Finding a small part
msgchef
City/Region: Washington
Photos: Seaweed
PostPosted: Mon Oct 03, 2016 9:26 pm    Post subject: Finding a small part Reply with quote
Hi
CD25, Center window, adjustable rod 1 or 2 holding up the window is now missing the pin that connects the rod to the window bracket.
Does anyone have any idea where to find a replacement? West Marine had no idea and not in the catalog unless I wanted to replace the whole rod assembly.
Not even sure what to call this pin.
Thanks so much for help
Paul
"There are good ships,
and there are wood ships,
The ships that sail the sea.
But the best ships, are friendships,
And may they always be."
2015-2018 Seaweed
PostPosted: Mon Oct 03, 2016 9:51 pm    Post subject: Reply with quote
Any good machine shop can make a pin like that--problem is that you have to have the dimensions. For similar instances, I have used welding rod (without flux)
It is possible that a SS roll pin is a replacement. If you can get micrometer measurements of the diameter--should be easy to find the correct pin. Some different years have had different support "arms" for the opening front window.
msgchef
Photos: Seaweed
PostPosted: Tue Oct 04, 2016 7:33 am    Post subject: Reply with quote
Thanks, Dr. Bob
Obviously not an off the shelf fix, but sounds very doable.
Paul
AstoriaDave
City/Region: Astoria
PostPosted: Tue Oct 04, 2016 8:54 am    Post subject: Reply with quote
Paul, any good machinists supply ahould have drill rod in a variety of dimensions. Larger communities with machinist shops would have one. Check McMaster-Carr for mail order choices if you are a long ways from town.
Dave Kruger
Astoria, OR
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Oct 04, 2016 11:23 am    Post subject: Reply with quote
Can you post a pic with measurements? I can check my odds and ends bins
Brent Barrett
PostPosted: Tue Oct 04, 2016 11:59 am    Post subject: Reply with quote
Roll-pins are standard commercial items. If you've lost one, use a drill bit to find the diameter, a tape measure to find the length and then look in the Granger or McMasters-Carr catalog to find the replacement. Also try BoltDepot.com
If it's just a pin, find the measurements, as above and then look in the catalogues.
You need a stainless replacement and could search for it on the internet as well as the above catalogues.
msgchef
Photos: Seaweed
PostPosted: Tue Oct 04, 2016 3:23 pm    Post subject: Reply with quote
thanks all
That will be my minor project once we get thru whatever Matthew has in store for us. Last tracking had it coming directly over my house. wish us luck
Paul
Page generation time: 0.0321s (PHP: 65% - SQL: 35%) - SQL queries: 20 - GZIP disabled - Debug on
