try tabs
rainman2
City/Region: bremerton
Vessel Name: angler managment
PostPosted: Tue Feb 21, 2017 8:44 am    Post subject: try tabs Reply with quote
ant thoughts on trim tabs ,as to type electric,vs hydraulic,vs pneumatic. and size for a 22 ft CD angler. 115 Etec powered. please and thanks guys Ray
rainman2
PostPosted: Tue Feb 21, 2017 8:47 am    Post subject: trim tabs Reply with quote
as to size of trim tabs,i heard one say 12 inch was good.
PostPosted: Tue Feb 21, 2017 11:49 am    Post subject: Reply with quote
Trim tabs are a bit of a chevy vs ford deal. I have Lenco electrics and love them. I can't find a reason not to get them. Simple to install, work great, no pump, oil or reservoir to worry about. 5 years and no signs of corrosion. Boat was in the water for two summers. I have had them on two boats including my current one. One thing I would upgrade too, and most likely will soon now that the tech is here, would be auto leveling. One of my pet pevs , of which there are many to choose from, is not having the boat level 100% of the time. I hate when someones walks from one side of the boat to the other and I have to readjust the trim. And I HAVE to readjust the trim. Drives me crazy to ride in another persons boat that does not notice or care about trim. Side to side or even front to back. I hate it.
So all the trim tab makers now have auto adjust. Its not just side to side but also front to back. It will also adjust the trim in corners for a flatter turn.
Bennet https://youtu.be/CruJRMOoAAg
Lenco https://youtu.be/vD80u9WVSks
Zip wakehttp://www.zipwake.com/
these are the three major brands. Zip wake is a re design of the old QL Volvo system. I have not used this system but do like the looks and the way it works. Would love to try it but I already have lenco tabs and will most likely update those with a auto controller.
A Fishin C
Guest
PostPosted: Tue Feb 21, 2017 11:58 am    Post subject: Reply with quote
Lenco Standard Trim Tabs 9x12.
Inexpensive, easy to install, and work like a charm for me (for side to side)
I do have permatrim also though to get the bow down.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Tue Feb 21, 2017 1:02 pm    Post subject: Reply with quote
THESE guys are awesome and have a great product and great service .
Found on OEM C Dorys
Marc
Wefings Marine Website
Since 1909
PostPosted: Tue Feb 21, 2017 1:26 pm    Post subject: Reply with quote
Marc- Looks like this one company is making upgrades for both the Lenco and the Bennets http://www.lectrotab.com/products/automatic-level-control-lenco-bennett.php
I will have to compare the cost of all three.
PostPosted: Tue Feb 21, 2017 1:40 pm    Post subject: Reply with quote
Boat Leveler is another trim tab company which has been used on the C Dory. The bottom line is that they are all good. 9" x 12" is the size. I currently have Lenco, and have had them on a larger boat--no problems. Probably the best service is from Bennett.
Agree that the Permatrim, is also a good addition, along with the trim tabs.
olsurfdog
City/Region: Carmel Valley
Vessel Name: Summer
PostPosted: Tue Feb 21, 2017 4:38 pm    Post subject: Reply with quote
Is 9 x 12, length (9") x width/beam (12")? Or vise versa??
Thanks!
Michael
______
I am where I am
Because I was where I was
Wefings
Dealer
PostPosted: Tue Feb 21, 2017 4:47 pm    Post subject: Reply with quote
12 W
9 L
m
rainman2
PostPosted: Tue Feb 21, 2017 4:48 pm    Post subject: Reply with quote
thanks all , so i am ruling out the "smart tabs"pneumatic
liking lenko with a permatrim add-on.
thinking electric over hydraulic
in a 9x12 or 12 x12 size sound ok?? thanks again all brats, ray
PostPosted: Tue Feb 21, 2017 5:51 pm    Post subject: Reply with quote
The "smart tabs" don't do the job. You want real adjustment. The automatic will trim the boat as you want, side to side, but may not give the amount of "down bow" you need into chop.
PostPosted: Tue Feb 21, 2017 6:03 pm    Post subject: Reply with quote
Bob, if you read or watch the links I gave you will see that the auto tabs work front to back and side to side. They even take speed into account and turns. Its a new world over the old bubble level and switches. Its tech from your cell phone. They use the same sensors your phone does to tell which way you are holding the phone. Great new stuff.
A Fishin C
Guest
PostPosted: Tue Feb 21, 2017 6:09 pm    Post subject: Reply with quote
lenco and bennett have their dimensions reversed i think. mine stick out 9 and are 12 wide.
the stick out dimension may affet your kicker if you have one,
PostPosted: Tue Feb 21, 2017 10:15 pm    Post subject: Reply with quote
I have Lenco Electric. I love the idea, but my T-tabs are too small. (9'W tapered to 8"W by 9" long.) They need to be at least 144 Sq inches or better. Getting 12" wide on a C-Dory makes for a REALLY tight fit. If you can get 10"s Wide by 14 long I'd go with that. The added length will be more effective at slower planing speeds without adding as much drag.
SleepyCMoon
PostPosted: Wed Feb 22, 2017 1:45 am    Post subject: Reply with quote
Anybody tried interceptor tabs? Certainly it is a nicer installation (at least on the outside of the boat). Haven't seen what's on board.
Page generation time: 0.2047s (PHP: 93% - SQL: 7%) - SQL queries: 30 - GZIP disabled - Debug on
