How to quite your espar heater
PostPosted: Fri Oct 06, 2017 3:13 am    Post subject: How to quite your espar heater Reply with quote
I was looking around the net to answer a question for another brat about my Espar heater and just learned that now you can get mufflers for them for a bout $30 bucks. https://www.youtube.com/watch?v=uR5enBj_Pzc
PostPosted: Fri Oct 06, 2017 10:04 am    Post subject: Reply with quote
When I first installed my Webasto heater, I was told how I could make a muffler for it. I actually made two, but decided not to use either of them. It's basically a small copper pipe with holes drilled in it, going thru a larger copper pipe with insulation stuffed in it. If anyone wants one to try, just let me know. Colby
PostPosted: Fri Oct 06, 2017 12:09 pm    Post subject: Reply with quote
My one concern with the heaters is the noise.
PostPosted: Fri Oct 06, 2017 1:03 pm    Post subject: Reply with quote
Yeah, you can just imagine that you are at SeaTac and a big jet is in the process of taking off! But the warmth and comfort makes it all worthwhile!
PostPosted: Fri Oct 06, 2017 2:51 pm    Post subject: Reply with quote
After the start up process I don't notice the noise hardly at all. We run it more when we are fishing and under way then any other time so I never notice it then. I will install a muffler for when we are at the dock . It also helps to dock so the exhaust is facing out from the dock and not towards the dock. Coby if you want to send me one of those I will give it a try.
Second recommendation is for this item inline drain. You should always have a low point in your exhaust line between the out let and the heater unit to trap any water that might enter. I have a low point but no way to remove the water. I will be using something like this but with a valve added at the end of the copper . These are made for truck installs where all the plumbing is out side. I will have to modify it a bit to work in the boat.
PostPosted: Fri Oct 06, 2017 2:53 pm    Post subject: Reply with quote
It's not quite that loud, but it does sound just like a jet turbine! lol
PostPosted: Fri Oct 06, 2017 5:44 pm    Post subject: Reply with quote
Tom, you anywhere near the Snake or Columbia Rivers? I'll bring one of the mufflers with me when I come out next week. Regarding a water drain, I believe my exhaust is the lowest point in the system, with a constant descent in the piping. I was worried about that as well when I initially installed the heater. Colby
PostPosted: Fri Oct 06, 2017 5:54 pm    Post subject: Reply with quote
Afraid I am not. I live in marysville Wa. But maybe we can work something out. When are you going to be there?
Ron on Meander
City/Region: Powell River
Vessel Name: Meander
Photos: Meander
PostPosted: Fri Oct 06, 2017 7:32 pm    Post subject: Reply with quote
You could just get a Wallas furnace. You can hardly hear it run. Inside or out.
PostPosted: Fri Oct 06, 2017 8:49 pm    Post subject: Reply with quote
I'm looking at all options right now; Espar, Webasto or Wallas.
I noticed Tom/Susan's this past weekend. Sounded just like a propane construction heater.
I love the Wallas (low noise and low power consumption along with more BTUs) but they cost almost three times as much.
I will have a Wallas 85DU with low hours for sale soon.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
PostPosted: Fri Oct 06, 2017 9:27 pm    Post subject: Reply with quote
Mark,
I'm surprised you didn't notice the noise of Tosca's Webasto this last weekend at Stuart. We were across from you on the dock with our heater exhaust pointed toward the dock (on our starboard side) and therefore toward Au Kai.
It is a bit noisy, but it doesn't really bother me. I wouldn't mind quieting it down a bit. I guess a muffler will do that (I could sure hear the difference in the video clip posted above). I wonder if there is a down side, even a slight down side, to fitting a muffler on the Webasto unit?
Ron on Meander
Photos: Meander
PostPosted: Fri Oct 06, 2017 9:39 pm    Post subject: Reply with quote
Yeah the Wallas heater is the pricey option. We have had our 1800 Kerosene furnace for about 10 years now. I have not had any problems with the furnace and haven't serviced it yet. (That bit is for the Wallas naysayers out there) The selling points for me on the Wallas furnaces are: low power draw, excellent heat provided, for the fuel consumption used, the ability to duct the heat, the drying of the interior air, and it's QUIET. Price sucks!
Doing it again, and without the DU95 to add additional heat. I'd go with the bigger Wallas 30 for heating a 25 in the PNW.
Cheers
Ron
PostPosted: Fri Oct 06, 2017 10:18 pm    Post subject: Reply with quote
I'll send you a PM. Colby
Discovery
City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
PostPosted: Fri Oct 06, 2017 10:45 pm    Post subject: Reply with quote
I start the Espar up and it's noisy (like a little jet), but then the boat heats up in about 10 minutes, and I turn the dial down. At lower settings I really can't hear any "jet" noise.
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
R407c
City/Region: Milwaukee
C-Dory Year: 1997
PostPosted: Sat Oct 07, 2017 9:18 am    Post subject: Espar heater muffler Reply with quote
Tom Starcrafttom,
I had a muffler that looked just like the one in your video link. I got it with the marine kit conversion I ordered after getting my used Espar from a truck shop. The muffler is stamped stainless steel, folded over and tack welded. However, It is not air tight. Exhaust gas leaks along the seams and where the end stubs are put on. Yes, it can be used if it is out side the truck cab or out side the boat. The exhaust side of the Espar is slightly pressurized so I did not use this muffler in my installation.
What Colby has made out of copper for a muffler I think would work fine. I am still think of driving out to his place as he is only 70 miles away and picking it up but haven't yet. I guess I could make one too. Right now I use the Espar with out the muffler and at lower outputs, the sound is pretty low.
Take care,
Mike Moser
Mike Moser
Page generation time: 0.1779s (PHP: 90% - SQL: 10%) - SQL queries: 32 - GZIP disabled - Debug on
