Lower Carrier Bearing Housing
CDory23
Photos: CDory23
PostPosted: Wed Apr 19, 2017 12:20 pm    Post subject: Lower Carrier Bearing Housing Reply with quote
I need to replace the oil seals on my 2003 Yamaha F40 Lower carrier bearing housing. I bought the puller to remove it easily since it seems these can be a paint to remove and light prying did not budge it. I have the bearing oil seals but unfortunately there is also an O ring I didn't know about that seals water from the hub that won't arrive in time for me to make my voyage on Friday. Has anybody removed this housing and re-used these rings? Parts 50 & 51. Think I can salvage the O rings and reinstall with just the bearing oil seals?
http://www.boats.net/parts/search/Yamaha/Outboard/2003/F40TLRB/LOWER%20CASING%20DRIVE%201/parts.html
Thanks
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Wed Apr 19, 2017 1:23 pm    Post subject: Reply with quote
Applying heat to the case around the carrier can help. Use propane or mapp gas, or perhaps a heat gun, never acetylene. Heat the case all around the carrier to expand the case. if the paint is smoking, that is enough heat. The heat can damage the o-rings, but so can just pulling the carrier. If the orings leak, that is just as bad as having the seals leak, either way you can get water in the gearcase.
Consider just using the motor as is and change out the gear oil when you return. Modern outboard gear oil has additives to absorb some water.
Larry H
A C-Brat since Nov 1, 2003
CDory23
Photos: CDory23
PostPosted: Wed Apr 19, 2017 1:35 pm    Post subject: Reply with quote
Thanks for the reply,
I would have used as is since it wasn't a large leak to begin with but unfortunately I have already damaged the outer seal trying to remove it without the removing the actual assembly... Maybe I could still try to just remove and replace the outer seal while leaving the carrier barrier housing in place for just this trip and then later replace everything properly. I originally tried to remove seals with barrier housing in place but got nervous about damaging the prop shaft by drilling and using self tapping screw to remove the seal so stopped doing it the "hack" way. I would hope that this method if done carefully wouldn't damage the inner seal... Any thoughts?
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Wed Apr 19, 2017 2:41 pm    Post subject: Reply with quote
If you get the outer seal out, inspect the inner seal closely.
If no damage seen, install the outer.
When I worked Evinrude/Johnson, we had a tool that could remove the seals with the carrier in place. It was a hollow tube with tapered threads on the end. It slipped over the prop shaft and threaded into the seal, then pull. I don't know if Yamaha has the same thing, it depends on how the seals are made.
That prop shaft and its replacement labor is spendy. Probably cheaper to take the motor to the shop for the seal change.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Wed Apr 19, 2017 2:44 pm    Post subject: Reply with quote
SIM Yamaha has several quick delivery options
call
888-231-2392
about them and if items are in stock
Anyone close to you have them?
Brent Barrett
BrentB
Photos: BrentB
PostPosted: Wed Apr 19, 2017 4:35 pm    Post subject: Reply with quote
I would replace them bc they have changed shape due to compression over the years. m2cw
CDory23
Photos: CDory23
PostPosted: Wed Apr 19, 2017 6:56 pm    Post subject: Reply with quote
Thanks again for all the replies.
I want to get the job done right so I"im gonna hold off on the next trip. I will have all the proper tools/gaskets soon and will be replacing all oil seals/o rings associated with the lower unit when they arrive. I will then pressure test it per the yamaha manual and go from there. Luckly I have a pressure tester I can borrow from work.
I only noticed a very slight milk in the gear oil so maybe I"m getting ahead of myself, but at this point since I have everything might as well get both motors and all seals done as preventative maintenance.
Do others notice small hints of milk in there gear oil when changing? Maybe a very small amount is somewhat normal?
BrentB
Photos: BrentB
PostPosted: Wed Apr 19, 2017 9:15 pm    Post subject: Reply with quote
No I havent. I change the drain and fill crush washers often and bulk packs are available from SIM
CDory23
Photos: CDory23
PostPosted: Fri Apr 21, 2017 3:12 pm    Post subject: Reply with quote
Well this Lower Bearing Carrier is very tough to get out! I've heated with propane torches, sprayed lubricant as well as possible and tried several ways to pull out. the most succesful being this modification on a regular puller. I may have moved it 1/64"
https://www.youtube.com/watch?v=dLlNOumzPTY
The problem I had with that method was getting it to pull out straight. It always leaned a small bit to one side and the chain links I was able to attach to the carrier started to bend.
