C-Dude
C-Dory Year: 2013
Vessel Name: Gryphon
Photos: C-Spirit
Posted: Wed May 10, 2017 1:16 am Post subject: Fuel selector switch |
I purchased a 2013 22 cruiser. Maiden voyage this coming Saturday. The fuel selector switch has 4 labels on it. "off, port, starboard, gasoline". The previous owner duct taped a "port" label over the original "gasoline" label on the switch and duct taped "starboard" over the original "starboard" label on the switch.
He told me he runs off one tank at a time, I want to run simultaneously from both.
I would like to run out of both tanks simultaneously instead of switching tanks. It is a single engine vessel. Do one of the positions on the switch allow for simultaneous fuel burn from both tanks?
I wish I could post a picture for reference, but cannot figure out how.
My old c-dory had dual engines and no fuel switch, so this was not an issue.
In my mind, burning from both tanks simultaneously would be best for weight and balance and for convenience.
[/img] _________________ Ben
2013 C-Dory 22 Cruiser - sold
2006 North River 26 O/S
2004 Wooldridge Alaskan OB Jet
2001 C-Dory 22 Cruiser
1994 Weldcraft Jet boat
Seine Net Skiff |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Wed May 10, 2017 8:53 am Post subject: Fuel selector switch |
I guess you could just take the fuel line from each tank and put them into a T fitting. Then use the last part of the T to go to the engine. I guess you could continue to use the valve but it would be just on and off and you have to remember which way was on the valve so you could label it that way. I never had too much trouble managing the levels on two tanks using the fuel valve. We just slid a cooler around or move passengers around. I thought on a 22 you could see the fuel levels. Having a reserve amount set aside seemed like a good idea for me. If I remember the standard selector valve has three ports. Port, starboard and the third to the engine. If I was to do what you are thinking on I would want to carry some extra fuel for the ride.
BrentB
State or Province: IN
Photos: BrentB
Posted: Wed May 10, 2017 8:54 am Post subject: |
The handle may be attached incorrectly. That is big end or handle is the pointer to fuel flow _________________ Brent Barrett |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Wed May 10, 2017 9:10 am Post subject: Fuel selector switch |
Or the port and starboard hoses were installed backwards. I thought I remembered the shaft and the handle having a flat side so it could not slip.
The fuel valve if I remember the center connection was to the engine and the other two were for the port or starboard tanks. By pulling off the hoses and putting air to the fuel line you can hear the air in the tank the hose is connected too. I know this because our boat came with the hoses connected incorrectly. The fuel line for engine was connected to starboard position on the valve and the center connection was going to the starboard tank. That meant when you switched to the port tank you had no fuel getting to the engine. You can pull the valve and blow thru it to see how the hoses should be connected.
D.D. |
BrentB
Photos: BrentB
Posted: Wed May 10, 2017 9:23 am Post subject: |
That is the issue. The valve needs removal and inspected to determine the root case.
m2cw |
Joined: 02 Nov 2003 Posts: 20848 City/Region: Pensacola
Posted: Wed May 10, 2017 9:24 am Post subject: |
Using the fuel valve which comes with the standard rigging, you can only run one tank at at time, except as noted above to put a "T".
Since the boats use relatively small amounts of fuel, we just alternate days port and Sub., or use the fuel to help trim the boat.
The point made about "reserve" is an excellent one. One a long run, we will run one tank going out--and the second one coming in, but always leave about 1/4 tank "reserve" on the first tank used.
This has worked well for us on the 22's. _________________ Bob Austin
BrentB
Photos: BrentB
Posted: Wed May 10, 2017 9:46 am Post subject: |
Does the handle (big end) have a company engraved on it like Anderson Brass? |
C-Dude
C-Dory Year: 2013
Photos: C-Spirit
Posted: Wed May 10, 2017 1:14 pm Post subject: |
BrentB wrote: | Does the handle (big end) have a company engraved on it like Anderson Brass? |
Yes, it is engraved "Anderson - Brass Co. Harrisville, SC" |
C-Dude
C-Dory Year: 2013
Photos: C-Spirit
Posted: Wed May 10, 2017 1:32 pm Post subject: |
Understand that "port" is intended to draw from port tank independently and the same with starboard. "off" is obviously off. What is the "gasoline" position on the switch typically for? Drawing from both tanks at the same time or something different?
Ben |
BrentB
Photos: BrentB
C-Dude
C-Dory Year: 2013
Photos: C-Spirit
Posted: Wed May 10, 2017 4:26 pm Post subject: |
That is the one.....I believe it is the 200 series, because it clicks into position. I contacted the manufacturer, received an immediate response and they said I will need to disassemble and take a look in order to determine the set up. I will take it apart soon.
Thank you!! |
BrentB
Photos: BrentB
Posted: Wed May 10, 2017 4:30 pm Post subject: |
I assume the gasoline label is just a label identifying the valve is for fuel tank selection and as stated above only tank is able to be use to remove fuel and the other tank is closed off from drawing fuel. Good idea on the T fitting |
