Gel Coat Questions
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Tue Jun 27, 2017 12:12 pm    Post subject: Gel Coat Questions Reply with quote
I have a small ding in my starboard chine where the boat came down on one of the trailer shackle bolts.
I just realized that my boat came with a gelcoat kit that has sat in the shop since 2005. I opened it, and to no surprise it was fairly solid. I haven't messed with it, but am curious if there is a way to still use it to repair my chine. Any experts? Dr. Bob?
AstoriaDave
City/Region: Astoria
PostPosted: Tue Jun 27, 2017 1:50 pm    Post subject: Reply with quote
Nope, that batch is dead. Depending on the temperature, and how it was packaged, you can expect a couple years or so.
Dave Kruger
Astoria, OR
PostPosted: Tue Jun 27, 2017 7:43 pm    Post subject: Reply with quote
Agree 100% with Dave. Toss that. Check with Spectrum color and see if they have the C Dory white--I saw some advertised recently....But at times they only have larger sizes: Here is the paste in white.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Wed Jun 28, 2017 10:58 am    Post subject: Reply with quote
I just bought the little container Bob shows and fixed last year's major battle scars. The color matched perfectly and the only issue was the quality of my workmanship. The instructions give a mixing ratio for using 1/2 of the container at a time, way more than what I needed. But I eyeballed about 1/8th of the gel and the corresponding number of drops of catalyst and it worked out fine.
I'll probably get more practice soon and won't have to worry about it going bad.
One problem was that I filled a couple of big gouges with a black epoxy. If I had used a white epoxy it would have made things a lot easier.
Mark
Wandering Sagebrush
PostPosted: Wed Jun 28, 2017 11:34 am    Post subject: Reply with quote
Thanks everyone. IBoat only has the gallon, so I'm checking with NMI. Worst case, it will be clear epoxy. The ding is really small, and on the chine, so it's not a big deal if I can't match it.
Page generation time: 0.0278s (PHP: 60% - SQL: 40%) - SQL queries: 18 - GZIP disabled - Debug on
