Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Tue May 23, 2017 4:46 pm Post subject: Transom Saver |
For those road warriors who trailer a lot this product might be of interest. Click on your brand of engine for a video of how they install on your brand. www.motormateusa.com _________________ Chevrolet The Heart Beat Of America |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Tue May 23, 2017 6:55 pm Post subject: |
I don't get it. It looks like the piece spans from the outboard leg to the outboard transom plate. It might not look like it is still transferring any twisting stress to the plate, but where else can the force go? With a traditional transom saver, some of the force is transferred to the trailer cross member (sometimes via the first roller). That has the possibility of reducing the stress on the transom. This gizmo keeps all of the twisting force still in the same place, i.e., on the transom plate.
The amount that the motor "wiggles" isn't really an indication that transom stress has been relieved. I ain't buyin' it.
Mark |
Aurelia
Photos: Aurelia
Posted: Tue May 23, 2017 7:35 pm Post subject: |
Thats true, but many boaters focus more on saving the outboards trim hydraulics instead or doing both that and easing transom forces. It's like a partial solution for those to are not worried about the transom I suppose.
I do something similar in wood form to take the load off our trim system and don't really worry about the transom itself so much.
The bars that extend to the trailer can do a disservice to the engine and transom if the boat is not really well locked down in place. Small boat movements can transfer a lot of force through that support and now your doing more harm than good.
Careful use of that type is a good idea. I have seen negative results as in twisted and blown hardware.
Gig Harbor
Ari - 19 Cruiser sold 2023
C-Dude
C-Dory Year: 2013
Vessel Name: Gryphon
Photos: C-Spirit
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Tue May 23, 2017 9:19 pm Post subject: Transom Saver |
I have no interest in the company. I just saw it as new product. I'm ok if no one buys it. Yamaha sells a similar device like the last poster's link illustrates. It just slides over the tilt ram and has a rubber snubber. Just adjusting the tilt down puts pressure on the rubber snubber. With the motor tilted almost all the way up I would think most of the weight of the engine is pushing down on the transom. The idea of keeping pressure off of the tilt cylinders and the manual support arms is the usual idea. It would seem movement can create more dynamic forces to cause extra stress on all components . JMHO.
D.D. |
C-Dude
C-Dory Year: 2013
Photos: C-Spirit
Posted: Tue May 23, 2017 9:46 pm Post subject: Re: Transom Saver |
Will-C wrote: | I have no interest in the company. I just saw it as new product. I'm ok if no one buys it. Yamaha sells a similar device like the last poster's link illustrates. It just slides over the tilt ram and has a rubber snubber. Just adjusting the tilt down puts pressure on the rubber snubber. With the motor tilted almost all the way up I would think most of the weight of the engine is pushing down on the transom. The idea of keeping pressure off of the tilt cylinders and the manual support arms is the usual idea. It would seem movement can create more dynamic forces to cause extra stress on all components . JMHO.
D.D. |
That motormate looks like a pretty good product. Seems like it would serve a similar purpose as the M-Y Wedge, but provide more solid support. Do you happen to know the approximate cost range of the motormate? Interesting product |
Joined: 27 Oct 2012 Posts: 3372 City/Region: SW Michigan
Posted: Tue May 23, 2017 9:50 pm Post subject: |
The amount of force put on the trim rams and transom in normal operation is way more than that produced by trailering. The tilt ram (for getting the motor out of the water) is not designed for these forces and may have it's life extended by this device. However, I just stick a piece of 2x4 in between the stationary and moving parts of the motor mount and then lower the motor a bit to trap the piece of wood. In addition to relieving the force on the tilt ram, the wood provides a bit of a cushioning effect vs. a hard metal mount. |
BTDT
Joined: 07 Jan 2011 Posts: 322 City/Region: Grand Lake Oklahoma
State or Province: OK
Vessel Name: C- Lark Wine Down
Photos: C-Lark
Posted: Wed May 24, 2017 7:55 am Post subject: |
My concern is not so much the transom but rather the steering input forces on the hydraulic system. I have ordered two and will test on the trip to the Mississippi gathering _________________ John & Vicki Clark
C-Lark Wine Down
Tomcat 255 |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Wed May 24, 2017 10:18 am Post subject: |
ssobol wrote: | I just stick a piece of 2x4 in between the stationary and moving parts of the motor mount and then lower the motor a bit to trap the piece of wood. |
I had to go with 3x3 to get the leg raised a bit more. I drilled a hole in it and attached a tag line to the motor so that it can't get lost. Total cost is 10 cents and it floats. I need a clever trade name (MotorFloater?), some bright paint (same reason as a fishing lure), and I can go into business.
Mark |
Aurelia
Photos: Aurelia
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Wed May 24, 2017 2:33 pm Post subject: |
I turn the motor all of the way to one side to avoid stress on the steering system--and feel this is important. You can do the same thing by pieces of PVC pipe slipped over the ram arms. Wedge to support the motor over the tilt arm. Generally works well, easy to use, and not expensive.
I have one of the types which goes to the trailer frame, on the Caracal Cat. Although this sort of keeps the motor centered, I still use PVC on the ram arms keep the motor centered. _________________ Bob Austin
