SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Fri Nov 25, 2016 6:22 pm Post subject: Why does my boat always sit lopsided ? |
Under the topic of batteries I asked this question as I always thought it was because of the batteries.... but then I thought, everyone else has at least two batteries on that side...so what goes ?? it has always sat lopsided...I only carry about 8 gallons of fresh water in the tank so it may be a bit light on that side...but why just my boat ? One thought might be that I might have water in the hull, but it sits level on the trailer and I would think any water would spread to both sides and equalize the weight....my boat has sat funny since it was new...and is not in the water all that much... so any ideas ???
Other than there is a load of krap on the drivers side....(not funny)
looks like I am sinking
SEA3PO |
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Fri Nov 25, 2016 6:37 pm Post subject: |
It can't be the weight of food onboard as junk food is just empty calories....and not that heavy.... and I do try to pack any heavy stuff on the left side...I have a propane tank with maybe 2.5 gallons of propane on the left side ....but the boat has always sat low (about 2") on the right side... the motors seem to be mounted near the centerline and not offset... so WHAT ?? I give !
SEA3PO |
Joined: 03 Mar 2005 Posts: 3597 City/Region: Valley Centre
Posted: Fri Nov 25, 2016 7:30 pm Post subject: |
Well, most 22' C-Doreys are balanced. Given that, the tilt must be explained by more weight on one side or the other. So the problem is either how one redistributes the existing weight or removes extra weight from the side that's low in the water.
It's a 3D problem, because the weight is probably either fore or aft as well as side to side. Look at the boat in the water, see if it sits low to port or starboard as well as low fore or aft. Next try adding weight to the high side and end at the same time. If it sits low to port and low in the stern add weight to the starboard-aft until the boat is balanced side to side until it's level. Now you have an idea of how much to shift or remove. Look at what's in the boat and decide.
Good luck.
Boris |
Joined: 23 Oct 2003 Posts: 5315 City/Region: Warrenton
Posted: Fri Nov 25, 2016 7:45 pm Post subject: |
It sounds like you have a Wallas. The stove itself isn't heavy, but the anxiety and stress it carries is a tremendous burden. _________________ TyBoo Mike
Sold: 1987 22' Cruiser |
Hunkydory
Joined: 28 Mar 2005 Posts: 2662 City/Region: Cokeville, Wyoming
State or Province: WY
Vessel Name: Hunkydory
Posted: Fri Nov 25, 2016 8:16 pm Post subject: |
TyBoo wrote: | It sounds like you have a Wallas. The stove itself isn't heavy, but the anxiety and stress it carries is a tremendous burden. |
You just made my day _________________ Jay and Jolee 2000 22 CD cruiser Hunkydory
NancyandBud
Joined: 15 Aug 2016 Posts: 199 City/Region: Nashville
State or Province: IL
Vessel Name: Willow
Photos: Willow
Posted: Fri Nov 25, 2016 8:29 pm Post subject: |
And I thought it was a good thing that our boat came with one. _________________ "Is there a 12 step program for people addicted to sailing? Yes, & the 13th step is called a C-Dory" Marc Grove
Fair Winds and Following C's to us all. |
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Fri Nov 25, 2016 8:38 pm Post subject: |
TyBoo....You also made my day.... you are so correct about the wallas...
I have a propane stove and one of those small fireplaces...plus a 2.5 gallon propane tank on the light side... great for wine and cheese ambiance
The tank is in the left side lazzeret.....(light side)
Joel
SEA3PO |
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Fri Nov 25, 2016 8:41 pm Post subject: |
Proper Sea Talk would be the Port Side stern locker.. The one with a bottom in it... used to use it as a bait tank...now a propane locker.
Joel
SEA3PO |
Hunkydory
Posted: Fri Nov 25, 2016 9:10 pm Post subject: |
Nancy and Bud wrote: | TyBoo wrote: | It sounds like you have a Wallas. The stove itself isn't heavy, but the anxiety and stress it carries is a tremendous burden. |
And I thought it was a good thing that our boat came with one. |
Actually, I still think it is, as pricey as they are & wonderful when properly working |
South of Heaven
Photos: Blue Water
Posted: Fri Nov 25, 2016 10:48 pm Post subject: |
My 19 used to sit lop-sided as well. I never figured it out. It was so lightly loaded too and the fuel/batteries were almost symmetrical. Strange. _________________ <><><> Jason <><><>
1995 C Dory 16' Angler (40 hp Yamaha, sold 2/16) |
Ron on Meander
Joined: 17 Jun 2004 Posts: 561 City/Region: Powell River
Vessel Name: Meander
Photos: Meander
Posted: Sat Nov 26, 2016 12:40 am Post subject: |
A C-Dory without a Wallas is like Seattle without the Sea Hawks. Unimaginable. To me anyway. |
Foggy
Joined: 01 Aug 2013 Posts: 1524 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Sat Nov 26, 2016 8:02 am Post subject: Re: Why does my boat always sit lopsided ? |
SEA3PO wrote: | SNIP it has always sat lopsided...I only carry SNIP a load of krap on the drivers side....(not funny)
SEA3PO |
My best guess for uneven gunnels: your holding tank is too full or
it's the wind.
Good Luck with that.
Aye. _________________ "I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life. |
Joined: 27 Oct 2012 Posts: 3384 City/Region: SW Michigan
Posted: Sat Nov 26, 2016 8:44 am Post subject: |
These boats are light weight and relatively narrow in beam at the water line. In my boat most of the heavy stuff is on the starboard side (batteries, helm, wiring harness, battery charger, sink, refrigerator, stove) plus the biggest cabin storage area is on that side. This all conspires to put the lateral CG right of centerline. If you add the weight of the operator you can have a few hundred pounds of offset load. This is a fair percentage of the boat total weight.
When the boat is moving you can trim this out with the tabs. But I have noticed that my boat has a significant change in lateral trim if a passenger moves from one side of the boat to another.
Unless I need to do otherwise, I only put fuel in the port tank. This does help balance the load a bit. |
RobLL
Joined: 05 Aug 2014 Posts: 421 City/Region: Bremerton
Posted: Sat Nov 26, 2016 9:57 am Post subject: |
kicker and batteries (mostly) on the starboard side. Rain collects as per.
bilge pumps on the port, so after a rain it drains after I get aboard! |
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Sat Nov 26, 2016 12:33 pm Post subject: |
Maybe I could get rid of the ice chest in the back and replace it with a narrower but taller ice chest on the light side next to the aft bulkhead... |
