Trim/tilt leak arounf piston
gallen
City/Region: Santa Rosa
Vessel Name: Rosy B
Photos: Rosy B
PostPosted: Sat Nov 11, 2017 3:07 pm    Post subject: Trim/tilt leak arounf piston Reply with quote
Hello knowledgeable group,
The seal around the trim/tilt shaft on my Honda BF50 is seeping fluid. Does anyone know if there is a kit of replacement gaskets for that, or do I have to replace the entire trim tilt assembly?
Thanks in advance for your help,
Gary
PostPosted: Sat Nov 11, 2017 4:46 pm    Post subject: Reply with quote
Here you go. Parts diagram and order for the BF50A You want to check to be sure this is your model--If not enter it in their search.
gallen
Vessel Name: Rosy B
Photos: Rosy B
PostPosted: Mon Nov 13, 2017 11:33 am    Post subject: Reply with quote
Thanks so much, Dr. Bob.
Page generation time: 0.048s (PHP: 48% - SQL: 52%) - SQL queries: 20 - GZIP disabled - Debug on
