Raising the roof
Izzy
C-Dory Year: 1992
PostPosted: Tue Oct 10, 2017 12:29 am    Post subject: Raising the roof Reply with quote
I have a 22' C dory cruiser. Love the boat. What I don't like about it is the roof is too low. I'm wondering if the stability of the boat would be affected by cutting the roof off, raise the cabin walls 10", and reattaching the roof. I'd either raise the Windows 10" or replace them with larger Windows. Has anyone done this to their Dory? Any thoughts?
PostPosted: Tue Oct 10, 2017 12:34 am    Post subject: Reply with quote
The room is laid on top of the fiberglass sides of the pilothouse. To remove, just cut the tabbing inside. There may be some sealant under it aft..
However, I think it would really look strange--You might get custom windows--or make you own of Acrylic or Lexan (I have done that in several boat).
10". I am 6'2" and no problem with my 22, and the height. If you are over 6'4" the bunk is going to be cramped anyway.
The side windage would be increased, and not going to be real easy to get all of the geometry correct--especially with the slanting windshield. If you went straight up in front--that also would ruin the aesthetics.
My advice is not to do it.
Izzy
C-Dory Year: 1992
PostPosted: Tue Oct 10, 2017 1:30 am    Post subject: Reply with quote
Thataway, thanks for your input. I didn’t think about the windshield angle. I guess another option would be cut the cabin wall at the gunwales and build up from there. Hmmm!
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Tue Oct 10, 2017 8:45 am    Post subject: Reply with quote
You might come out ahead by just selling your 22, and buying a high top model 22 cruiser. They made a lot of them.
2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016
PostPosted: Tue Oct 10, 2017 8:49 am    Post subject: Reply with quote
The hull and deck are one molding. You could cut just above the deck--but 10" would be huge--again--under the windshield may be an issue. You will have to take the galley side wood apart. That forward part is supported by the small dog house forward, not the bulkheads forward in the boat..
Could it be done? Probably. Wise to do--no.
Have you been aboard the "hi top" boats? They have about 6'10" as I remember.
If it is the helm area?--there may be other options.
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Tue Oct 10, 2017 9:12 am    Post subject: Reply with quote
You could always ask the factory to make you a high top and just replace the top.
Jody Kidd
KE7WNG
Northern, Utah
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Tue Oct 10, 2017 9:32 am    Post subject: Reply with quote
BEST answer yet in my opinion!
I was going to suggest lowering the sole which would eliminate messing with the windows LOL.
It's something in the water!
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Tue Oct 10, 2017 11:04 am    Post subject: Reply with quote
Go for the High top model or an added high top from the factory. It would fit properly and look good plus be less custom work needed.
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
Izzy
C-Dory Year: 1992
PostPosted: Wed Oct 11, 2017 1:15 am    Post subject: Reply with quote
Thanks everyone for your suggestions. I did not know there was a high top model. I also thought they stopped making C Dory years ago. Does anyone have a photo of a high top Dory?
Izzy
C-Dory Year: 1992
PostPosted: Wed Oct 11, 2017 1:05 pm    Post subject: Raising the roof Reply with quote
Can you tell me how much window height is gained with a high top?
With gratitude,
Izzy
Aurelia
Photos: Aurelia
PostPosted: Wed Oct 11, 2017 1:47 pm    Post subject: Reply with quote
No window height is gained. This is a picture of the high top in which you can see only the center raised section of the roof is higher than the standard model.
http://www.c-brats.com/modules.php?full=1&set_albumName=album&id=DSC00053&op=modload&name=gallery&file=index&include=view_photo.php
Below is an example of the standard roof
http://www.c-brats.com/modules.php?full=1&set_albumName=Bertas-Boy&id=IMG_5322&op=modload&name=gallery&file=index&include=view_photo.php
Greg
PostPosted: Wed Oct 11, 2017 3:59 pm    Post subject: Reply with quote
It sounds as if you need to either change the height or cant of your helm seat, or learn to live with the window height of the current boats. They are not like a huge window pilot house boat--but as you get used to the windows, there is plenty of field of view.
Describe what you see as the problem.
PostPosted: Wed Oct 11, 2017 7:55 pm    Post subject: Reply with quote
There is a lightly used "HighTop" here:
http://www.c-brats.com/viewtopic.php?t=25845&highlight=
Might make more sense to just get this one. It is a 2007 22 Cruiser with a High Top and with low hours on the OB.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Thu Oct 12, 2017 9:28 am    Post subject: Venture 23 Reply with quote
Go look for a high top or a venture 23 if you need more then 6ft 4in then go to A cd 25 with 6ft 8in headroom happy hunting
Page generation time: 0.1435s (PHP: 81% - SQL: 19%) - SQL queries: 31 - GZIP disabled - Debug on
