Help identifying unknown switch on 25
jkswor
City/Region: tok
Vessel Name: Missy marie
PostPosted: Mon Nov 06, 2017 10:45 am    Post subject: Help identifying unknown switch on 25 Reply with quote
Am cleaning electrical wiring and terminal block on a 07 25 ft cdory. On starboard side where batteries are there is a terminal block. With a cover saying house switches. Under it It is on right side of compartment. There are from left to right 4 wires. A yellow one with a yellow fuse. A red one. A unknown object. Has 2 switches about one half x one inches each with two connector posts attached together with a red cable on bottom post Then 2 more red cables
The switch like item is rusted very badly at the connector posts . What is it? So I can get new ones
Wish I could attach a photo. But site will not allow me to do so photo is on my iPhone
Hope that is enough info
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Mon Nov 06, 2017 11:48 am    Post subject: Re: Help identifying unknown switch on 25 Reply with quote
Yes Wink
text a pict to nine oh seven three nine 4 thirtyfivethirty.
tsturm
Photos: JMR-TOO
PostPosted: Mon Nov 06, 2017 11:52 am    Post subject: Re: Help identifying unknown switch on 25 Reply with quote
Yes Wink
& west marine catalog on line is a good resource, West Marine in Anc. has been real good about mailing parts & pieces.
jkswor
City/Region: tok
PostPosted: Mon Nov 06, 2017 12:35 pm    Post subject: Reply with quote
Problem solved/ identified
Thanks
PostPosted: Mon Nov 06, 2017 1:04 pm    Post subject: Reply with quote
What a great place, a great group and great service.
tsturm
Photos: JMR-TOO
PostPosted: Mon Nov 06, 2017 1:10 pm    Post subject: Reply with quote
Thanks
Something like this might be a better long term solution Thumbs Up [url][/url]
PostPosted: Mon Nov 06, 2017 1:18 pm    Post subject: Reply with quote
Great to have identified the essential circuit breaker for the "house" systems of the boat! This should be a reminder to all of us:
1:Yearly go over our wiring, and look for corrosion. Clean and protect with a corrosion block material.
2. Identify and label all wiring, including that under the console.
Identify each fuse and circuit breaker.
3. Make at least a rough wiring diagram, so if there is an "electrical emergency" you can identify where the problem is--particularly if you are underway or anchored in a remote area.
The "fuse" in this area, could be either the Wallas stove, or a bilge pump.
Ask the administrators for a "photo album" and then learn to post photographs. It often speeds the information, and thanks to tsturm for posting and solving the problem!
jkswor
City/Region: tok
PostPosted: Mon Nov 06, 2017 5:39 pm    Post subject: Reply with quote
I traced the hot wire to the dingy winch. So original boat owner had this installed. I like the idea of the switch above. Maybe there were none of these in 07. I have only had this boat since July and am going threw it to clean and update as I go. Boat was not maintained well. When I get finished will be like new
Thanks to all
jkswor
City/Region: tok
PostPosted: Mon Nov 06, 2017 6:18 pm    Post subject: Reply with quote
Thanks to all
tsturm
Photos: JMR-TOO
PostPosted: Mon Nov 06, 2017 6:38 pm    Post subject: Reply with quote
Thanks to all
They have been around for 40yrs that I can remember, just more expensive & built to be in a damp environment. Good luck on your project, I did the same thing when I acquired my 25 replaced all the green fuzzy wiring etc.
PostPosted: Mon Nov 06, 2017 8:49 pm    Post subject: Reply with quote
Thanks to all
This is not really a "switch" made to shut off the circuit--although it will do so. It is a circuit breaker to protect the wiring and boat; and you should have a battery switch, which cuts off all power. (except to the bilge pump, wired directly to the battery, or a main bus.) I guess I am confused by your comment "maybe there were none of those in 07" Was that in reference to the photo which was posted?
As tsturm noted they have been around for a very long time. Similar function and action circuit breakers were used during WWII.
Good on the maintenance!
tsturm
Photos: JMR-TOO
PostPosted: Mon Nov 06, 2017 10:14 pm    Post subject: Reply with quote
Thanks to all
What he had was 2 ea RV/Auto style auto-reset circuit breakers(metal can with 2 #10 studs) in parallel, on 2 pieces of Alu., 1 attached to buss bar through both breakers to Alu. piece #2, with a #6 or#8 lead to some device.
Page generation time: 0.2005s (PHP: 93% - SQL: 7%) - SQL queries: 29 - GZIP disabled - Debug on
