2003 22' C-Dory Cruiser – $32,000 – Durango, Colorado
Water Bill
City/Region: Lake Keowee, South Carolina
State or Province: SC
Vessel Name: C-Swell
Photos: C-Swell
PostPosted: Sat Feb 11, 2017 5:01 pm    Post subject: 2003 22' C-Dory Cruiser – $32,000 – Durango, Colorado Reply with quote
2003 22' C-Dory Cruiser – Durango, Colorado
Suzuki DF 90 Four-Stroke - 2003
  • Motor Serial #: 09001F-421501
  • 1,702 Hours on Engine
  • Stainless Steel Suzuki Propeller 14x18 - Three Blade
  • Stainless Steel Solas Titan E3 Propeller 13 7/8x15 - Three Blade
  • Hustler Aluminum Turning Point Propeller 13 3/4x15 – Three Blade (spare)
  • Outboard Motor Cover
Nextrail Aluminum Tandem Axle Boat Trailer
  • Trailer Vin #: 1N9BB23272B171248
  • Hydraulic Surge Brakes
  • Disc Brakes on Each Axle
  • Aluminum Mag Wheels
  • Commodore Tires ST 205/75R 14C
  • Stainless Steel Bolts and Nuts in Main Frame
  • Galvanized Axles
  • Cypress Bunk with Marine Carpet
  • Aluminum/PVC Post Guide-Ons and High Profile Bunk Guide-Ons
  • Heavy Duty Aluminum Cross Braces
  • Submersible Lights (LED)
  • Model 21 - 23 Tandem
  • GVWR 6000 lbs
  • Trailer Weight 800 lbs
22' C-Dory Cruiser Boat Features
  • Hull ID#: CDO22057G203
  • White with Deep Blue Factory Accent Trim
  • High Top 6’-6” Interior Headroom
  • Commuter Model Bench Seat
  • Cabela’s Pro Fisherman High-Back Seat – Color Blue/Gray
  • Spare Stock Forward Facing Captains Seat – Color Blue
  • Stock Forward Facing Passenger Seat – Color Blue
  • Bench Seat and V-Berth Cushions – Color Blue
  • Additional 3” Thick Memory Foam in Zippered Blue Denim Cover for V-Berth
  • V-Berth Snap On Privacy Curtain
  • Garelick Adjustable Table with Cherry Wood Trim
  • Snap-in Translucent Window Covers for All Windows – Color White
  • Snap-in Floor Carpet (Cabin & Bow) – Color Blue
  • Front Opening Center Window by Diamond Sea Glaze
  • Rear Opening Door with Lock, Window and Screen by Diamond Sea Glaze
  • Full Screen for Door Opening
  • Two Side Opening Windows by Diamond Sea Glaze with Window Screens
  • Screen for Bow Hatch
  • Sunbrella Bimini Top Cockpit Canvas - Color Blue with Stainless Steel Frame
  • Sunbrella Camper Back - Color Blue (with screens and clear vinyl windows)
  • Port and Starboard Electric Wipers
  • Water system - A 20 Gallon Water Tank Fed to a Stainless Steel Sink by a Foot Pump
  • Wallas Diesel Stove & Heater Model 95D
  • Custom wood racks on galley counter
  • Two Additional 8“ Cleats on Bow Starboard and Port Side
  • Two Additional 12” Stainless Steel Grab Rails Mounted on Brow Starboard and Port Side
  • Two Sets of Ignition, Door and Water/Fuel Cap Keys
  • Swim Step with Ladder - Located on Port Side
  • Fiberglass Cockpit Floor Boards
  • Upgraded Starboard and Port Lazarette Hatches
  • ICOM IC-M402 VHF Marine Radio
  • Shakespeare 4’ VHF Antenna with Ratchet Antenna Mount
  • FloScan Fuel Flow Meter - Fuel Management System - Monitors GPH (Gallons per Hour)
  • Garmin 741XS GPS Chartplotter Sounder with BlueChart g2Mapping for the Coastal US/Bahamas, LakeVu HD Mapping for the US, and LakeVu HD Ultra West
  • Airmar T150M 300W Broadband Chirp Transducer Transom Mount Garmin 8 Pin
  • Suzuki Tachometer Multi Fuunction Gauge
  • Suzuki Outboard Trim Indicator
  • Suzuki Voltage Battery Charging Indicator
  • Lev-O-Gage
  • Three 12 volt Cigarette Lighter Adapters
  • Caframo Model 748 Bora Fan Over Dash
  • Teleflex HA5419 Seastar 20 Degree Steering Wheel Wedge Mount
  • Hydraulic Steering by SeaStar
  • Hydraulic Trim Tabs (9" x 18" each) by Trim Master Marine, Inc.
