Joined: 23 Oct 2003 Posts: 5310 City/Region: Warrenton
Posted: Fri Aug 25, 2017 7:44 pm Post subject: TyBoo repower |
My old Honda 130 has pretty much given up after 18 years and 1600 hours. A leak down test suggests the water in the oil is from a bad head gasket, which isn't such a big deal in itself if not for me seeming to have oddball problems.
A few of the early Honda 130 blocks had a problem with cracks and they also had a corrosion problem with the fuel delivery system. When I first got the boat I had Les at EQ give it a check up. He verified that the block was not one of the problem ones and updated the fuel system under warranty/recall. Honda extended the warranty out to ten years on everything and the motor has been perfect until now. It was in 2002 that they issued the recall and the 130s built since then had the updated fuel system parts along with a new design for the cylinder head.
Fast forward to today - the head gasket for the original head on my 1999 motor is obsolete and to repair it requires an updated head. A local shop found a used one that he could put on but I decided it was too much to do for so old an engine.
Off to Sportcraft Marina in Portland we went (a great place for all things C-Dory, by the way). They successfully converted me to the dark side and I will soon have new black Suzukis hanging off the back - a DF200 main with a DF9.9 kicker. The big motor is ordered and they will put it on shortly after Labor Day.
The DF200 is a recent design using an inline 4 cylinder that weighs 498 pounds total, about a 100 pounds less than their previous V6 200 hp model, and a few pounds less than the Honda 130 I now have. I think the Honda 150 which is a good fit and popular on the CD25s is a few pounds lighter.
I went there planning on a 15 or 20 hp kicker, but the tech explained to me, once again, about hull speed and how the smaller motor will move the boat just as well as the larger one up to that point. The DF9.9 has electric start and power tilt and still comes in cheaper and lighter than the all manual 15/20 hp so it was an easy sell.
The only sad thing in this is that I decided to sell my tractor to pay for the boat upgrade. I never really needed a tractor anyway, but it was a John Deere so it was tough letting go of it.
Anyhow, even though I am missing out on the big crowds for the salmon fishing this year, we might be able to make it north for the late September Stuart Island gig. I would not have trusted the old Honda and no kicker that far from home. Who knows - I might even catch a fish or two while we run up the initial 20 hours on the new motor. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
South of Heaven
Photos: Blue Water
Posted: Fri Aug 25, 2017 8:39 pm Post subject: |
You won't know what to do with all that power! Woohoo! I had the V6 200 Suzuki....crazy power. I'd be interested to hear your thoughts on the new V4 version. Sounds like amazing technology _________________ <><><> Jason <><><>
1995 C Dory 16' Angler (40 hp Yamaha, sold 2/16) |
Jim Gibson
Joined: 21 Feb 2006 Posts: 611 City/Region: Sacramento
C-Dory Year: 1998
Vessel Name: Pounder
Photos: Pounder
Posted: Fri Aug 25, 2017 9:11 pm Post subject: |
Now that you have re powered why don't you join us on our Lewis & Clark Expedition Cruise?
This trip would be a great low speed 100 hour breakin for your new big engine. _________________ Jim on M/V Pounder
And the C-Tales Continue |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2768 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Fri Aug 25, 2017 9:12 pm Post subject: |
Mike, those black motors look really nice on a CDory... BTW, the 9.9 is also fuel injected. I'm going to put one on my boat. Black and silver looks lopsided. Actually, the fuel injection is appealing.
Consider putting a PermaTrim on the 200.
Congrats! _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
Posted: Fri Aug 25, 2017 9:28 pm Post subject: |
The Permatrim was a great addition to the Honda 130. I will try the new feller without it for a bit but suspect I will add one to it. And oh yeah - that's right - I forgot to mention the fuel injection on the little guy. The only goofy thing I see with the Suzies is the need to take off the plastic case section to get to the oil filter. They could've made a door or something.
We might wander upstream a little ways, Jim. It is really neat cruising past the mill I worked at all those years and not have to be there. |
Slipknot
C-Dory Year: 2016
Posted: Fri Aug 25, 2017 10:53 pm Post subject: |
Good choices, and the Suzuki also has a self adjusting timing chain rather than a belt that has to be checked and replaced. My new 25 has a Honda 200 on it which I'm looking forward to running. |
Posted: Fri Aug 25, 2017 11:26 pm Post subject: |
Great choice of engines. I agree with the kicker. You would not go any faster with a 15 or 20.