I just ordered this $$$$$ tool as my last shot to get this job done, and then I"m going to just take it in. I talked to the Owner, and if it doesn't fit or it doesn't work I will return it.
http://marinetechtools.com/lower-bearing-carrier-housing-puller.html
BrentB
Photos: BrentB
PostPosted: Fri Apr 21, 2017 3:30 pm    Post subject: Reply with quote
wow that tool is crazy expensive
another source
http://www.sterndrive.info/yamaha/tools.html
doing the work yourself, the tools are free
PostPosted: Fri Apr 21, 2017 3:56 pm    Post subject: Reply with quote
Not sure what oil you are using. I like to really soak parts with PB Blaster, AeroKroil, ACF- 50 etc..for at least 24 hours--applying more every few hours.
Then heating the outer housing. Immediately apply CRC "Spray Freeze-Off" (extremes of this would be using dry ice.) The spray freeze is not inflammable, but I certainly would not breath the fumes or spray.
Too much force may damage carrier bearing or housing....I would think that you could modify a wheel puller (making your own "arms" )to slip under the carrier bearing--and pull it out that way....
Combination--pulling with a modified gear puller, after soling well with the penetrating oil--heating all around the housing, then hit the inner part with the Freeze spray, and maybe even a light tap with a hammer. Keep the pressure with the puller all thru this-cranking a little if necessary. I would have at least a 5 ton puller (just to have enough beef in the threads to avoid stripping.--probably square threads (well lubed) are gong to be better.
CDory23
Photos: CDory23
PostPosted: Fri Apr 21, 2017 6:12 pm    Post subject: Reply with quote
I've been using Aerokroil. I have not tried the "freeze off" method so will try that.
I agree a tool could be modified farily easily, but I don't have time to do it before a Lake Shasta trip I have planned with being away all next week for work. At this point I've ordered the overpriced tool for the job and if it works I'd still be saving money and time from bringing in to shop.
What is the risk with too much force? Perhaps damaging the reverse gear or bearings? What would be too much force? Should I set a torque wrench to it to confirm I don't apply to much?
I saw a thread where someone was mentioning needing to put the motor in forward gear, but I believe he was referring to an in/out motor. The service manual diagram for the Yami 40 shows the whole carrier in place with nothing holding it in except for the 2 bolts on outside which I have obviously removed.
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sat Apr 22, 2017 2:58 pm    Post subject: Reply with quote
The puller you show puts pressure on the prop shaft end and pulls on the carrier. Do NOT strike the end of the puller with a hammer. The force of a hammer strike would be transmitted to the forward gear thrust bearing and could damage the bearing rollers or races.
The puller force path is from the screw, down the propshaft, thru the forward gear thrust bearing to the case. The force then goes back thru the case to the stuck bearing carrier. The puller arms take the force to the puller plate and screw.
I would not recommend the YouTube method shown. That is make do and unsafe. The shackles and chain are not load rated to match the puller. If the puller screw leans over, it could fly off sideways, with potential injury. Same thing if a shackle or chain link fails. If you generate several tons of force with the puller screw and a part fails, injury or damage can result. There is a reason why the manufacturers create and sell the special tools to do these jobs.
I noted that in the YouTube video, he does not show the puller actually removing the bearing carrier!
A $200 tool is less than two hours of $$ shop time these days.
Have you checked the official Yamaha shop manual for the correct procedure?
PostPosted: Sat Apr 22, 2017 3:53 pm    Post subject: Reply with quote
Larry,
My though with light hammer taps was around the periphery of the housing where the carrier bearing holder was stuck. Just enough vibration to help to break that adhesion (which is probably due to corrosion), Agree certainly not on the end of the puller (although I have seen this used--there are serious risks).
Larry H
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Sat Apr 22, 2017 4:05 pm    Post subject: Reply with quote
Bob,
I agree that light taps around the housing might help.
Page generation time: 0.0539s (PHP: 68% - SQL: 32%) - SQL queries: 28 - GZIP disabled - Debug on
