Ron Cowan
State or Province: AL
C-Dory Year: 1985
C-Dory Model: 22 Classic
Vessel Name: Elk-Tenn
Photos: Elk-Tenn
Posted: Wed Dec 20, 2017 8:37 pm Post subject: leaking tilt on 2011 Honda 30hp |
My 2011 Honda 30hp on my log puller tilt is leaking down in about 4 days. The engine has about 250 hours and there is no hydraulic fluid showing around a leak. I assume there must be a seal that is leaking by in the cylinder. Has anyone had this issue and is it a repair to tackle? _________________ Ready to go with the '85 22' Classic |
tsturm
Joined: 01 Nov 2003 Posts: 1180 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Wed Dec 20, 2017 9:14 pm Post subject: Re: leaking tilt on 2011 Honda 30hp |
Ron Cowan wrote: | My 2011 Honda 30hp on my log puller tilt is leaking down in about 4 days. The engine has about 250 hours and there is no hydraulic fluid showing around a leak. I assume there must be a seal that is leaking by in the cylinder. Has anyone had this issue and is it a repair to tackle? |
There is a bypass screw on the left side of the pump(for lowering if no elect. power) make sure that is tight.
Some times a ck valve (internal) will get a piece of debris in it & not seal well. I would get the book out, drain all the oil out into a clean container & look for paint flakes or something that is not clean hyd oil. Refill with clean oil as per the manual. run it up & down a bunch & repeat, see if that wont cure it/flush it out.
Have a good one  |
Ron Cowan
C-Dory Year: 1985
Photos: Elk-Tenn
Posted: Thu Dec 21, 2017 9:08 am Post subject: |
Thanks for the info. and I shall do this as soon as I take the boat back to the water. I am up for the winter with battery off etc. |
Ron Cowan
C-Dory Year: 1985
Photos: Elk-Tenn
Posted: Thu Dec 21, 2017 9:11 am Post subject: |
Thanks for info. I shall try this as soon as I get the battery back to the boat, off for winter. |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2785 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Thu Dec 21, 2017 11:25 am Post subject: Re: leaking tilt on 2011 Honda 30hp |
I’ve never heard of a “log puller tilt”, is it a particular style of tilt mechanism? _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
Ron Cowan
C-Dory Year: 1985
Photos: Elk-Tenn
Posted: Thu Dec 21, 2017 11:39 am Post subject: |
Sorry for the poor wording in my post. The tilt is the engine tilt on the engine on a modified pontoon used for pulling logs out of our subdivision waterways. |
Wandering Sagebrush
Posted: Thu Dec 21, 2017 3:26 pm Post subject: |
Ron Cowan wrote: | Sorry for the poor wording in my post. The tilt is the engine tilt on the engine on a modified pontoon used for pulling logs out of our subdivision waterways. |
Ron, no worries! Sounds like you have quit an operation! Thanks! |
