Lower Unit Drain Plugs
Goto page 1, 2, 3  Next
PostPosted: Mon Oct 24, 2016 11:01 am    Post subject: Lower Unit Drain Plugs Reply with quote
Sick and tired of lower unit drain plugs that strip out on the screw head. All are common screwdriver driven style. I'd like to find some that are allen wrench driven. Anyone have a lead on who makes such? I'm looking for three that fit in the Mercury 4 stroke 115hp (3/8 x 16 I believe), and two for the Tohatsu/Nissan 6hp Kicker (M8 x 1.15 or 1.25, can't remember which it is). Thanks in advance. Colby
PostPosted: Mon Oct 24, 2016 11:42 am    Post subject: Reply with quote
This may not help you: but be sure that the screwdriver fits the drain plug slot. I have never had one strip out. I use bits in a socket. As I recollect mine are 3/8" drive. You can get bits in either slot, or phillips head which fit properly. With the socket/driver, you can keep good pressure on the plug head/driver bit, as you back it out.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Mon Oct 24, 2016 12:19 pm    Post subject: Reply with quote
I was just thinking about the same thing. I saw that my lower unit had a couple drops come out while parked for a week in hot weather (hadn't lost a drop all winter in the garage). I looked at the lower screw and it was mangled, so I thought that I would get a new one, and a new gasket, when replacing the oil. My "go to" place is usually Tacoma Screw Products because they are close, but Fastenal generally has stuff like this. I could pull the screw, measure it and get the thread pitch, but I usually just walk in with the old part. If you don't want to pull the screw first, and you have the fill attachment for the engine, you could just measure that and go shopping.
Yamaha actually lists the screw (in a flat head) for $5 and the gasket for $4. I'm guessing I can get both at Tacoma Screw (in a stainless Allen head) for $3.
Mark
island andy
City/Region: rochester hills
PostPosted: Mon Oct 24, 2016 12:45 pm    Post subject: Reply with quote
ahhh, the misery of drain screws!
I would second thataway's principle that pressure is key. My tool choice is a little different, but accomplishes the same goals of pressure applied in a straight line to the slot.
I use a large [that is, LARGE] screwdriver. One which fills the slot. The screwdrivers I use have a hex bolster/fitting on the shank. A square shank serves the same purpose. On my hex bolster I apply a ratcheting box wrench, [a fixed box or open end wrench can serve] to the hex bolster. Then, carefully applying pressure in a straight line with the longitudinal axis of the screw, I can apply torque through the end wrench while maintaining alignment with the screw.
For me, this is a workaround for becoming older and arthritic, but I have found that the technique works well for most any screw, both slotted and Phillips, and I rather wish I had adopted this method years ago. My latest old/arthritis workaround is using a repurposed patient lift to get outboards on and off transoms.........
As a more direct answer to your question, I know that BRP/OMC offers hex recess drain screws, and I love the Fastenal approach.
andrew g wilson jr
PostPosted: Mon Oct 24, 2016 12:48 pm    Post subject: Reply with quote
Perhaps McMaster Carr?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Oct 24, 2016 1:11 pm    Post subject: Reply with quote
Any chance that you are over tightening? Isn't the
Torque spec 35 ft lbs
Brent Barrett
Darkwater
City/Region: Fort Bragg
Photos: Darkwater
PostPosted: Mon Oct 24, 2016 1:12 pm    Post subject: Reply with quote
I use a large screwdriver (don't know number size) where the width of the blade is almost as much as the screw head slot, and the thickness of the blade has very little play when in the screw head slot. Keep the screwdriver perpendicular when tightening. Use a new O-ring every time.
If you want to use a ratchet, get a bit that fits the screw head as above but beware of over tightening. My Honda 90 service manual says only 4.8 ft-lb torque, which is about what you get when tightening "snug" with the large screwdriver. If you are unsure, get a small torque wrench.
I have never heard of one of these screws coming loose. Anybody?
Darkwater Doug
Fort Bragg, Calif
Boat and fishing obsessed...
C-Ray 230DA sold Aug 2013
Retired Dec 2013
2008 C-Dory 22 Cruiser (unnamed) Jun 2014
PostPosted: Mon Oct 24, 2016 1:20 pm    Post subject: Reply with quote
I had the same vexation. You can't get it tight enough not to leak without slipping out of the slotted head (why slotted? Angry).
I stopped in the local Yamaha mechanic (where I buy parts sometimes) and asked them how the heck they do it? He advised what island andy describes above. I followed this procedure and, Voila! I was able to get the screw MUCH tighter (which I had to or it would tend to seep).
1) Get very large screwdriver with tip that fits the screw really well and has a square shank (I had to go to a large Ace Hardware).
2) Fit this into the slotted head, apply pressure to keep it there.
3) Grab the shank of the screwdriver with a spanner that fits the flat and only turn with that, while keeping up the pressure on the screwdriver head. You can get it a lot tighter. And no slipping.
