USCG Documentation Interior Hull Numbering
sjhantzis
City/Region: Barters Island
State or Province: ME
Vessel Name: Catleen
PostPosted: Wed May 17, 2017 8:55 am    Post subject: USCG Documentation Interior Hull Numbering Reply with quote
Any thoughts on the best place for interior hull USCG Documentation Numbering? Here's the USCG parameters:
The vessel must have the official number permanently affixed in block-type Arabic numerals of not less than 3 inches in height, preceded by the letters “NO .” on some clearly visible interior integral structural part of the vessel.
SJH
PostPosted: Wed May 17, 2017 10:39 am    Post subject: Reply with quote
We documented a 22, 25 and 255. In each case, we put the NO. on the inside of the hull under the table, with vinyl stick on letters, then covered those with a very thin sheet of fiberglass cloth (deck cloth), which is transparent when coated with clear epoxy. Some have just put clear epoxy over the vinyl letters.
Another way, is to cut a board, rout the NO. in the board, and epoxy the board to the inside of the hull--probably the best place remains under the table. I used teak on some of our larger vessels.
Unless one is doing a lot of international voyaging, or trying to diminish fees, there is little reason to document currently. It used to be that documentation was free renewal--now the CG charges a fee, I believe it is $26. If you miss the renewal date, the vessel must be re-instated, and if out of the US when that occurs there can be some expensive implications--daily late fees.
Also many states require that the vessel also be state registered. Florida does,--if you are not state registered even if visiting, you may be asked to register in Florida...At one point officers were enforcing that near the border. I believe that more leniency is given now... State registration doe snot mean state numbers, but the state sticker should be displayed on the windshield or side window--or part of hull--mast on sailing vessels.
It used to be free renewal, no state registration, and there were some diplomatic advantages in foreign waters...most of these have been negated. Our current boat is not documented.
beermanPDX
City/Region: Portland
Photos: Jean Marie
PostPosted: Wed May 17, 2017 12:08 pm    Post subject: Reply with quote
On my 25 I put the USCG Doc # directly on the sole / hull in the galley cabinetry (on the floor under the sink). I also just did the vinyl stickers covered with a layer of fiberglass/epoxy.
Cheers Beer
Rob
2008 25 Cruiser - Sold
2002 Nordic Tug 32/4 - Sold
1989 40 Tollycraft Sport Sedan
sjhantzis
PostPosted: Wed May 17, 2017 2:23 pm    Post subject: Reply with quote
Thanks, under the table, is a good idea. I'll probably do that.
Page generation time: 0.1186s (PHP: 90% - SQL: 10%) - SQL queries: 21 - GZIP disabled - Debug on
