Lewmar Pro Sport 550 Windlass Parts
Mike B
City/Region: Staten Island
State or Province: NY
Vessel Name: Remembrance
Photos: Remembrance
PostPosted: Sat Nov 05, 2016 7:47 pm    Post subject: Lewmar Pro Sport 550 Windlass Parts Reply with quote
Does anyone have an idea where I can get parts for my Lewmar Pro Sport 550 Windlass ?
PostPosted: Sat Nov 05, 2016 11:04 pm    Post subject: Reply with quote
The pro sport is not as common as many of the other windlasses--but P2 Marine should be able to get the parts. I suspect that most of the parts are similar to the 700.
Mike B
Photos: Remembrance
PostPosted: Sun Nov 06, 2016 6:55 am    Post subject: Reply with quote
Thanks, I saw P2 but didn't see mine on their list. Ill give them a call Monday.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Nov 06, 2016 3:13 pm    Post subject: Reply with quote
Anything wrong with the unit and what parts do you need?
Brent Barrett
Mike B
Photos: Remembrance
PostPosted: Sun Nov 06, 2016 3:56 pm    Post subject: Reply with quote
The line and chain feed out if you only pull on it. It was fine for the last few years, just started in September. I saw a video on youtube and understand what happened and why with the bushing that should only turn one way and lock the other way. Mine is frozen. Trying to anticipate any possible problem I started looking for parts and couldn't find them. As long as its cranking by March Ill be good ! Thanks for the help.
PostPosted: Sun Nov 06, 2016 6:02 pm    Post subject: Reply with quote
P2 seems to have a diagram of your windlass on their site, with parts list. Agree that you want to talk to them, when you have the parts you need in hand.
Also find out why the windlass failed. Although they are not the most expensive windlass, I have been using Lewmar (or predicessor0 for many years, and if you take care of them, they seem to continue to work fine. Not to say, you don't have to disassemble, grease, clean etc on a regular basis...
Good luck.
Mike B
Photos: Remembrance
PostPosted: Tue Mar 07, 2017 3:55 pm    Post subject: Reply with quote
Well now that its apart I found the problem with my windlass. The 2nd compound gear assembly was locked up. I freed it up and dissembled it and got a bearing rebuild kit from P2. The only part I cant find is a thrust pin roller bearing, it is the size of a 3/8 washer with rollers. Lewmar does not sell them and I'm having trouble measuring it because of rust. Any idea where to get one ? There is a picture in my albums, I cant seem to post it here.[/img]
BrentB
Photos: BrentB
PostPosted: Tue Mar 07, 2017 4:02 pm    Post subject: Reply with quote
check with www.rbcbearings.com
PostPosted: Tue Mar 07, 2017 6:41 pm    Post subject: Reply with quote
Mike, is this the pix of the washer/bearing you are wanting moved? Hope so.
Mike B
Photos: Remembrance
PostPosted: Tue Mar 07, 2017 6:59 pm    Post subject: Reply with quote
That's it . Little bearing, big headache.
BrentB
Photos: BrentB
PostPosted: Tue Mar 07, 2017 7:14 pm    Post subject: Reply with quote
Is thrust pin roller bearing the correct name?
Mike B
Photos: Remembrance
PostPosted: Tue Mar 07, 2017 7:18 pm    Post subject: Reply with quote
as far as I can tell yes.
BrentB
Photos: BrentB
PostPosted: Tue Mar 07, 2017 7:28 pm    Post subject: Reply with quote
ok, thanks I would send the pic to various bearing tech support sites
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Tue Mar 07, 2017 9:15 pm    Post subject: Reply with quote
Torrington Thrust Bearing Wink Wink
Mike B
Photos: Remembrance
PostPosted: Wed Mar 08, 2017 7:16 am    Post subject: Reply with quote
I can find these type of bearings, I need the part number or correct dimensions.
Page generation time: 0.0464s (PHP: 43% - SQL: 57%) - SQL queries: 28 - GZIP disabled - Debug on
