Replacing Honda start switch on honda BA50
Baxter
City/Region: Sheridan
State or Province: WY
Vessel Name: Baxter ll
PostPosted: Thu May 11, 2017 11:23 pm    Post subject: Replacing Honda start switch on honda BA50 Reply with quote
I have searched every where to find a Honda BA 50 replacement switch. Boats US
and Honda Marine have not helped much. Say not available. We are headed
to Friday Harbor gathering and only can start on engine.
Is there any kind of generic switch one can use? OFF, ON, START.
each mounted separately.
I did overnight one here that said is was what I wanted but some colors
of wire different. So I am stuck.
Last summer the switch stuck once. I should have replaced then. Not
thinking straight. Worked last fall so forgot about it. Water test the
other day failed. have checked all connections and fuses.
I don't care about appearance matching just so it works.
thanks Baxter
What we do for ourselves stays here, what we do for others goes with us
jack keifer
City/Region: Boise
State or Province: ID
Vessel Name: C-Squirt
Photos: C-Squirt
PostPosted: Fri May 12, 2017 1:35 am    Post subject: Replacing start switch Reply with quote
You might try Sportcraft in Portland. They are both a Honda and C-Dory dealer, and I have had good luck with them.
Jack
Previously 22 cruiser "Loafer's Paradise"
Now 16 cruiser "C-Squirt"
Page generation time: 0.0216s (PHP: 56% - SQL: 44%) - SQL queries: 19 - GZIP disabled - Debug on
