Gelcoat Repair
Smuttynose
City/Region: Portsmouth
State or Province: NH
Vessel Name: Snap Out Of It
Photos: Snap Out Of It
PostPosted: Mon Oct 31, 2005 6:47 am    Post subject: Gelcoat Repair Reply with quote
During the last docking of the season, a 3-point landing put a scratch through my green tirm into the white hull. Any ideas on repairing. This is my first season with a boat that I know I will own for decades and until this weekend was "showroom floor" new.
PostPosted: Mon Oct 31, 2005 7:48 am    Post subject: Reply with quote
Smuttynose-
Can't tell where you are from your profile at the sidebar, but if you're anywhere near the factory or plan on being near there at a C-Brat get together, like the Seattle Boat Show and C-Brat Convention, the boys at the factory can make it look just like it never happened.
There are local dealerships and other marine repair shops that can do good work too, but I'd check into their reputation for quality work in this area of expertise, as some are mostly mechanical repair oriented. Doesn't have to be a C-Dory dealer, but I'd insist they use the original jel coat material from the factory for the best color match. Joe.
C-batical
City/Region: Pinckney
Vessel Name: C-Batical
Photos: C-Batical
PostPosted: Mon Oct 31, 2005 9:44 am    Post subject: Reply with quote
Repairing gelcoat is not difficult. See the following site: http://www.spectrumcolor.com/ Spectrum color is an excellent source for supplies and directions. Use wet sandpaper only. I don't use anything coarser that 600 grit , usually 800 grit and finish with 1000 or 1500. Polishing with medium grade rubbing compound.
Rollie/C-Batical
fiddlersgreen6
City/Region: Riverside, Ca. & Melbourne Beach, Fl.
C-Dory Year: 1991
Vessel Name: Don Quixote
PostPosted: Mon Oct 31, 2005 10:17 am    Post subject: Reply with quote
Rollie--- thanks for the input, I've ordered a couple of patch kits today, my biggest problem has been finding the correct color and to be able to allow for some fading differential. In southern calif. there is a fellow who does pretty good mobile work, and seems to be reasonable, his business is called Gelcoat Unlimited, he usually has an ad in the The Log newspaper. Rich
Page generation time: 0.0299s (PHP: 62% - SQL: 38%) - SQL queries: 21 - GZIP disabled - Debug on
