touch up stripe
NancyandBud
City/Region: Nashville
State or Province: IL
Vessel Name: Willow
Photos: Willow
PostPosted: Mon Oct 17, 2016 4:15 pm    Post subject: touch up stripe Reply with quote
Does any one know of a paint to touch up the green gelcoat stripe?
"Is there a 12 step program for people addicted to sailing? Yes, & the 13th step is called a C-Dory" Marc Grove
Fair Winds and Following C's to us all.
PostPosted: Mon Oct 17, 2016 4:49 pm    Post subject: Reply with quote
When I needed to touch up mine I got one of these and mixed and matched.
http://www.jamestowndistributors.com/userportal/show_product.do?pid=11339&familyName=Evercoat+Match+%26+Patch+Kit
You can play around pretty much as long as you like to get the color right until you add the hardener.
Unless you know right where to look you can't see the repair on my boat.
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Mon Oct 17, 2016 8:35 pm    Post subject: Reply with quote
Nancy,
post some pics.
If the entire colored gelcoat stripe or areas of it is looking chalky or has a whitish film or if a wax job gets dull in 2 months with poor mirror reflection you may be dealing with gelcoat oxidation, and touch up 'paint' may not be the answer in that vintage boat.
If so, the cure involves removing wax (Simple Green or even WD-40 by the gallon at Lowes works) and wet-sanding (ye gads!) with 3m 400 or 600 then 800, 1000, 1500, 2000g sandpaper in a bucket of hot water with a few drops detergent, frequent rinses, and changing water between each grit change.
Any oxalic acid product can also work after de-waxing but pits the trailer and with less control over problem areas.
So, hope you're talking about a few scratches or nicks and not oxidation.
Best,
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
Page generation time: 0.0569s (PHP: 38% - SQL: 62%) - SQL queries: 17 - GZIP disabled - Debug on
