FellMarine MOB kill switch
PostPosted: Fri Jan 13, 2017 6:21 pm    Post subject: FellMarine MOB kill switch Reply with quote
I saw a note about this device in a splash in the Dec Boat US magazine. Since, I have seen it in a couple of other adds. Seems like a great safety device, especially for those of us who singlehand, although it can be used with more than one sensor (per person device) for either a single engine or multiple engines. It has a 50 foot range, and kills the engines in 1-3 seconds, and can be restarted in 6 seconds if someone is still on board to return to the MOB.
Made by Fell Marine, a Norwegian company, and there are a few dealers in US and Canada, and it appears to be not too hard to set up.
Here is the link:
https://www.fellmarine.com/
Looks like around $200 for the device.
I’m curious if anyone has seen it or has experience with it. Although I am very careful about where I am on the boat when it is running, there are times when I am in the cockpit photographing and have to be letting George, (my AutoPilot), do the driving. Admittedly those are for very short periods, but sometimes it is the nature of the beast. (Can’t stop the boat and expect the dolphins to keep playing in the wake.)
SleepyCMoon
PostPosted: Fri Jan 13, 2017 7:03 pm    Post subject: Reply with quote
I do not know anything about the device, but it is a catchy name for the company that makes it!
PostPosted: Fri Jan 13, 2017 7:30 pm    Post subject: Reply with quote
Here is a link to a Hull Truth thread about the device, and the thread includes some posts from the Fell Marine representative.
https://www.fellmarine.com/blog/the-hull-truth-anyone-using-the-fell-marine-wireless-kill-switch/
I sent some of this info to Tim at Rodgers Marine in Portland to see if they would be interested in dealing for FellMarine and/or at least install it for me.
Bill K
City/Region: Toledo
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
PostPosted: Fri Jan 13, 2017 7:33 pm    Post subject: Reply with quote
I use the Autotether and have two passenger sensors and it is made in the US.
http://www.autotether.com/
Bill Kelleher
KA8BFT
PostPosted: Sun Jan 15, 2017 12:39 am    Post subject: Reply with quote
Bill, that sounds like it serves the same function as the Fell Marine unit. How does yours install and have you tested it for function?
Bill K
City/Region: Toledo
Photos: NIC'L PIC'L
PostPosted: Sun Jan 15, 2017 10:00 am    Post subject: Reply with quote
Harvey,
All you do is exchange the kill lanyard for the Autotether kill lanyard that is connected to the receiver box ( 2" x 3" x 1/2" ) which is powered with AAA batteries as are the sensors. There is double sided tape on the back of the receiver.
When it is activated a pin in the kill switch connector pushes out and it disconnects from the kill switch.
Each person wears a sensor.
Yes I have tested it both for distance ( 75-150 ft ) and in the water.
I feel much safer.
Bill Kelleher
PostPosted: Sun Jan 15, 2017 12:54 pm    Post subject: Reply with quote
Hi Bill, Thanks for the reply. Their web site was a little vague on actually how it worked. I can see it working if you are running a single engine, but what if you are running twins, or in your case, have the main shut down and are trolling?
Bill K
City/Region: Toledo
Photos: NIC'L PIC'L
PostPosted: Sun Jan 15, 2017 1:24 pm    Post subject: Reply with quote
fHarvey,
I am pretty sure that I saw somewhere about using it with twins.
Update from web page
"What if I have 2 kill switches?
We can sell you a kill switch and you just need to have the 2 engines wired into the single kill switch. Call Technical Support for assistance."
In my case I just switch Autotether connector to the kill switch on the little engine remote control.
Here is a link to the manual.
www.autotether.com/uploads/3/8/4/6/.../autotether_manual-rev_may_2011.pdf
Bill Kelleher
PostPosted: Sun Jan 15, 2017 2:42 pm    Post subject: Reply with quote
Hi Bill,
Not sure why, but that link wen t to a "Error 404" page so I went back to the AutoTether site and recopied the link. we'll see if this one works any better.
http://www.autotether.com/uploads/3/8/4/6/38460803/autotether_manual-rev_may_2011.pdf
I just checked and this one worked, this time. (On Edit)
I didn't find anything in the manual that addresses twin engine application other than what you noted.
I know there is at least one C-BRAT that is using some sort of wireless MOB warning system. I believe it is Tim Flanagan on Two Lucky Fish, but my memory is a bit hazy.
SleepyCMoon
Bill K
City/Region: Toledo
Photos: NIC'L PIC'L
PostPosted: Sun Jan 15, 2017 2:47 pm    Post subject: Reply with quote
Harvey,
Sorry about the link problem, I had a heck of a time getting it to paste,
Bill Kelleher
olsurfdog
City/Region: Carmel Valley
Vessel Name: Summer
PostPosted: Sun Jan 15, 2017 3:04 pm    Post subject: Reply with quote
My quick impression is that the Autotether is a somewhat simpler system (KISS)! I know of two guys locally who have set up the Autotether and like it-neither has actually had to test it in a real life episode--but that's good too! Soon as I can I plan on getting an Autotether or the Fell system myself. Need a little more research to decide which.
Michael
______
I am where I am
Because I was where I was
PostPosted: Tue Jan 17, 2017 1:20 pm    Post subject: Reply with quote
I just talked to "AutoTether" and for twins, the OEM kill switch on the Throttle/Gear controls have to be wired together. They do not have a host device that is designed with two actuators (a "Y" from the main plug) to power two actuators. (Seems easy enough to do, but he said the actuator requires a 100 volt pulse from a capacitor to do the deed.)
He also said that having 2 separate systems, requiring to wear 2 MOB monitors wouldn't work because they would not shut down simultaneously.
This might be the KISS system for a single outboard, but it would require manually switching the actuator if/when you change to kicker power.
PostPosted: Fri Feb 03, 2017 5:22 am    Post subject: Reply with quote
Just wondering if anybody saw anything at the boat show, (or anywhere else), that would be comparable to either of these devices. It still seems like the Fell Marine one would be the easiest to use but the more complicated to hook up.
Seems like a a good device for a single hander.
BTDT
City/Region: Grand Lake Oklahoma
State or Province: OK
Vessel Name: C- Lark Wine Down
Photos: C-Lark
PostPosted: Fri Feb 03, 2017 8:39 am    Post subject: Reply with quote
I can't speak for others but my Tomcat with twin Honda's uses two keys for starting but one tether for stopping both motors.
Kind of a waste though as the tether is in the pilot house where it would be practically impossible to fall out of, but no tether at the cockpit dual control system where I could easily fall over the side?
I'm thinking of ordering the USA version for ease of installation and simplicity
John & Vicki Clark
C-Lark Wine Down
Tomcat 255
PostPosted: Fri Feb 03, 2017 12:31 pm    Post subject: Reply with quote
It would be easy and cheap to put a second tether switch somewhere in the cockpit. The switch and lanyard are about $18 for the marine version. There are motorcycle, and Snowmobile switches which are cheaper.
Page generation time: 0.0383s (PHP: 73% - SQL: 27%) - SQL queries: 32 - GZIP disabled - Debug on