  • Flojet Automatic Washdown Pump (Pressure Demand System)
  • Inverter - 1750 Pro Watt by Xantrex with Remote Switch & GFCI Protected 110V Cabin Outlet
  • One 12 Volt Duralast 27 DP-DLBattery (tray and cables for 2nd Battery)
  • Two 12 Volt Duralast Marine Deep Cycle Batteries 24MD-DL
  • 110V 30 Amp Shore Power
  • 40’ Shore Power Cord
  • Two Guest Dual Battery Chargers in Sink Cabinet
  • Simpson-Lawrence Sprint 400 Anchor Windlass
  • 8 Lb Seachoice Fluke Anchor, 10’ Ό’ Galvanized Chain and ½” x 150’ 3 Strand Nylon Rode
  • Anchor Deck Pipe
  • Rule 1100 GPH Bilge Pump with Automatic Float Switch in Cabin
  • Attwood Automatic 750 GPH Bilge Pump in Cockpit
  • Fuel Capacity - Two, 25 Gallon Tanks for 50 Gallons Total
  • 10 Micron Fuel Filter
  • Mermaid Manufacturing 5,200 BTU Model M-5C-U Cool Only Air Conditioning System
  • Mermaid Digital, Programable Climate Technology Digital Thermostat
  • Includes Foot Scoop, Seacock, Water Strainer, Pump, Air Supply Grill, 4” Air Ducting and Vents
  • Weight is 31.5 lbs
  • Cooling Capacity is 450 Cubic Feet
  • Thule Roof Rack
  • Three Blue Fenders 6”x22”
  • Four Braided ½” Dock Lines 12’, 21’, 23’ and 27’
  • Detachable BBQ Grill Platform
  • Stainless Steel Flag Staff and 24” American Flag
  • Fire Extinguisher
  • Two Perco Stainless Steel Fishing Rod Holders
  • Thetford 555 Porta Potty (Used)
  • C-Dory, Suzuki and Most Equipment Manuals are Included
  • Copy of Maintenance Log Included
  • Never Stored in Water
  • No Bottom Paint
  • Always Stored Under Cover When Not in Use
  • Always Washed After Each Use
  • Waxed Once a Year
Additional pictures can be viewed on my C-Swell photo album
Contact Bill at bnsroche@gmail.com
Water Bill
Photos: C-Swell
PostPosted: Thu Feb 23, 2017 12:29 pm    Post subject: Reply with quote
Several C-Brats have asked for additional photos of C-Swell. I took quite a few photos this week and entered them into a sub album called C-Swell For Sale Photos located in the main C-Swell album. You can get to this album by clicking on Photos: C-Swell.
Esmi2
City/Region: San Luis Obispo, CA
PostPosted: Wed Mar 15, 2017 6:24 pm    Post subject: Bump Reply with quote
I spoke at some length with Bill recently about this boat, and it sounds absolutely wonderful.
He knows every inch of it, and has put virtually all of the hours on the Suzuki himself -- so he knows exactly how it's been maintained through most of its hours.
The boat has some really neat custom features, like the "commuter" seating, like the custom retractable table, like the extra padding in the v-berth, and so much more. Check his photo albums for details.
My story is that I joined this group a couple of months ago to find a 22' Cruiser to buy. C-Swell appears reeeealllllly close to perfect from a price/value perspective. What I have found is that even though it is the boat right, I am not ready to buy yet.
If you're in the market to buy, I highly recommend you add C-Swell to your short list. Thumbs Up
PostPosted: Wed Mar 15, 2017 10:38 pm    Post subject: Reply with quote
Here is one pix of the several added.
Water Bill
Photos: C-Swell
PostPosted: Sun Apr 02, 2017 6:39 pm    Post subject: Reply with quote
C-Swell sold today to a nice couple from Utah.
Esmi2
PostPosted: Sun Apr 02, 2017 11:11 pm    Post subject: Reply with quote
Thumbs Up
I'm so glad for you, Bill. I hope the new boat is all you're expecting and more!
Post new topic   Reply to topic    The C-Brats Forum Index -> C-Dory Boats For Sale By Owner All times are GMT - 6 Hours
Page generation time: 0.0649s (PHP: 64% - SQL: 36%) - SQL queries: 23 - GZIP disabled - Debug on