A note is that I did have a fresh O-ring on the screw and the slot was fine, but even so, I could not get it properly tight without the recommended method. I also bought a new screw-with-o-ring at the Yamaha place just so I'd have it on hand (but with the recommended technique didn't need it -- just used the original screw with the new o-ring I was already using.
But Colby, I agree. Would be great if it had a Robertson drive or something else similar (maybe it can't for some reason?).
PostPosted: Mon Oct 24, 2016 1:44 pm    Post subject: Reply with quote
For everyone telling me not to strip it out. Thanks! Rolling Eyes But as long as I've owned boats with outboards, I've had problems with those slot heads!!! Over time they do strip out. Yeah, I may be overtightening the suckers. But since it's underwater and I don't want to chance having one come lose on a vibrating piece of machinery, I like to make sure they are tight. Then getting them out again is always an issue. Yeah, I have several screw drivers, all of various size. But seems none of them are a perfect fit. Plus, that slot in the head of the screw is fairly shallow. Without exactly the right angle, blade just pops off, causing more damage to the screw head. Sounds like some others know exactly what I'm talking about. So anyway back to my question. If anyone knows of a part number or brand that has the allenhead, I'd like to know. Also, are the plugs stainless or aluminum? Since the screws tend to strip out in that slot, I have a hard time believing they are Stainless...especially going into aluminum units. I see Amazon sells some advertised for Evinrude/Johnson, but the description doesn't say the size of screw.
PostPosted: Mon Oct 24, 2016 1:50 pm    Post subject: Reply with quote
For those who have aluminum in the lower end casing, just pointing out that aluminum and stainless don't mix. The aluminum will become corroded.
Damn near ruined a sailboat mast that way. Don't ruin your motors lower casing.
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Mon Oct 24, 2016 2:42 pm    Post subject: Reply with quote
I just pulled the lower screw out to change my oil. Two reasons I'm going to keep the slot head screw. First, an Allen head screw would set proud of the casing. Not a big deal, but the thin head on the original is flush. The second reason is that the original has a magnet. There was just a trace of silver powder on it, so it's doing it's job.
The original Yamaha screw is stainless, as are probably all. I don't know if there would be a problem unless you don't have good anodes. If you think that a SS strips easily, try an aluminum screw. It goes in but you get to drill it out. Even aluminum screws in aluminum have this problem. I had to drill out several when I rebuilt my 1933 Evinrude.
There is a special product (I forget the name) that is used for screws going into aluminum. It's a non-conductive Teflon paste. I used it on my aluminum trailer wheels that have SS lug nuts. I suppose it would work for a SS screw into an aluminum lower unit, but I've never heard of that screw being a problem.
Mark
Will-C
City/Region: Temple
Vessel Name: Will-C
Photos: Will-C
PostPosted: Mon Oct 24, 2016 4:15 pm    Post subject: Lower Unit Drain Plugs Reply with quote
I like Klein tools and their screw drivers. The right sized screw driver depends on the blade thickness and width. Using something that sort of fits usually is the cause of the problem. I think a decent screw driver that will fit correctly and hold up for years you might not find the right one at Kmart, Wal-Mart, ACE hardware or True Value. Get some new screws and head to Grainger or a decent tool house and find a quality and correctly sized screw driver. I would bet they use that type of screw so you won't /can't mess up the lower unit casting by stripping out the screw threads.
D.D.
PostPosted: Mon Oct 24, 2016 4:33 pm    Post subject: Reply with quote
The beauty of using the socket screwdriver, is that I can set the torque properly--How do you do that with a screw driver and a set of vise grips?>???
Colby, I'll bet you are using undersized screwdriver bits! Not doing the correct torque? Maybe not changing the O ring or Crush Gasket each time.
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Oct 24, 2016 5:24 pm    Post subject: Reply with quote
I have taken a different approach to loosening and tightening the oil drain and vent plug. I went to outboard school way back in 1974 (actually I got to go to several time at the expense of the USCG).... I use a simple hammer driven impact wrench with a bit in it that fits the screws (for any brand of outboard) and have never stripped a screw nor have had a leak. The hammer driven impact wrench once was an expensive tool, but now can be purchased very cheaply from most tool suppliers (Harbor Freight has the tool with bits for less than $9, http://www.harborfreight.com/impact-screwdriver-set-with-case-37530.html )
All of the C-Brats that get outboard maintenance training at my home have learned the value of this very simple tool.
Steve Baum
Homeport of Portsmouth, VA
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Mon Oct 24, 2016 6:59 pm    Post subject: Reply with quote
I thought about using my impact wrench with a screwdriver bit, but first I just took a big honkin' screwdriver to it and it came out easy enough. Was it the right size screwdriver? The Yamaha screw is metric (8mm x 1.25mm thread pitch). It wouldn't surprise me that the slot is also metric. I'm not sure that I've ever seen a metric screwdriver. Yamaha probably sells one just for this purpo$e.
The oil change went without incident, so I'm okay for a few hundred hours.
Mark
Page 1 of 3
Page generation time: 0.126s (PHP: 80% - SQL: 20%) - SQL queries: 32 - GZIP disabled - Debug on