Did you get the digital instruments or analogue? Also you have two different charging circuits. All kinds of things to explore. I know my son's 25 runs great with a 150 Honda--yours will be awesome with the 200. _________________ Bob Austin
Posted: Sat Aug 26, 2017 12:19 am Post subject: |
I am getting the digital gauge. The additional cost ($400) was the same as the Suzuki rebate so I like to tell myself it was free. I do not know if that includes the sensors for fuel flow and speedo. It is the same square shape and size as the Raytheon depth gauge that is on the opposite side of the panel so it will look cool in there.
It also displays water pressure with an additional sensor, but I'm not sure what pressure is being measured?
I'm looking forward to trying it all out. My big old heavy boat has always been a dog with the Honda 130 and sometimes climbing up the big ocean ground swells was kind of spooky when the SOG dropped down to 3 or 4 kts. I am thinking the fuel economy will be better, too. I have always averaged right about 2 MPG. |
Posted: Sat Aug 26, 2017 4:17 am Post subject: |
Whaa-whooo. Good for you. I think you will like the power change, and the new reliability. I was surprised to hear such low hours and needing to replace.
Congrats on the upgrade. Now about that tractor. I can understand the reluctance. Just consider that Johnny was pulling for you to the last step.
SleepyC
Posted: Sat Aug 26, 2017 2:01 pm Post subject: |
200 horses. Nice. _________________ "We can go over there...behind the 'little one'....."
My IRA
Joined: 18 Dec 2003 Posts: 233 City/Region: Springfield
C-Dory Year: 2013
Vessel Name: Aidiam
Photos: My IRA
Posted: Sun Aug 27, 2017 11:19 am Post subject: |
The torque of that new black Suzuki will bring a smile to your face every time you throttle up. Ryan, at Sportcraft, is such a great guy to do business with (extremely honest and a wealth of knowledge). _________________ Jerry and Helen
1984 Arima Explorer sold 1985
1985 Arima 17 SR sold 1992
1992 C-Dory 22 Cruiser sold 8/96
1992 OLympic 26XLF Sold 10/2000
1989 Arima 19 SR sold 2003
2004 C-Dory 25 sold 10/05
1992 Bounty 25 Offshore Pilot sold 6/2010
2006 Arima 17 SC sold 9/2012
2013 C-Dory 23 Venture |
Ordutch1975
Vessel Name: Boatless :-(
Photos: PennyBridge
Posted: Sun Aug 27, 2017 2:13 pm Post subject: |
I second that Ryan is awesome! Congrats on the repower I am sure you will enjoy it for years to come _________________ "And it is an interesting biological fact that all of us have, in our veins the exact same percentage of salt in our blood that exists in the ocean, and, therefore, we have salt in our blood, in our sweat, in our tears. We are tied to the ocean. And when we go back to the sea, whether it is to sail or to watch it, we are going back from whence we came. " -JFK |
AstoriaDave
Posted: Sun Aug 27, 2017 2:16 pm Post subject: |
Tyboo, give us a run up Youngs Bay, above the new YB bridge, OK? I wanna hear those 200 horses!
Oh, high tide, of course! _________________ Dave Kruger
Astoria, OR |
Anita Marie
Joined: 01 Nov 2003 Posts: 826 City/Region: Oak Harbor
Vessel Name: Anita Marie
Posted: Sun Aug 27, 2017 2:17 pm Post subject: |
You will be amazed how different your boat is going to preform. I repowered from a 150 Honda to a 200 Yamaha and the difference was short of amazing.
A 200HP for a 25 C-dory is the perfect match. |
Joined: 02 Nov 2003 Posts: 8551 City/Region: Birch Bay, WA
Posted: Sun Aug 27, 2017 5:55 pm Post subject: |
I admit I am a tiny bit jealous, since I know that 200 horses would get Daydream up on plane and singing anywhere on the Loop, and sometimes that would be nice. But financially I am happier just putzing along and merely humming...IF (when?) we need a repower, that will be a different thing. _________________
