2004 honda 90 carburetor or fuel injected
terraplane
City/Region: chesapeake bay
C-Dory Model: R-25 Tug
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Wed Dec 07, 2016 3:46 pm    Post subject: 2004 honda 90 carburetor or fuel injected Reply with quote
Is the HOnda 2004 90hp fuel injected?
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Wed Dec 07, 2016 4:18 pm    Post subject: Reply with quote
Carbureted,
In 2006, they started offering the FI feature.
We currently have a 2003 75 which is nearly the same motor (also carbureted of course). Aside from a multi-step cold start routine, I have never had trouble with the carbs on our motors. We also owned 2 90hp 2005 motors in the past.
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Wed Dec 07, 2016 4:28 pm    Post subject: Reply with quote
The Fuel injection 90 did not come along until very late 2006 or early 2007. I have a late 2006, and it is Carbureted. The other feature which came with the injected engines is the larger alternator of 44 amps, vs the carb of 17 amps.
I drain my engines, and squirt in a little carb cleaner, then drain again, if I am not going to be using it for more 2 months. I try and always use non ethanol fuel (not always practical) Put in Stabil, and Startron.
If it is ethanol gas, I pull it out thru my "polishing system" and run it in the truck.
Here is part of one of the very early reviews of the "new 90".
new 1496cc powerhead, a four-cylinder, single overhead-cam design with about 100cc less displacement than the previous BF90. Dry weight is down by 14 pounds, Also the BLAST (boosted Low Speed Torque) and VTEC(Variable valve timing) were introduced at this time. The early injected 75's did not have VTEC.
Aurelia
Photos: Aurelia
PostPosted: Wed Dec 07, 2016 4:33 pm    Post subject: Reply with quote
If those pics of Sally's Sister in your album are of the motor in question, I can tell its carbureted from the pics.
Greg
Steven Dore
City/Region: Ocean Marine - Portsmouth, VA
Vessel Name: Orca
Photos: Orca
PostPosted: Sat Dec 10, 2016 8:37 pm    Post subject: Reply with quote
I have a 2004 Honda 90 and it is carbureted. The only problem I have experienced, was due to a tank of bad fuel at the beginning of the season. I suspect the fuel had sat in the marina's tank for several months before I filled up.
Page generation time: 0.0383s (PHP: 63% - SQL: 37%) - SQL queries: 22 - GZIP disabled - Debug on
