Transom Mounted Livewell pump Fast water pickup?
CDory23
Photos: CDory23
PostPosted: Fri Oct 14, 2016 2:15 am    Post subject: Transom Mounted Livewell pump Fast water pickup? Reply with quote
Hi all,
A while back I installed a 500gph transom mounted removable live well pump for my 13 gallon live bait tank. Its basically a bilge pump mounted to the transom so I can avoid drilling thru-hulls for a permanent install. I don't use it all the time so I like the fact I can remove it easily. It has always worked great but I've never had to transport bait for long distances at higher speeds. I recently killed all of my bait traveling from long beach to Catalina because the pump is useless over 10mph because the pump is out of the water. I have seen fast water pickups for thru hulls but nothing for the transom mount setup. Anybody know a solution?
san juanderer
City/Region: Stanwood
C-Dory Year: 1990
PostPosted: Fri Oct 14, 2016 9:14 am    Post subject: Reply with quote
Does your boat have trim tabs ?
Yes, then drill 1 1/8 hole thru the tab and mount the pump stem thru the hole. You will then have cruise speed water pickup.
To drill the hole use a bi-metal hole saw.
alan
Cdory 22 Angler
SeaSport 24XL, Etec 250 hp (sold)
Rosborough RF246 (sold)
Commander 30 Sportfish (sold)
Olympic 26 XL (sold)
Glassply 19 (sold)
Olympic 23 (sold)
Bayliner 38 Motoryacht (sold)
Olympic 20 (sold)
Fiberform 16 (sold)
Olympic 18 (sold)
CDory23
Photos: CDory23
PostPosted: Fri Oct 14, 2016 10:41 am    Post subject: Reply with quote
Thanks, but I do not have trim tabs. I have twin engines with permatrims installed and have been happy with the trim I get from adjusting the motors themselves.
CDory23
Photos: CDory23
PostPosted: Fri Oct 14, 2016 10:42 am    Post subject: Reply with quote
This is the setup I have flush with the bottom of the transom
http://www.jmsonline.net/transom-mnt-aerator-pump-360.htm?gclid=CjwKEAjwhILABRDwo8mlqt6ug38SJACNSq_kbnBcHbU1sgrNyLUmrPiFlCgtoju-sL7EcaTYZaPAixoC7p_w_wcB
CDory23
Photos: CDory23
PostPosted: Fri Oct 14, 2016 2:56 pm    Post subject: Reply with quote
I found a great cheap solution to the issue. I'm going to mount a flanged fitting pick up tube to hang below the transom cut at angle to get suction while underway. It took a while but I found a great write up on an install which covers this type of set up in detail. Here is a link with pictures where I learned this.
http://www.carolinaskiffowner.com/showthread.php?12621-Quick-Disconnect-Live-Bait-Tank
PostPosted: Fri Oct 14, 2016 8:03 pm    Post subject: Re: Transom Mounted Livewell pump Fast water pickup? Reply with quote
CDory23 wrote:
Hi all,
Go slow for 5 minutes every hour to allow the bait tank water to refresh?
Page generation time: 0.0382s (PHP: 59% - SQL: 41%) - SQL queries: 23 - GZIP disabled - Debug on
