Boat Cover Vents....
jbdba01
PostPosted: Wed Jan 17, 2018 5:24 am    Post subject: Boat Cover Vents.... Reply with quote
Not sure how many CDory folks have boat covers; regardless, I bought two cover vents and put one on my boat cover - not sure if they'll make a big difference but we'll see. Summer will be a better indicator - winter months in FL are in general pretty benign. I know it's brutal underneath there in the summer.
I added one to start - something about cutting a 3" hole in your cover that just felt wrong, but it's "fixable". Where I installed it was triple reinforced with a heavy duty plastic between the sunbrella and extra stitching.
Takes about 5 min to cut the hole an screw on. Underneath my uprights/supports fit perfectly.
Product image.
PostPosted: Wed Jan 17, 2018 8:54 am    Post subject: Reply with quote
The Angola Canvas Covers have semi natural venting--the bow is open under the bow railing--and also some in the stern, to give air flow.
There are many types of vents--some are sew on--plastic scoops.
Best to cut the "canvas" (Sunbella, or other synthetics), with a hot knife, much less chance of runs or fraying.
PostPosted: Wed Jan 17, 2018 9:02 am    Post subject: Reply with quote
We have two of those vents in our current boat cover, and they seem to work well. They have some heft to them, and are designed to have a post under it to support the weight.
jbdba01
PostPosted: Thu Jan 18, 2018 7:16 am    Post subject: Reply with quote
Hmmm...may take heat gun to it. I'll try that on the leftover piece first.
PostPosted: Thu Jan 18, 2018 11:12 am    Post subject: Reply with quote
Not a heat gun, a "hot knife". I have three--one is like a soldering iron, with knife like blade. Another is a 140/100 or 260/200 watt Weller soldering iron, which I have several "hot knife blades". and a mini butane torch with cutting tip.
A tip for the Weller 550 or 650:
If you don't have a trigger gun, then the Weller TB100PK Therma-Boost Heat Tool is a decent tool, with many uses:
Or a butane type, one of my usual tools aboard:
The Weller Portosol:
You can use any of these, or even a regular soldering iron to seal the edges of any synthetic cloth you cut.
Page generation time: 0.0378s (PHP: 62% - SQL: 38%) - SQL queries: 18 - GZIP disabled - Debug on
