Solar charging through cigarette lighter?
Ozma
City/Region: Albany
Vessel Name: Ozma
PostPosted: Thu Jun 15, 2017 9:29 pm    Post subject: Solar charging through cigarette lighter? Reply with quote
I purchased a portable 50 watt solar panel to charge the batteries while anchored. Instead of using the supplied clamps to connect to the batteries, I would like to plug into the 12v lighter on the panel. Has anyone done this with success?
Dan Wilcox on board the 22' CD cruiser Ozma
Dan Wilcox, OZMA
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Thu Jun 15, 2017 10:19 pm    Post subject: Reply with quote
I dont use them and consider it unsafe and could cause damage so bought a solar charger
Brent Barrett
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Thu Jun 15, 2017 10:31 pm    Post subject: Reply with quote
It would be better closer to the battery's to minimize the voltage drop. 50 watts isn't all that much you will want it pointed directly at the sun not flat on the roof.
Jody Kidd
KE7WNG
Northern, Utah
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Thu Jun 15, 2017 11:03 pm    Post subject: Reply with quote
Yes, I've charged through the cigarette lighter. Not on my boat, but I have a Polaris Ranger that has a 2W solar panel because I often make short rides around my property and the battery doesn't get fully charged. It's just a trickle charger.
For a 50W panel, I'd wire direct to the battery through a solar charge controller. A $12 solar charge controller can make the charging so much more efficient that it doesn't make much sense to go just through a lighter socket except as a temporary solution.
https://www.amazon.com/dp/B00NAVVI8E/ref=asc_df_B00NAVVI8E5032079/?tag=hyprod-20&creative=395033&creativeASIN=B00NAVVI8E&linkCode=df0&hvadid=167157220945&hvpos=1o3&hvnetw=g&hvrand=3430728877407254944&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9033322&hvtargid=pla-314689475003
Mark
Ozma
City/Region: Albany
Vessel Name: Ozma
PostPosted: Fri Jun 16, 2017 6:13 pm    Post subject: Reply with quote
Thank you all for your input. The panel does have a charge controller and it does make sense to go directly to the battery to minimize voltage drop.
Dan
Page generation time: 0.0368s (PHP: 41% - SQL: 59%) - SQL queries: 22 - GZIP disabled - Debug on
