Installing Solas Props
CDory23
Photos: CDory23
PostPosted: Sun Apr 30, 2017 2:00 pm    Post subject: Installing Solas Props Reply with quote
Hi,
I recently posted a thread on props for a 22 with twin Yami 40's. I ended up purchasing 2 new Saturn SS Solas Props. #3331-116-11. The same ones as "Hardee" since he runs at a similar weight and altitude and is happy with there performance. I assumed new thrust washers and spacers would come with them and the only item I would reuse is the nut. It only came with the prop itself with hub installed obviously.
Can you just reuse the old thrust washer and spacer from the old yamaha props that were installed? My originals were 11 1/8 X 13-G yamaha prop.
Thanks
CDory23
Photos: CDory23
PostPosted: Sun Apr 30, 2017 2:15 pm    Post subject: Reply with quote
All of the spacing/clearances seems to work, I'm thinking the old materials are fine to reuse with new props.
PostPosted: Sun Apr 30, 2017 2:20 pm    Post subject: Reply with quote
I don't know how much comfort this will give you, but I reused. Only changed out the props. Still working. I put about 250 hours on last summer on the new props.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Apr 30, 2017 3:32 pm    Post subject: Reply with quote
m2cw
new props, new washers,etc
Brent Barrett
PostPosted: Sun Apr 30, 2017 9:16 pm    Post subject: Reply with quote
I have reused the thrust washers when installing different props--as long as they had the same hub configuration. New cotter pins/ and or tab washer may be necessary. The thrust washer for various brands of props maybe different, as if you use a Torq Flo hub prop. (There are several different Torq flo hubs)
Page generation time: 0.0263s (PHP: 62% - SQL: 38%) - SQL queries: 18 - GZIP disabled - Debug on
