Adhesive Removal - How to?
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sun Jul 09, 2017 11:14 am    Post subject: Adhesive Removal - How to? Reply with quote
I put some adhesive backed non-skid pads in the motor well years ago, and they are now starting to deteriorate and peel back.
Any thoughts on how to get the sticky gunk off the gelcoat without hurting anything?
Thanks in Advance!
san juanderer
City/Region: Stanwood
C-Dory Year: 1990
PostPosted: Sun Jul 09, 2017 12:24 pm    Post subject: Reply with quote
Rubbing alcohol removes the adhesive.
Have used it on car paint to remove tree sap and decal adhesive, at first was very leary about using it. But does not damage the auto paint.
Cdory 22 Angler
SeaSport 24XL, Etec 250 hp (sold)
Rosborough RF246 (sold)
Commander 30 Sportfish (sold)
Olympic 26 XL (sold)
Glassply 19 (sold)
Olympic 23 (sold)
Bayliner 38 Motoryacht (sold)
Olympic 20 (sold)
Fiberform 16 (sold)
Olympic 18 (sold)
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sun Jul 09, 2017 12:44 pm    Post subject: Reply with quote
I have used Goo-Gone several times and it works super...leaves nothing behind and works fairly quick..
Joel
SEA3PO
AstoriaDave
City/Region: Astoria
PostPosted: Sun Jul 09, 2017 1:31 pm    Post subject: Reply with quote
Rubbing alcohol works most of the time. In a worst case, get some of 3M's Windshield Adhesive Remover. About as toxic, fumewise, as gasoline. Wear thick nitrile gloves, do not breathe the vapor. Ace, NAPA, WalMart, other sources:
https://www.upccodesearch.com/upc/051131036185
Dave Kruger
Astoria, OR
SENSEI
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
PostPosted: Sun Jul 09, 2017 1:34 pm    Post subject: Reply with quote
when I was removing the names and numbers off the sides of the boat there was a lot of sticky residue. I asked my detailer what he used to take it off and he told me to use gasoline. I did and it worked great.
Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017)
Wandering Sagebrush
PostPosted: Sun Jul 09, 2017 1:39 pm    Post subject: Reply with quote
Thanks everyone! Much appreciated!
PostPosted: Sun Jul 09, 2017 3:28 pm    Post subject: Reply with quote
I recently had to remove a 3M clear "mask" which was put on the front cap of my RV to prevent paint damage 10 years prior...It was the hardest adhesive I have had to remove. I also could not damage the several thousand dollar paint job (just on the front fiberglass cap) I tried all of the various solutions. The final result was a cleaner called "Zep Heavy Duty Citrus Cleaner" from Lowes, spayed on first, then spray on WD40. A few places I had to loosen the film with steam--and I there I used "plastic" razor blades to lift the film. That solution removed any trace adhesive--Any of these should mandate the use of heavy Nitrile gloves. (I have some 9 mil that work well)
No damage to the paint, and all adhesive removed.
My IRA
City/Region: Springfield
C-Dory Year: 2013
Vessel Name: Aidiam
Photos: My IRA
PostPosted: Sun Jul 09, 2017 3:59 pm    Post subject: Reply with quote
If nothing above has worked, try 3M General Purpose Adhesive Cleaner Part #08984, it will work.
Jerry and Helen
1984 Arima Explorer sold 1985
1985 Arima 17 SR sold 1992
1992 C-Dory 22 Cruiser sold 8/96
1992 OLympic 26XLF Sold 10/2000
1989 Arima 19 SR sold 2003
2004 C-Dory 25 sold 10/05
1992 Bounty 25 Offshore Pilot sold 6/2010
2006 Arima 17 SC sold 9/2012
2013 C-Dory 23 Venture
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Sun Jul 09, 2017 4:06 pm    Post subject: Reply with quote
Goo-Gone and/or a hair dryer has worked for me.
Martin.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Sun Jul 09, 2017 6:27 pm    Post subject: Reply with quote
My go to is denatured alcohol. Works for all sorts of adhesives.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Sun Jul 09, 2017 8:12 pm    Post subject: Reply with quote
One thing to watch for is the effect of rubbing too vigorously. Even if you have a solvent that cuts whatever, rubbing the surface too hard can leave a mark that shows where the whatever was removed. This is particularly a problem when the solvent is not all the good at removing the material and the natural tendency is to rub harder.
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Sun Jul 09, 2017 9:45 pm    Post subject: Reply with quote
We use a product from Essex - a urethane adhesive cleaner - part # U - 421. It is very friendly - solvent free, non toxic, and biodegradable. Although a lot of friendly cleaners don't work as good as their toxic cousins - this stuff works great. Not cheap though.
Regards, Rob
PostPosted: Mon Jul 10, 2017 12:26 am    Post subject: Reply with quote
WD-40 may do the trick also.
Page generation time: 0.0584s (PHP: 51% - SQL: 49%) - SQL queries: 30 - GZIP disabled - Debug on
