The boat is located in Newport, OR. Our slip is also available for sale.
Features:
115 HP Yamaha, 4cyl, 4-stroke, CFI, elec/hydr trim/tilt, Michigan Wheel SS prop, 344 hours
9.9 HP Yamaha (T9.9XPHB High Thrust), 2016, 8 hours
“MagicTilt” aluminum frame, tandem torsion flex axle, bunk trailer, disk hydraulic surge brakes on all 4 wheels, (2011) brake lines, (2014) brake actuator, (2013) tires.
VHF marine radio, Standard Horizon, 8’ Shakespeare antenna, SS folding mount on roof.
Garmin GPS Map 541S (2013) 5” color chart plotter, all USA charts, plus chip for Canada, Inside Passage to AK.
Garmin GPS 198C Sounder color, 5” in dash, US nav only, set up for depth (new transducer 2013), speed, fish finder.
Simpson-Lawrence electric anchor winch (2014), Manson 15# Anchor (2012) w/reversing slot for retrieval if stuck, chain 15’, rode 95’
Lenco electric trim tabs with LED position indicator on panel.
9’ inflatable dinghy in case, oars, pump, 2014, like new.
Full aft camper enclosure with windows and screens. Windows can be rolled up, or sides can be rolled up, or removed altogether. Sunbrella, treated, no repairs, fading, leaks, or rips. Aluminum framing. Roof can be rolled up and stored on frame in matching zipper pouch against cabin
Towing cover (2013) - covers cockpit completely on a slant, from roof to motor well.
(2) 30 gal aluminum gas tanks, on rubber strips. Fuel selector switch, R, L, OFF, primary fuel/water separator, electrical master switch in aft SB locker, (2) Ser. 27 batteries in center locker, P locker is live bait tank with plug, but only used for storage of lines, etc.
Electric bilge pump in recessed drain between tanks, auto plus dash switch.
Swim step with SS folding ladder underneath.
Inside cabin height 6’3”, berth length the same, all floors are flat, with foamed spaces underneath, which make for quieter ride and warmer floors. 2 inspection covers.
Wallas kerosene stove/heater, factory serviced late 2014. Not used since servicing.
SS sink with fitted wood cover, pressurized water from 12 gal tank under port aft seat.
2 cf refrigerator, 12V, 120V, we added SS vents for positive air circulation fridge/stove.
Guest battery charger.
All switches with co-located fuses. 120V shore power, circuit breakers, 1 dual outlet. 2 electr. windsh. wipers. Opening center window. Custom tarp from roof to bow rails allows open hatch & center window for ventilation in rain.
Hydraulic Buoy Star steering, SS wheel. Electric horn.
Matching dark green snap-in carpeting on all cabin floor spaces. Upholstery is Sunbrella.
Sliding side windows open 50%, with screens. Privacy snap-on blinds for all windows, door. Screens for all openings.
Dashboard is standard, except for additional GPS mounted on top with marine adhesive tape. 5” Ritchie mag. compass, illuminated.
Tetfort portable toilet under removable bunk section, privacy curtain.
Chrome Barometer over door. Inside/outside electronic thermometer.
Extended, folding 360 cruising/anchor LED light to reach above inflated dinghy on roof.
Hull stripped to the gelcoat in 2014 and inspected (not a scratch!), and repainted with 2 coats of high quality anti-fouling paint.
Cape Cruiser 23' Venture
rudi23
Photos: Wi Knot?
PostPosted: Tue Mar 20, 2018 4:17 pm    Post subject: Reply with quote
Wi Knot? has been sold. Thanks for all the calls and interest in our boat.
Post new topic   Reply to topic    The C-Brats Forum Index -> C-Dory Boats For Sale By Owner All times are GMT - 6 Hours
Page generation time: 0.0353s (PHP: 75% - SQL: 25%) - SQL queries: 19 - GZIP disabled - Debug on
