Repowering w/115
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Fri Jun 23, 2017 4:04 pm    Post subject: Repowering w/115 Reply with quote
I finally did the deed this morning, we are repowering our CD 22 with a Suzuki 115. The boat goes in next week, and we should have it early the following week. If anyone with a similar setup has prop recommendations, I'd appreciate your feedback. Right now, I'm thinking a 17 & 19 or 19 & 21 pitch would make a good pair to have.
I'm putting the motor Honda 90 Hp (carbureted) w/Permatrim, plus an 8 Hp Honda Classic on consignment with Sportcraft. I have 3 props for the main, a stainless 15, and 13 and 17 aluminum props that will be for sale. A spare thrust washer, too. If you're interested, let me know.
Steve
MikeR
City/Region: Mill Creek
C-Dory Year: 2016
Photos: MikeR
PostPosted: Fri Jun 23, 2017 4:24 pm    Post subject: Reply with quote
Congrats! Bet you'll love the extra thrust of the larger prop/engine!
Why not start with the 19, run it for a bit, then decide if you want a 17 or 21 as second prop.
FWIW, I'm running a 15x17 on the Command Thrust 90, obviously not same motor, but has similar displacement at 2.1L, and similar gear ratio (2.38 vs. 2.59)... Boat weight has been increasing over the last year but I'm still reaching almost the middle of the max rpm range for the motor...this weekend I'm going to be trying out a 15.25x15 for pushing heavier loads. Would think that for you a 17" is great for heavier loads and 19 for everyday use, but start with the 19 and see!
Enjoy the new motor!
-Mike
22' C-Dory Cruiser (2016)
16' C-Dory Angler (1989)
10' C-Dory Row Boat (1995)
PostPosted: Fri Jun 23, 2017 10:05 pm    Post subject: Reply with quote
I've got a 2007 CD-22 Cruiser with a 2007 Mercury 115hp, 4 stroke efi. I'm running a 3 blade 14 x 13, or 4 blade 13.25" dia. X 13" . Actually I usually run the 4 blade. Very happy with it. WOT with either prop gives me about 6500 rpm's, so I'm on spec. Colby
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Sat Jun 24, 2017 12:59 am    Post subject: Reply with quote
I'm running 13-7/8" X 17 pitch Solas SS on my DF-115 sea level and use a 15 pitch for Lake Powell and Yellowstone. Remember the Suzuki is geared lower than the other motors so what they use won't work for yours.
Jody Kidd
KE7WNG
Northern, Utah
Wandering Sagebrush
PostPosted: Sat Jun 24, 2017 8:02 am    Post subject: Reply with quote
Thanks, that is exactly what I was interested in.
jkidd
PostPosted: Sat Jun 24, 2017 7:11 pm    Post subject: Reply with quote
Of course my boats on the heavy side most of the time so I would start with a 17 at sea level. If it over revs then I have a 19 aluminum that you might want. Then the 17 would work for Powell. I don't think there is much difference between aluminum and Stainless at least with my tests no great gains.
Wandering Sagebrush
PostPosted: Sat Jun 24, 2017 7:30 pm    Post subject: Reply with quote
When at Lake Powell, we refer to our boat as the African Queen... Way to much stuff!
The guys at Sportcraft are going to help me prop it, but your info looks like a great starting point...
Wandering Sagebrush
PostPosted: Sun Jul 09, 2017 9:57 am    Post subject: Reply with quote
The deed is done, and much less than I thought it might run. Sportcraft is great to work with... The boat (lightly loaded) propped out with a 19 pitch here on the Willamette. WOT was in the 5,600 - 5,800 range. I am going to run that for a while and see what I think. I have a used 17 pitch as a backup.
I still have a stainless 15 pitch prop, thrust washer and nut, motor cover and fresh water wash attachment if anyone is interested, and will do an inventory of what there is. I'll put a separate thread out for that stuff.
PostPosted: Sun Jul 09, 2017 10:35 am    Post subject: Reply with quote
Looks good, Steve! Thumbs Up It will be interesting to hear your thoughts between the old motor and new.
PostPosted: Sun Jul 09, 2017 12:49 pm    Post subject: Reply with quote
Do you still have the used motor? Greg was looking for one on another post
Wandering Sagebrush
PostPosted: Sun Jul 09, 2017 1:41 pm    Post subject: Reply with quote
It is on consignment at Sportcraft. Thanks Tom!
Page generation time: 0.145s (PHP: 90% - SQL: 10%) - SQL queries: 28 - GZIP disabled - Debug on
